Old 02-17-2011, 02:26 AM   #61
advNZer?
advNZer?'s Avatar
Oddometer: 2,903
Originally Posted by electric_monk View Post
no.1 The little spring clip that connects the float to the float needle.
no.2 Starter motor bolts
the lh(looking from the rear of the bike) starter motor bolt ,if i have to do it again i will try taking the air cleaner base of first....
aka BMWST?
advNZer? is offline   Reply With Quote
Old 02-17-2011, 02:53 AM   #62
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,131
Originally Posted by MIOB View Post
I have done a number of those jobs on my BMW, but yesterday all I had to do on my CB750 is drop the needles one notch. Hell, pure hell. I love my BMW.
Overhaul just one Honda 4 and you'll be an airhead rider for life.
I hate those things.
Old 02-17-2011, 03:32 AM   #63
darklight79
scaffold builder
Oddometer: 426
cat skinners
[QUOTE=supershaft;15201106]I don't understand why you would need to check that after a rebuild but there is more than one way to skin a cat.
.................Only one way to skin a cat ...Take the fur off.... Some things when it comes to wrenching can be a PITA ..however I did Ford IFS lift kit solo in the drive way ... So when that driveshaft boot on the scooter task came along ....It s all attitude .
darklight79 is offline   Reply With Quote
Old 02-17-2011, 05:40 AM   #64
Screaming Chicken
Screaming Chicken's Avatar
Oddometer: 591
Similarly, all I had to do (a couple of years ago) was replace the main jet in my NX 650. After a few iterations I had the time down to about 90 minutes. Which is a hell of a lot longer than such a job has any right to be on a single cylinder single carb bike.
(It's about time I revived the fscker. It's been sitting for 2 years, the front brake pads have seized on the rotor, and I need to move. I love the big thumper, but for working on I'll have the GS any day.)
'92 R100GSPD
Two Bings to rule them all, Two Bings to ride them,
Two Bings to bring it all and in the twisties grind them.
In the land of Bavaria, where the boxers ride...
(Gandalf the oil-stained)
Screaming Chicken is offline   Reply With Quote
Old 02-17-2011, 06:31 AM   #65
Rucksta
SS Blowhard
Rucksta's Avatar
Oddometer: 2,690
Pushrod Seals
I've only done this job a couple or a few times and not had a problem.
I use two sleeves on the lower studs to push the assembly into place using the nuts.
This stops the tendency of the assembly cocking the seals in the holes.
I do this with heads on rockers off and maintain the tension during rocker assembly before final torque down.
The theory is squeeze it in to its final home and let the seals relax then no further disturbance.
Maybe I just got lucky but I've had no issues with weeping around the seals or base gasket without some sort of impact event to set it off.
My bike is slow but the earth is patient.
Rucksta screwed with this post 02-17-2011 at 07:06 AM Reason: seplilng
Rucksta is offline   Reply With Quote
Times are GMT -7.   It's 06:01 AM.
