Old 07-04-2008, 09:20 PM   #1
Burnszilla OP
BurnsMoto.com
Burnszilla's Avatar
Oddometer: 1,345
FuzeBlock Install on a R12GS
Last year I installed a Blue Seas fuse box into the tail of my GS and a few of you guys said it was a stupid idea and "you'll end up moving it some day." Well that day has come. I was looking for a smaller size fuse block that would fit under the seat where I wanted it. I saw the 'behind the tank fuse block' install on 1150GS and thought it could be done on the 1200, but a smaller fuse box would be needed. Along comes the www.fuzeblocks.com.
I first tested with a vertical install of the box but it hit the inside of the top of the seat.
First, I cut a mounting plate out out aluminum.
Then I mounted to the bracket with 3m 2 way tape and the mounting screw. I removed the zip tie as it was not needed.
The only con of the fuzeblock is that the conacts on the back are exposed and short circuits are possible. So, I covered the solders with electric tape.
Burnszilla screwed with this post 07-07-2008 at 03:03 PM
Burnszilla is offline   Reply With Quote
Old 07-05-2008, 06:28 AM   #2
BobFV1
BobFV1's Avatar
Oddometer: 23,806
That's a slick looking unit. Thanks for the pics - looks like a good improvement to you set-up.
BobFV1 is offline   Reply With Quote
Old 07-07-2008, 02:07 PM   #3
ian408
Oh?
ian408's Avatar
Oddometer: 14,607
Very cool. My only comment would be that using a piece of old innertube might be better than the tape--at least it would take longer to wear through
P.S. it's www.fuzeblocks.com
ian408 screwed with this post 07-07-2008 at 02:15 PM
ian408 is offline   Reply With Quote
Old 02-14-2011, 05:38 PM   #4
doc riverz
anatra di seduta
doc riverz's Avatar
Oddometer: 4,353
Hey Burnszilla and/or ian408, have we determinated that the fuzeblocks.com device is the current state of the art in aftermarket fuse blocks for BMW motos?
I ask coz I just found this
In my garage and it needs electrical farkles.
Thanks, guys.
doc riverz is offline   Reply With Quote
Old 02-14-2011, 07:24 PM   #5
sblaylock
Explorer
sblaylock's Avatar
Oddometer: 119
+1 for Fuze Block
There is another thread here talking about fuse blocks for R1200's.
I went with the Fuze Block and would do it again tomorrow.
Scott.
PS Congrats on the new addition.
Scott
06 - BMW R1200GS
28 - BMW R62
36 - BMW R12
07 - BMW G650X Challenge - Gone
sblaylock is offline   Reply With Quote
Old 02-14-2011, 08:15 PM   #6
DualMule
Oddometer: 333
Are you not concerned with water rolling running right through that thing? I just installed the Eastern Beaver unit and I avoided that mounting location for that reason. I ended up installing mine in the tool tray like many others. I couldn't fit my tool roll in there anyway, so it was empty.
DualMule is offline   Reply With Quote
Old 02-15-2011, 01:43 AM   #7
Stressfest
ekki-ekki-pitang
Stressfest's Avatar
Oddometer: 214
Just about to install mine this weekend. Seems like a great piece of kit
Stressfest is offline   Reply With Quote
Old 02-15-2011, 05:18 AM   #8
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 54,490
It really isn't an issue. Guys have been doing it for years on the 1100/1150 bikes.
The only thing I would do different is use liquid rubber tape on the back of the fuzebox instead of regular electrical tape. The regular electrical tape will peal off leaving a sticky mess when it gets hot.
Jim
Old 02-15-2011, 10:11 AM   #9
Northlondoncookie
Beaver hunter
Oddometer: 36
Nice install. I have a low seat on my GS so not sure it would go there. Also good idea to have that there with the rain? Have mine under the tool box. I dremeled out the top part of the tool box and much more room. Very clean.
Northlondoncookie is offline   Reply With Quote
Old 02-15-2011, 10:19 AM   #10
LaurelPerryOnLand
Oddometer: 3,482
I voted with my wallet for:
Your's was a nice install...but this guy also has a nice solution.
http://www.excelcyclewerkes.com/index_files/Page672.htm
http://www.excelcyclewerkes.com/imag..._GSCentech.pdf
LaurelPerryOnLand is offline   Reply With Quote
Old 02-15-2011, 12:49 PM   #11
LVNVGS
LVNVGS's Avatar
Oddometer: 40
+1. I just installed my Eastern Beaver PC-8 2 weeks ago. I'm not the most mechanically inclinded and it was a very easy install (in the tool tray).
LVNVGS is offline   Reply With Quote
Old 02-16-2011, 12:56 AM   #12
1coolbanana
1coolbanana's Avatar
Oddometer: 1,459
Yes, a nice install but I prefer mine away from the elements.
Doesnt get wet, plenty of room to play and proper tools go in a tooltube where they belong
1coolbanana is offline   Reply With Quote
Old 02-16-2011, 01:54 AM   #13
crazyhawk99
Oddometer: 348
Better protection on the back.
Looks like a clean install.
Not to criticize, but I would be very concerned about the electrical tape wearing thru. If it does, you could have big problems and not likely at a convenient time/place.
I recommend insulating it from shorting with something more durable than electrical tape. The inner tube idea isn't bad. Perhaps cutting a piece of flexible teflon cutting board. Cheap and easy to find and holds up well to cutting with a knife, so should be quite resistant for your purpose.
"Sometimes, it's hard to look cool..."
_______________________________________________
Current bikes:
2009 R1200GS
2009 Buell 1125CR
2002 HD Heritage Springer
2004 ZX-10R
2003 SV650
1988 Sporty 883 (cafe project)
Next Bike:
Hmmmm....
crazyhawk99 is offline   Reply With Quote
Old 02-16-2011, 08:04 AM   #14
Aviatordoc
BMW K12S rider
Aviatordoc's Avatar
Oddometer: 420
You know they have a back plate available now from Fuzeblocks?
New units come with a spacer and a plastic back plate.
Aviatordoc is online now   Reply With Quote
Old 08-29-2011, 07:04 AM   #15
hbkramer
Oddometer: 375
fuze bloc
Are these units holding up well?
solder joints ? connection points ? any gotchas ? tips ? i am going to install one like the authors install on the back side of the tank shortly and thought I would ask.
Bruce
HB 05 R12GS,and a few airheads
hbkramer is offline   Reply With Quote
Times are GMT -7.   It's 09:45 AM.
