Old 01-23-2011, 06:26 AM   #571
doyle
RallyRaidReview-ing
doyle's Avatar
Oddometer: 23,705
Originally Posted by Pilbara View Post
It seems Despres had quite a capacity advantage (according to Michelin) in 2007 and 2010
Seriously bored out engine
Cheers
Pilbara
And therein lies the difference between "factory" and customer bikes.
RallyRaidReview - @RallyRaidReview
doyle is offline   Reply With Quote
Old 01-23-2011, 07:12 AM   #572
JMo (& piglet)
Gone a bit Baja
JMo (& piglet)'s Avatar
Oddometer: 4,276
Originally Posted by crankshaft View Post
Been running Tubliss on my 950 SE for a year now and I find the opposite to be true, I can change them faster than a tube. I have eliminated the possibility of getting pinch flats and when I ran tubes, I would get them on the SE all the time while running hard in rocky terrain. I've also ran them on Rally stages with no problems at speeds up to 116 MPH and I'm still sitting here typing
I usually carry a spare Tubliss tube in my pack but I've never used it.
Try them sometime.
Hi Crankshaft - I'm not suggesting they are not a useful alternative to tubes, just saying they are not a [sensible] alternative to mousses, particularly when racing...
The only benefit I can see with using Tubliss is the ability to run other brands of [tubeless] tyres on tubed rims, and the ability to alter the air pressure - both of which have little baring on rally racing - the best tyres for rallying are all designed to run with mousses anyway, and the 15-18psi range of a mousse seems to be the optimum for heavish bikes, hitting stuff at racing speeds - even in sand? So I can't see how Tubliss would offer any benefit?
Ultimately you want to minimise (if not eradicate altogether) the chance of a flat, and an air-inflated tyre can still get holed... yes you can plug it, and reinflate with a gas cylinder, but that all takes time you won't want to lose in the middle of a stage?
With a mousse, it is very rare it would ever go flat (even if it starts to break down with heat, it never goes 'flat') - and if it does start to soften and lose grip on the bead, then the typical trick is to use heavy duty zip-ties to hold the tyre onto the rim for the rest of the stage... straight forward and less than a minute to implement.
I'm not saying Tubliss doesn't have a place, I'm just saying noone [to my knowledge] uses them in rally racing...
Jx
ps. That said, Tubliss might have a place in short course sand events or for extreme enduros in muddy conditions, where you might want to run a softer rear tyre?
JMo (& piglet) is offline   Reply With Quote
Old 01-23-2011, 07:16 AM   #573
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,548
my mousse's are a bit soft for the 640 but they sure are sweet on the 525
Beerthief
skibumsoirée2009 skibumsoiré2010
Riff Raff 2015, 2012, 2011, 2010, 2009
RIP ITsteve, ride in peace my friend
save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk
skibum69 is offline   Reply With Quote
Old 01-23-2011, 07:26 AM   #574
F650Dakar_Norway
What off-season?
F650Dakar_Norway's Avatar
Oddometer: 960
Spot on. The "factory" 690's had 700cc (80 plus HP) versus the 653cc ( ca. 72HP )of the customer bikes. Both Pal Anders Ullevalseter and Thomas Berglund converted their 690's last year to 700cc to compensate for the restrictor rule.
I can however confirm that us mortals with customer bikes don't have to fret over lack of power. It still hauls ass and is a joy to ride in the dirt.
Norway
Current stable:
2010 BMW F800GS
2008 KTM 690 RFR
1994 Honda ST1100
F650Dakar_Norway is online now   Reply With Quote
Old 01-23-2011, 07:28 AM   #575
JMo (& piglet)
Gone a bit Baja
Oddometer: 4,276
I believe there are different 'weights' of Rally mousse, depending on what weight of bike you are riding - like you suggest, a fully-fulled 75bhp 690RR is going to put a lot more strain on the tyres than a 50bhp CRF450 for example...
And I know there are are different rated front Desert mousses too - Patsy tends to specify the stronger/stiffer version for front wheels (to help minimise dented rims), and of course you'd want to run a Desert specific mousse in a Desert tyre, not a regular MX/enduro mousse (which will be softer, and smaller)...
Jx
Old 01-23-2011, 07:34 AM   #576
skibum69
slave to gravity
skibum69's Avatar
Oddometer: 5,548
Jx
true, I knew there were different flex mousse's, I had all my spares for the 525 and threw a set on the 640 for arse'ing around at home
Beerthief
Old 01-23-2011, 09:02 AM   #577
doyle
RallyRaidReview-ing
doyle's Avatar
Oddometer: 23,705
mmmmm mousse.
Old 01-23-2011, 09:40 AM   #578
Bluebull2007
Bluebull2007's Avatar
Oddometer: 5,261
Doyle.
I would be wary of tubliss in a rally for the simple reason if you ding your rim hard (Like I always seem to do), you will be screwed because you cant get a seal.
If it werent for that I think tubliss would be great.
Dreaming of Dakar
Everyone has a max speed, 90% of that max speed is much safer and easier, and if that 90% speed isn't fast enough at Dakar, you enter the snowball. - neduro
Bluebull2007 is offline   Reply With Quote
Old 01-23-2011, 10:05 AM   #579
JMo (& piglet)
Gone a bit Baja
Oddometer: 4,276
mmmmm mousse.
Mmmmmmmm chocolate... x
Old 01-23-2011, 02:11 PM   #580
beechum1
Grimace Soup
beechum1's Avatar
Oddometer: 8,506
Try them sometime.
Just FYI for those interested in doing some kind of tubeless convert. http://cyb.smugmug.com/gallery/72508...65979444_cW2xa many people have had success.
Originally Posted by Boondoggle View Post
Watching Dakar is like watching people who've built their own world, and for just a couple of weeks they get to live in it.
beechum1 is online now   Reply With Quote
Old 01-23-2011, 02:23 PM   #581
JMo (& piglet)
Gone a bit Baja
Oddometer: 4,276
Originally Posted by Bluebull2007 View Post
Doyle.
It'll polish out...
Jx
Old 01-23-2011, 03:41 PM   #582
cyborg
Potius Sero Quam Numquam
cyborg's Avatar
Oddometer: 5,238
Try them sometime.
I agree with Crankshaft. I love the Tubliss in my RXV550 (both ends) with Michelin Deserts. I can run them down to 5psi and never worry about pinch flats and they handle all the speed & power the RXV550 can dish out. I had the wheels balanced so they run smooth at paved road/highway speeds. I did not find them hard to change either, with simple hand tire tools.
cyborg is offline   Reply With Quote
Old 01-23-2011, 03:48 PM   #583
cyborg
cyborg's Avatar
Oddometer: 5,238
This my gallery BTW. I have done this conversion on bikes that already can run "tubeless" tires so the rims I consider "tubeless compatible" and have spokes that basically never get loose (in non-racing applications). Never done my own method to dirtbike tires since I think they take too much of a beating and spokes get loose quicker. I run the Neutech Tubliss sustem in my Aprilia dirtbike. I've used my sealed rims method on my KTM990S and 2 Triumph Tigers 955i for over 110,000 combined miles of all kinds of terrain. I guess it sorta works. No failures yet.
Old 01-23-2011, 04:44 PM   #584
crankshaft
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,005
Doyle.
I dented a rim on the MX track while running Tubliss and it held just fine. Even if the tire lost air, the inner tube would still hold the tire on the rim but the tire would be flat. Done it many times and worked fine. Not trying to argue the difference between mousse and Tublis, just offering my rel world experience. Should I run a Rally on my 690 and prove the point?
Fine, the Safari it is
crankshaft is offline   Reply With Quote
Old 01-23-2011, 05:32 PM   #585
BC61
BC61's Avatar
Oddometer: 1,270
I found a good way of preserving the front tyre - and the perfect excuse for a gratuitous self-promotion shot:
Jx
What was your tire allotment and what were your change intervals?
BC61 is offline   Reply With Quote
Times are GMT -7.   It's 06:40 AM.
