Old 01-21-2011, 11:35 AM   #76
3uba296
Thumpcurious
3uba296's Avatar
Oddometer: 129
Or... try to find a core plug in the right size?
Dr350(80)R-97
3uba296 is offline   Reply With Quote
Old 01-21-2011, 02:08 PM   #77
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
Yes, I was really wondering if these are available.
Pablo83 is offline   Reply With Quote
Old 01-27-2011, 12:08 PM   #78
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
Originally Posted by BikePilot from DisTech's DR350 build thread
IIRC the primary drive ratio (crank to clutch basket basically) is different between the 350 and 250. I know that for a given final drive ratio my '94 250SE turns more rpm than my '96 350SE. Also note that your 250 motor is a 250SE. The plain S was kick start only.
primary drive ratios:
DR350 20:64 (3.200)
DR250 22:62 (2.818)
I'm led to believe that the lower ratio (from the 250) will be easier on the tranny and harder on the final drive. I'd rather be replacing chains/sprockets than trannies, so I'm going with the 250's primary.
Old 01-27-2011, 03:23 PM   #79
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,245
Yeah, what the numerically lower ratio does is transfer less torque through the geartrain by making it spin faster. A numerically higher final drive is then required to multiply the torque back up again. That's why Honda's HRC kit for the XR600 included an NX650/XR650L primary drive set with a lower ratio.
1995 XR628R -Lots of goodies...room for more.
Drinking: Funky Cold Medina.
HeadTrauma is offline   Reply With Quote
Old 01-27-2011, 04:53 PM   #80
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
I reviewed your comments on my NX build when I was deciding what promary to use. Thanks for all the help. BTW, since when are you into DR's?
Old 01-27-2011, 05:02 PM   #81
HeadTrauma
¯\_(ツ)_/¯
HeadTrauma's Avatar
Oddometer: 1,245
I was considering one as a possible alternative to an XR250.
I was also thinking about DR650s until I saw the thread about some grenading the gearbox.
Old 01-27-2011, 05:45 PM   #82
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
So far, the bike's been real easy to work on. I love the engine, it's very simple; much easier to work on than the RFVC. There are big bore kits available up to 460cc and with the 250, 350 ,street, and offroad versions, there are a number on interchangeable engine components.
The flexible chassis is an issue, but maybe I can get that sorted out. I'd love to have this engine in a CRF250 chassis; that'd be a lot of fun.
Old 01-27-2011, 05:49 PM   #83
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
The neutral switch looks like it's missing a cover. I checked the fiche and it doesn't show one, so I guess this is right.
Old 01-27-2011, 05:50 PM   #84
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
One tranny down, one to go...
Old 01-27-2011, 05:53 PM   #85
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
specs
I did some measurements on the different bores I have. "Sleeve" means the overall height of the sleeve.
The pins with two thicknesses are tapered on the inside; they get thinner towards the edge. Notice the pin dia is different between the 250 and the 350, so you can't put the 350's piston on the 250's rod (I was told you could).
Old 01-27-2011, 06:03 PM   #86
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
this is the counterweight drive gear on the crank. Jesse Kein says there is a problem with the pin slipping out and causing catastrophic damage. I can't remember what Jesse's solution was. I decided to weld mine.
I did a fusion weld (no filler rod) so I wouldn't upset the balance.
Old 01-27-2011, 06:06 PM   #87
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
What a mess
And the second engine's apart. Now to see if I can get them back together.
Old 01-27-2011, 06:15 PM   #88
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
Reassembly Notes
Flywheel weights:
91 DR250S: 4lb, 3oz
98 DR350: 3lb, 15oz
The manual suggests jamming a penny between gears to stop them from spinning when you're trying to torque things down. I tried this to torque the flywheel bolt down (95 ft/lb) and I broke a tooth off the oil pump drive gear ($30 replacement). So don't try that.
When swapping the trannies I swapped all the internal parts (gears, shafts, forks, and drum). The reassembled trannies both bound up. I spent a long time trying to figure out what was wrong. I finally swapped the drums back and they worked. I examined the drums closely and couldn't find anything different about the two, but it appears the drum needs to stay with the case it was meant for.
Old 01-27-2011, 06:23 PM   #89
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
In order to get the primary drive ratio I want, I need the 91 DR250S's clutch basket. So I put in the whole clutch from the 250. Does anyone know if there's a difference between this clutch and the '98 350 kicker's?
Old 01-27-2011, 08:09 PM   #90
Pablo83 OP
Sleep, Wrench, Ride
Pablo83's Avatar
Oddometer: 4,440
Valves
DR350 valve sizes (these are not exact)
intake: 30mm
exhaust: 26.5
DR250S
intake: 28
exhaust: 24.5
Times are GMT -7.   It's 02:59 AM.
