Old 02-19-2011, 11:06 AM   #1
One Less Harley OP
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,695
damned neutral switch again!!!
Yep, yearly leaking neutral switch on the G/S. Replaced it when I had the tranny out then it leaked less than a year later. Replaced it early last year (Max replaced it), now it's leaking again. Looks like I'll be plugging the thing.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-19-2011, 11:41 AM   #2
elmontanero
Practicing...
elmontanero's Avatar
Oddometer: 1,828
Mine was working fine till the rebuild, now no love. And yeah... after the rebuild, with sealant from the builder, leaks.
"And if we have food and covering, with these we shall be content."
elmontanero is offline   Reply With Quote
Old 02-19-2011, 12:33 PM   #3
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,488
I'm plugging mine. Which reminds me, I need to return the one Datchew loaned me.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 02-19-2011, 12:35 PM   #4
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Yes you do. I was wondering where that went. And bring me a slinger if you have any laying around. Not the repops mind you. Those are apparently junk.
datchew is offline   Reply With Quote
Old 02-19-2011, 01:06 PM   #5
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
I had an idea, (yeah, yeah, why didn't it die of loneliness)
Heard it before.
Anyway, if someone here has the computer skills, howzabout we draft a cyber letter of complaint, get a SHITLOAD of pissed off inmates to sign it and I could get it to the right person at BMW.
If for no other reason than to get them to either change their vendor or put pressure on their vendor to fix the fucking switches.
Maybe some language about how the neutral switch is part of the Federally mandate SAFETY Starter cut-out blah blah...
Either way, we could hopefully collect enough signatures to get them (or her)to take notice.
Power in numbers.
I am personally sick of buying switches and will be plugging the very young switch on my bike that pukes oil.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 02-19-2011, 01:26 PM   #6
SUVslayer
SUVslayer's Avatar
Oddometer: 812
Heard it before.
Power in numbers.
I'll sign. I thought I was doing something wrong like over torquing them or something. It's the last oil leak (I think) and I can't seem to fix it.
SUVslayer is offline   Reply With Quote
Old 02-19-2011, 01:29 PM   #7
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
BMW doesn't care Robert. Supplying parts for old obsolete bikes is probably a PITA to them.
My guess is there's some other vendor making repops for them anyway just like Huggett makes the slingers for Vech, Bob's, and MAX.
I've heard over and over about "I like BMW because I can get parts for the old bikes"
I no longer buy that line.
Old 02-19-2011, 02:04 PM   #8
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,830
Anything you can mark up 100% (or more), only stock what normally sells, and make customers wait for it doesn't normally sell much isn't a PITA, but a gift to a retailer. Most dealers know this and don't mind a bit.
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 02-19-2011, 02:11 PM   #9
The Raven
The Raven's Avatar
Oddometer: 4,811
Ok....the neutral switch in the GS looks just like the 4wd switch in my Jeep, and the reverse switch in my 328i with NEITHER leaking......There has to be a tips and trick solution...
The Raven is offline   Reply With Quote
Old 02-19-2011, 02:13 PM   #10
ChromeSux
Plated and screwed
ChromeSux's Avatar
Oddometer: 1,488
Funny this topic has came up again, a few weeks ago mine started leaking for the third time, i have replaced the switch twice in less than 2 years, NO MORE.
I went to Auto zone and bought a 12mm x 1.5pitch bolt, cut it just about 2 threads shorter than the exposed threads that were on the switch, used the crush washer that was on the switch, little high temp RTV and all is well.
I did let the gearbox fluid drain overnight and cleaned the switch hole threads with a Q tip and some carb cleaner, damn sure aint leaking now.
On the R100GS you have to pull the clutch in to start it any way so no big loss not having the switch, just no light for N.
On a side note just today as i was savoring the moment of defeating that oil leak and i discovered a new one starting, Pushrod tube seals, i looked all over the bike to see if it had made by AMF Harley Davidson but it doesnt, it just says BMW.
ChromeSux screwed with this post 02-19-2011 at 02:20 PM
ChromeSux is online now   Reply With Quote
Old 02-19-2011, 02:42 PM   #11
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Are you implying that the dealers are the ones making the huge mark-up?
NOT!
the average profit margin for BMW parts is around 31%
It used to be around 40% when I started working there 16 years ago, but has diminished greatly.
www.wirewerkes.com
Old 02-19-2011, 04:58 PM   #12
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
I got to the same mind as you Chromesux. I replaced it 1 last time. When this one leaks, I'm plugging it with my aluminum bolt (it's an aluminum case after all) and a crush washer or nitrile washer.
I don't really find much use for it anyway as I have gotten in the habit of knowing by speed and pitch of the motor RPM what gear I'm in.
My neutral safety connection was killed long ago, so the switch serves only for the indicator light and seeing that little green light simply isn't worth the $.
Old 02-19-2011, 05:05 PM   #13
One Less Harley OP
Oddometer: 4,695
I was looking though my extra parts and i don't believe it there are three screwed up switches in the box!!! Dang I didn't know I'd had that many, depressing!!!
CS is right the bolt is a 12x1.5
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 02-19-2011, 08:54 PM   #14
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,131
I wonder if there's a way to re-engineer these things so they're rebuildable with a seal, rather than being crimped together? For the $30 or $40 they want for the dumb things, it would be worth it.
Mine started leaking a while back and leaves a puddle in the garage where it's parked. I've just been putting up with the mess cause I don't want to hassle with it. Don't know how old it is since the bike is new to me.
Old 02-19-2011, 08:59 PM   #15
One Less Harley OP
Oddometer: 4,695
Maybe I should give the crimp a couple more whacks with a hammer. I've noticed on a couple of the leaking switches that the plastic body rotates in the Al housing. Might be worth a shot, might tighten up the o-ring seal in the body. I'll take one of the bad ones apart to see how it's put together.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 05:03 AM.
