Old 01-12-2011, 12:49 PM   #1
Padmei OP
enamoured
Oddometer: 3,604
Gen lite needed?
Hi all a quick question. I removed speedo & idiot lites etc on my 91 R80GS. I have read somewhere that the gen lamp is part of the charging system. Is this correct? If so I'll just mount a remote one somewhere no probs but if not needed I won't bother.
Cheers
PS please don't post a ' use the search function' reply thanks.
Padmei is offline   Reply With Quote
Old 01-12-2011, 12:56 PM   #2
matman1972
Lost in the woods.
matman1972's Avatar
Oddometer: 711
You do need the charging light circuit. An electrical charge travels through it prior to starting to charge the coils in the stator. It of course also lets you know when your output from the alt falls below what it should be. If you remotely locate it, be sure to use a bulb of similar wattage so you get the correct resistance. I did this with an r50 that I removed the speedo from. I ended up putting a small digital speedo on it, and mounted a small plate to the tripples with two lights, oil and charging.
Matt
2005 vw trike
Estamos copados
Confusion to our enemies.Zaphod for president!!
matman1972 is offline   Reply With Quote
Old 01-12-2011, 01:13 PM   #3
Padmei OP
enamoured
Oddometer: 3,604
Cheers fro that Matman.
I actually found this & it answers my question also.
http://www.buchanan1.net/charge.shtml
Old 01-12-2011, 02:35 PM   #4
shaner1100gs
Oddometer: 165
You could use one of these.
http://www.motoelekt.com/genlightacc.htm
shaner1100gs is online now   Reply With Quote
Old 01-12-2011, 02:50 PM   #5
matman1972
Lost in the woods.
matman1972's Avatar
Oddometer: 711
Did you bypass the light to keep juice going to the gen before starting? I have always wondered if that is needed. Dad has a VW trike that has the same setup as a bosch and couldn't get power without the light hooked up or bypassed.
Matt
2005 vw trike
Estamos copados
Old 01-12-2011, 07:39 PM   #6
nella
nella's Avatar
Oddometer: 403
It's interesting that this came up right as I started to install warning lights on my 100/7. I've had the charging light on my bike disconnected since April and it's been charging fine.
Tonight I experimented with a 12v led in the charging circuit and it seems to work fine. I might add a 400ohm resistor in parallel, not sure yet.
Scott
nella is offline   Reply With Quote
Old 01-12-2011, 10:04 PM   #7
Padmei OP
enamoured
Oddometer: 3,604
I've started it without anything plugged into the idiot lite plug & no problems. I'm not planning on using it as a round-the-worlder & I don't commute or sit at lites so May not worry about it- just put the tender on it every few weeks.
Shanna thanks for that link. It gives me the details of what I need to make one up.
Cheers guys.
Old 01-12-2011, 10:46 PM   #8
matman1972
Lost in the woods.
matman1972's Avatar
Oddometer: 711
My newest project has no charging light. Went total loss just so I don't have to deal with those ural alternators
Matt
2005 vw trike
Estamos copados
Times are GMT -7.   It's 04:09 AM.
