Old 02-18-2011, 05:21 PM   #76
R Doug
Recalculating
R Doug's Avatar
Oddometer: 312
Originally Posted by stou View Post
This procedure doesn't work on a 990R. Anyone know if there's a way to set the wheel size on a 2010 990R?
Darn, sorry to hear that. I can confirm the procedure does work on my 2008. I know your 2010 has the same console as my old Super Duke.
-- Doug
R Doug is offline   Reply With Quote
Old 02-18-2011, 07:54 PM   #77
stou
stou's Avatar
Oddometer: 350
I looked at many places on the net and I didn't found nothing about that procedure for the 990R. It bothers me a bit, when I ride with the 19/17 combo, the speedo is a good 10 km/h more (depending on the speed). So it make more km on the odometer. While traveling, it bothers me a lot. It's harder to calculate when I need to refuel.
2010 KTM Adventure 990R - 2012 Ossa TR280i
'87 Honda TLR 200 - '72 Honda CB350K4 - '72 Honda CD175
http://www.stoudesign.com
Montreal to Moab 2008: http://www.advrider.com/forums/showthread.php?t=343166
stou is offline   Reply With Quote
Old 02-18-2011, 10:57 PM   #78
-GUV-
Oddometer: 244
You got some pictures of it with the 19/17 on it that you can put up?
Grant.
-GUV- is online now   Reply With Quote
Old 02-19-2011, 01:44 AM   #79
factory
factory's Avatar
Oddometer: 81
990R dash is the same as the 690, you need to cut a wire to the back of the dash that locks the wheel size. You can then adjust wheel size using the mode and set buttons. I did it on my 690 and worked well.
These are the notes I kept, this is the procedure once you have cut the wire:
*Turn key to "on" and with the meter set to "Trip 1", press and hold "Mode" for 10 sec.
Length xxxx (the 17" circumference) will show up (flashing), press "mode" to increase and "set" to decrease the circumference.
The correct setting for 21" should be 2205.
*Press "mode" and "set" simultanously to set it.
You will need to search the big 690 thread the find which wire to cut, I recall there are pics.
KTM 990 Adventure S
factory is offline   Reply With Quote
Old 02-19-2011, 03:13 AM   #80
stou
stou's Avatar
Oddometer: 350
Thanks for that info, I'll look for that in the 690 threads. That's the firts time i had good info about that, great!!!
Old 02-19-2011, 04:19 AM   #81
-GUV-
Oddometer: 244
Originally Posted by Sobiloff View Post
I read this procedure elsewhere and haven't tried it myself, but I figured I'd pass it on in case you're adventurous enough to try it:
*Remove old Odometer and the connector.
*Cut the wire for pin 18 (should be Brown/Grey for 690E) on the connector.
*Install Odometer
The only thing that the "pin 18" do is lock the Odo from adjusting wheelsize.
This looks like it?
Old 02-19-2011, 04:36 AM   #82
R Doug
Recalculating
R Doug's Avatar
Oddometer: 312
Now that I have been able to sneak in some miles this warm February w/ the new tire/wheel set up, here some some quick thoughts:
* The bike feels more sporty. Paved road corning has greatly improved and the big bike feels like it wants to tip in to every corner. I like that.
* The stock kick stand is too long now and I need *think* about bike placement before leaving it on the side stand. I may look for a shorter after market stand for when I'm using the 19/17 set up.
* Also, the center stand is long now which makes for a little more effort required to get the 990 up. But, I do like the add'l wheel clearance while the bike is on the center stand.
* Given the fact the bike appears to be lower to the ground now w/ the shorter wheels (as evidence by the the effects on the side and center stands), the bike does not feel lower to ground with my modest 28" inseam.
* Regarding the bike being lower to the ground, I wonder when I get into some awesome twisties, will I have less ground clearance when it comes to dragging the pegs? A few hours on WV's finest will let me know that soon enough.
-- Doug
Old 02-19-2011, 07:31 AM   #83
woody's wheel works
Built to Last
woody's wheel works's Avatar
Oddometer: 3,424
side stands...
here's one version that adjusts,,to give you one idea,,it has a 2'' range,,,good for any 17/18/19/21 wheel combination..
,,also has bigger pad...takes less than a minute to adjust
also works great when you carry extra riders and luggage,,,,,
heard you can also get a shorter sidestand off the SM,,,
if you get to touching things,,,you'll be the first one!!!,,,make sure you record it for us all
w....
www.woodyswheelworks.com
......Wanna talk,,,call us
toll free... 1-866-936-0232
Old 02-20-2011, 04:51 AM   #84
stou
stou's Avatar
Oddometer: 350
Originally Posted by -GUV- View Post
This looks like it?
Yesterday I was out skiing, I'll try to look at it today to see if it is the right procedure. Thanks!
Old 02-20-2011, 08:03 AM   #85
stou
stou's Avatar
Oddometer: 350
Grant.
[IMG][/IMG]
Old 02-20-2011, 08:25 AM   #86
stou
stou's Avatar
Oddometer: 350
I don't want to polute this thread, so I folow this discusion on a thread I started few months ago about wheel size setting on the 990R.
http://www.advrider.com/forums/showt...2#post15235012
Old 08-24-2012, 11:18 AM   #87
666
Agnostic and Orange
666's Avatar
Oddometer: 1,316
anybody wants to sell this 19/17 setup? I am starting new job with long commute miles.
2006 KTM 950 ADV; 2006 KTM 525EXC; 2013 Tiger 800 street
Moab Ride Report http://www.advrider.com/forums/showthread.php?t=629423
Dusy Ershim Ride Report http://www.southbayriders.com/forums...ad.php?t=99109
666 is offline   Reply With Quote
Old 08-25-2012, 12:04 PM   #88
R Doug
Recalculating
R Doug's Avatar
Oddometer: 312
My set is for sale.
I sold my Adventure and still have the 19/17 wheels with newish Tourances on them + a spare set of brand new Trail Attacks.
Here's the post:
http://www.advrider.com/forums/showp...4&postcount=33
-- Doug
Old 08-25-2012, 09:04 PM   #89
sstewart
sstewart's Avatar
Oddometer: 1,056
Wheels
Get off here and send me my wheels already.
sstewart is offline   Reply With Quote
Old 08-26-2012, 03:45 AM   #90
R Doug
Recalculating
R Doug's Avatar
Oddometer: 312
-- Doug
Times are GMT -7.   It's 04:12 PM.
