Old 02-03-2011, 11:38 AM   #46
rtwdoug
prominent underachiever
rtwdoug's Avatar
Oddometer: 3,720
Originally Posted by herrhelmet View Post
It's a perfect backup battery because it can sit for up to a year without needed a trickle charger. What bike are you riding?
03 Harley 1200 Dirtster XL/GS
www.motosapiens.org
My bike hotel in Bulgaria. ADVriders get 1st beer free!
rtwdoug is offline   Reply With Quote
Old 02-03-2011, 11:50 AM   #47
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
If you go to
www.testsycl.com
---in the Batteries section, the 6.9 AH has 360 CCA which is more than the OEM and is 1.8 lbs. Would fit into your touring bags and won't leak. Also a $15 ADV disount rebate if you buy one. We can put battery lugs on the cable ends so you don't need connectors.
"Your bike is too heavy" www.motolithium.com TWITTER
herrhelmet is offline   Reply With Quote
Old 02-07-2011, 05:53 AM   #48
Matttys
Matt the Balloon Guy
Matttys's Avatar
Oddometer: 437
I'm looking to use one of these for a DR650 based street tracker project.
How will the lithium ion batteries hold up to charging via a trickle charger? I've got a fairly nice DRS 8 bank charger for AGM/Gel/Standard batteries, but how can I trickle charge the lithium ion batteries. I realize that there is much less of a discharge rate; so would you suggest that there is no need to EVER externally charge these batteries?
Also, you suggest the 4.6 AH unit for my DR650 single?
'04 Bonneville hack, '05 DRZ134SM minimoto, '02 955i Tiger, '08 WR250R, DR650 Street Tracker
Matttys is offline   Reply With Quote
Old 02-07-2011, 06:31 AM   #49
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
I don't know about the DRS 8 bank charger, but charging on a desulfate mode will damage them. Battery Tenders are fine.
These batteries will hold a starting charge for up to 1 year without a charger.
I never leave mine on one. If you have a possible static drain like a digital clock, and leave the bike sitting for a while, it would give some peace of mind.
The 4.6 Ah should be perfect for a DR650. 10% REBATE if you mention ADV rider in online order.
Thanks,
Jim
Old 02-07-2011, 09:32 AM   #50
Matttys
Matttys's Avatar
Oddometer: 437
Thanks,
Jim
Cool. My super 8-Bank charger can desulfate, but that's only if I keep the charge activated overnight. If I turn the power on long enough to charge that battery the desulfate mode won't activate.
10% off. . . . expect an order from me within a few days!
Old 02-08-2011, 09:04 PM   #51
NSFW
ktm's "the tourist"
NSFW's Avatar
Oddometer: 16,688
jim, this is the answer!
i am putting an electric starter on the xr400 and there's no room for a regular size battery.
your batt is the perfect size. i will order once i get all the stuff installed.
NSFW is offline   Reply With Quote
Old 02-23-2011, 06:17 AM   #52
Matttys
Matttys's Avatar
Oddometer: 437
Thanks,
Jim
Jim - I noted ADVrider on the online order, but I was still charged full price. Can you please let me know how the 10% rebate works?
Old 02-23-2011, 08:33 AM   #53
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
Sorry, missed that. I will send you a rebate to your paypal.
Thanks,
Jim
Old 02-23-2011, 11:27 AM   #54
Matttys
Matttys's Avatar
Oddometer: 437
Thanks,
Jim
Paypal $$$ received. Thank you!
Old 04-19-2011, 03:49 AM   #55
Wylie
Back in the saddle again
Wylie's Avatar
Oddometer: 2,234
Nice!
Most excellent! Am I right in thinking that hydrogen is produced while these batteries are charing?
Maybe we could use some of that in the aspiration if I'm correct.
Okay so I'm not Super Man. I'm just the jack of many trades, master of some yet to find and as the world turns that would only be for a matter of time.
Okay, screw it, stop the world I'm getting off.
Wylie is offline   Reply With Quote
Old 04-20-2011, 06:15 AM   #56
kbuckey
Oddometer: 865
Hmm, I'm about to do another longish (3000 miles or so) tour on my DR650 and the current battery is going on 5 years so I'm figuring to change it out. I'm a little leery of brand new technology, but this really looks interesting. Question, since I also commute on the bike (coldest so far 11 degrees F) and sometimes on trips it gets in the 20s, I therefor wear a heated jacket liner and use heated grips as necessary. Um, along with a GPS. On the other hand all my lights are LEDs (including two Solstice 10W) except my headlight, which is HID. I do have a digital voltmeter to monitor the battery. The 4.6 going to work OK for this?
kbuckey is offline   Reply With Quote
Old 04-20-2011, 07:32 AM   #57
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
The 4.6 will work under these conditions and can last well beyond 5 years if you take care of it:
1. When you run all your cold weather gear your stator is able to handle the load without draining the battery, which sounds like it does if you got 5 years out of it.
2. You don't leave anything on without the charging system going...
3. For the real cold weather days, I recommend the quick disconnects and mounting the battery so you could take it inside. I use one on my snowmobile and do this. Never have a problem. I haven't tried one at 11F but at 20F it was a bit slow, but the battery self heats and gets stronger.
The racers who buy these all love the quick disconnects so they can just plug them in when they're ready to race... also if you leave them unplugged you can forget about them for a year without needed a trickle charger.
Jim
Old 04-21-2011, 04:28 PM   #58
herrhelmet OP
A Serious Man
herrhelmet's Avatar
Oddometer: 2,364
6.9 Ah Battery starts Jeep Liberty 3.7L V6
Lots of people are asking if the 6.9 Ah (12 Cell battery) will start a BMW 1200GS...
I don't own one, so I tried it on my Jeep. Started right up. So I now carry one as an emergency jump start when I go off road... in the glove box...!
Yes, the ADV 10% discount applies to all products except the 2.3 Ah which is already 20% off.
Starting tomorrow we will accept most credit cards along with Paypal and checks.
Old 04-21-2011, 04:48 PM   #59
tmotten
Lefthand ride Dutchy
tmotten's Avatar
Oddometer: 2,478
I reckon the 4.6ah would start that car.
tmotten is offline   Reply With Quote
Old 05-01-2011, 12:11 AM   #60
mpanther
KotW - Just Ride!
mpanther's Avatar
Oddometer: 1,036
Would it be possible to get a 2.3ah battery made that is two X two?
I would guess this would have a size of 2" X 2" X 2.75"
Peace in your heart & Light on your soul.
ad·ven·ture n.
1. Participation in exciting or hazardous experiences.
2. An undertaking of a questionable nature.
3. An undertaking of a hazardous nature.
'83 GL650swi "My Little Grey Lady"
'86 LS650 Milady's bike
mpanther is offline   Reply With Quote
Times are GMT -7.   It's 11:18 PM.
