Old 02-01-2011, 04:05 PM   #46
Ian B OP
Fairing Manufacturer
Oddometer: 595
Originally Posted by WoodsTripper View Post
Presumably, since the "KTM Generic" version fits KTM 450s, it will also fit a new Husaberg FE too, right? Hmmm. Could be a tasty addition to give my Berg that ADV look.
Yes, and we do the blue colour.
www.britanniacomposites.com
Ian B is offline   Reply With Quote
Old 02-08-2011, 03:49 PM   #47
AdventureMan
AdventureMan's Avatar
Oddometer: 59
Hi,
your fairing seems to be exactly what I am looking for. I have a few questions:
Will it fit with a steering damper mount? See the pics.
I have also raised the bars by 2" and added som Flexx quad bars. Can you see any reason that the fairing wont fit with this setup?? I am aware that I might have to move the GPS, but will prefer to have it mounted this way and put the OEM instrument on top of the fairing dashboard if the cables are long enough?
Heres some pics of my current setup. As you can see I have the Trailtech X2 lamp (HID). Lights are way better than stock, but not what I want. They are also flimmering when you ride hard on bad surface. How will your lights compare to the X2 HIDs?
And - how do I order? Cant find it on your homepage.
2014 BMW R1200GSAW
2009 KTM 690 Enduro R
2008 KTM 690 Rally Factory Replica
AdventureMan is offline   Reply With Quote
Old 02-08-2011, 05:37 PM   #48
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Originally Posted by AdventureMan View Post
Hi,
It might not be able to handle all those wheelies you do!!
2014 KTM 1190 Adventure R
2011 Victory Cross Country
CHRIS_D is offline   Reply With Quote
Old 02-09-2011, 05:11 PM   #49
Ian B OP
Oddometer: 595
Hi,
There's no reason the fairing won't fit with your setup. You may be able to leave the GPS where it is, but you might want to consider mounting the TT mount directly onto the Lynx dash. However, if you were considering mounting the OEM speedo higher up ( I think I recall that there is enough cable), it's important to let us know when ordering that you want the dash 'undrilled', because the dash normally comes pre-drilled for the unit to sit in the position shown earlier in the thread.
We've never done a 'back to back' with the trailtech lights, but I understand from general consensus that the Lynx lights are better focused, particularly the low beam which is a projector type and gives a very sharp horizontal cutoff and a wide spread.
The Lynx is very solidly mounted, with no elastic straps or anything like that, so you don't get any movement.
This specific Lynx is not on the website quite yet, but it's no problem ordering one from our order form, by just adding in the comments box that it is the new Lynx 690 that you want. Price and upgrades like HID and headlight protectors are exactly the same as all other Lynx's.
We have been really shocked by the level of orders pouring in for this version, so we are currently shipping about 2 weeks from order.
And yes, you can wheelie to hearts content !!
Ian
Old 02-10-2011, 05:10 AM   #50
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Hi Ian,
I didn't know you could order!! I been waiting patiently.
OK now I'm up in arms on what to do.... I have the same GPS set up as ADVman. I like where you currently have the OEM speedo mounted in the dash and would like to mount the ZUMO GPS above it. I'm not stuck using Ranzaco's GPS holder but would like continue to use the Touratech mount for security. I'm afraid if I mount the TT mount directly to the dash (without it fasten to the 1/2" bar) I will lose the capilbility to angle it so it's easily viewable. Any suggestions?
Also is the dash strong enough to hold the GPS or do you need to reinforce it with a bracket from behind?
Thanks!!
Old 02-10-2011, 08:11 AM   #51
Ian B OP
Oddometer: 595
Originally Posted by CHRIS_D View Post
Hi Ian,
Thanks!!
The dash is easily strong enough to mount the GPS, but I understand what you mean about the angle. If it's a key feature for you, it would be quite possible to have the 1/2" rail fabricated with some 'feet' to mount to the dash and then you would retain your variable angle. So the rail would be like a mini towel rail positioned out about an inch from the surface of the dash. As long as the 'feet' were reasonably wide ( say 1-1/2") then the dash would be quite strong enough.
Another solution : If you find that once you have got the 'right' angle (and don't need it to be variable), then you can just pack out the top or bottom mounting points on the GPS mount to get the right angle.
The angle of the dash is likely to be pretty close to the right angle any way.
Old 02-10-2011, 10:24 AM   #52
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Ian,
Thanks for the ideas. I will most likely use solution #2. Once it's set I won't need to mess with it.
My order is placed and I'm looking forward to getting it!!
Old 02-10-2011, 01:48 PM   #53
AdventureMan
Oddometer: 59
Ian,
Chris,
I have the same concerns as you regarding the GPS mount. My Plan B, if I dont use the Renazco mount, is to use this:
http://www.rally-raidproducts.co.uk/...roadbook-mount
bolted to the fairing. (I already have it in the garage)
Its maybe possible to use something like this too http://www.rally-raidproducts.co.uk/...aptor-roadbook if Ians sugestion does not work as expected, but hopefully it will. Its probably better to bolt it straight to the fairing if the result is similiar.
I am probably going to order HID all the way, but will also consider this solution
http://www.advrider.com/forums/showthread.php?t=524638 (post#14) if they are compatible with the fairing. Awesome lights - Bi-xenon.
Ian - what do you think, is it possible to make these lamps fit in your fairing?
2014 BMW R1200GSAW
Old 02-10-2011, 02:13 PM   #54
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Chris,
Damn both those RR mounts would work perfectly IMO. Good job!!
Now if I could only find someone selling them in the states.
Old 02-10-2011, 02:20 PM   #55
Para504
Spam, Spam, bacon & Spam!
Para504's Avatar
Oddometer: 560
You may want to try KTMtwins.com for the bracket; they are in Cali, and carry some of the R-R stuff.
TAT highlights - 2010 http://vimeo.com/13365926
Para504 is offline   Reply With Quote
Old 02-10-2011, 02:23 PM   #56
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Thanks, I already checked, no luck!
I'm sure RR would ship to states but I'm sure it would be costly.
Old 02-10-2011, 02:33 PM   #57
AdventureMan
Oddometer: 59
You may concider this one, but the RR mounts are fare more solid IMO
http://www.touratech-usa.com/Store/1...Mo-KTM-LC8-690
2014 BMW R1200GSAW
Old 02-10-2011, 11:32 PM   #58
rickypanecatyl
SE Asia adventure tours
Oddometer: 1,159
Hey guys - let us know what you think of the Lynx lights compared to the trail tech. If possible take a picture of the low and high beams with each?
rickypanecatyl is online now   Reply With Quote
Old 02-11-2011, 04:30 AM   #59
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
If you get a chance watch the video. You'll see they for some strange reason TT decided to run bracket all way down to the actual handlebar. Thus not making it simple to bolt the bracket on to a flat surface.
CHRIS_D screwed with this post 02-11-2011 at 04:57 AM
Old 02-11-2011, 01:21 PM   #60
CHRIS_D
CHRIS_D's Avatar
Oddometer: 963
Sorry Ian I'm not meaning to clog your thread.....
However I think I finally found a reasonable solution to mount the Touratech GPS holder to your fairing :
It's actually a mount designed for a FJR , but it should fit very nicely above the OEM speedo (and it's even black to blend with the dash ):
Here's the USA Touratech link: http://www.touratech-usa.com/Store/P...JR1300-to-2005
To top it off it's only $43 , which is really cheap when considering it's from Touratech!!
Times are GMT -7.   It's 11:00 PM.
