Old 02-24-2011, 01:57 PM   #1
BMW-K OP
F800GS FTW!
BMW-K's Avatar
Oddometer: 1,515
Woody's 21" vs OEM 19"
So, I won't go into details but I basically destroyed the cast rims on my GS last weekend. I will say I had a BLAST doing it though!
Now I need to replace my rims. The cost of OEM's vs. Woody's is basically the same. I don't do a whole lot of dirt and at 5'8" a 21/18 combo really isn't going to do me favors.
So, I'm going to stick with the 19/17 sizes but with one question: OEM's vs. Woody's.
Alternately stated: Tubes vs. Tubless. 'Cuz the Woody's need a tube on the front, minimum. I'm not big on tubes...but the BLING factor of the Woody's is darn hard to avoid!
One Day I will do the TAT. Not sure if that makes any difference.
Thoughts?
2010 F800GS Anniversary - a return to Eden
2011 Yamaha WR250R, 2012 Ducati Monster
2007 R1200GS (Sold)
IBA # 20880. STFU and Ride.
BMW-K screwed with this post 04-30-2011 at 08:19 AM Reason: Request by Woody Himself. And it better defines the thread.
BMW-K is offline   Reply With Quote
Old 02-24-2011, 02:08 PM   #2
bzrider
bzrider's Avatar
Oddometer: 2,631
Thoughts?
i just did the same i went with 21 front tubless less than oem, plus oem had to be ordered from germany.ZACH at woodies , answered all my questions and put a rush on building the wheel
bzrider screwed with this post 02-24-2011 at 07:11 PM
bzrider is offline   Reply With Quote
Old 02-24-2011, 05:10 PM   #3
Pir8te
over forty victim of fate
Pir8te's Avatar
Oddometer: 1,449
Woody can build tubeless might want to check with him over in the vendors section
In the end, it's not the years in your life that count. It's the life in your years.
Abraham Lincoln
Pir8te is offline   Reply With Quote
Old 02-24-2011, 05:39 PM   #4
SCflyer
SCflyer's Avatar
Oddometer: 1,657
I got a set 19/17 done, superlace - billet hub, excel wheels. Per my conversations with Woody and Zack, they cannot make a 21" wheel tubeless (this the need to order a special built - HP2 front??) but can the 19" and 17" as I have had them do to both mine. Mounted the Tourances, sealed up easy with a bestrest minipump. I had no problems with setting the bead. For the rear they use a 4.00 width rim vs 4.25 as BMW does but it make no difference. Woody said that's the norm and BMW is the oddball on this. If you want to reduce the cost and delivery a bit, call them, as they may have access to a stock set that they can true up or may already have some on their site for sale. If you change your own tires with irons I'd recommend either stay with silver or be sure to use leather or similar when mounting to prevent the scratching. I went with the black (little extra $$ as they have to have these particular wheels colored) to be similar to stock. The can do either a very shiny (spend some time buffing them up) or the standard which is about the same as the OEM black wheels.
"Not all those who wander are lost" J.R.R. Tolkien
SCflyer is offline   Reply With Quote
Old 02-24-2011, 07:01 PM   #5
OConnor
Bad juju
OConnor's Avatar
Oddometer: 3,769
4.25" was supermoto standard width before the OEM SM bikes started showing up.
2013 Husky TR650
2008 GSX1250N
1990 HD Ultra Classic
2000 SV650 track bike
1971 CB175 vintage racer inabox
OConnor is online now   Reply With Quote
Old 02-24-2011, 07:11 PM   #6
Schlug
JockeyfullofBourbon
Schlug's Avatar
Oddometer: 7,457
You're considering doing the TAT on the 1200 and you don't think you want a 21 up front?
"So what makes this protest different is that you're set to die, Bobby?"
--May well come to that.
"You start a hunger strike to protest for what you believe in. You don't start already determined to die or am I missing somethin' here?"
-- It's in their hands. Our message is clear. They're seeing our determination.
Schlug is offline   Reply With Quote
Old 02-24-2011, 07:43 PM   #7
BMW-K OP
F800GS FTW!
BMW-K's Avatar
Oddometer: 1,515
No. More like I'm not sure the 21 is necessaray. I've seen several GS's do the TAT on 19/17's.
If it's an absolute necessity, then that changes things. Kinda like the Haul Road - there's no need for a 21 at all. Fact is, if it's dry out you can run the Haul Road on Slicks.
2007 R1200GS (Sold)
Old 02-24-2011, 07:52 PM   #8
libratrades
libratrades
libratrades's Avatar
Oddometer: 93
local set
I had Woody build a set for my 09 GS. Black with his billet hubs, stainless spokes superlaced. I am in Orange County if you want to see what the set looks like. I have the factory spoked wheels as well to run more street oriented tires as well. Just pm me.
libratrades is offline   Reply With Quote
Old 02-24-2011, 08:01 PM   #9
hasenwerk
hasenwerk's Avatar
Oddometer: 1,342
Thoughts?
I think it is all what you are looking for. For the front, if I had to buy new I would go 21" - just because of the better off road abilities and the fact that a 90/90 21" is much cheaper than a 19" front - the old R100 / R80 GS had 21" as does the F800 - so that speaks some merit of the 21" - tubeless can most certainly be done using a R100 rim but they are not nearly as strong as the Excel rim.
The 17" rear is the way to go - I considered the 18" for my 1100 GS and my 30" inseam and the good choice of 17" rubber made me stay with 17"
All that being said I have a Woody's 21" front and an OE 17" rear on my bike - 90/90 21 on the front and 140/80 17 on the rear - tubes on both ends. I am happy with the whole setup!
David Marshall - Quesnel, BC, Canada - fastforward.ca
2006 BMW F650 "YZ" Dakar | 2013 BMW G650 "YZ" Sertao
hasenwerk is offline   Reply With Quote
Old 02-24-2011, 09:28 PM   #10
mtncrawler
mtncrawler's Avatar
Oddometer: 1,193
I have an 09' too. Have considered a second set from Woody as well. Did you do 21/17 or 19/17? or other?
If you get bored it would be nice to see both sets of your wheels side by side.
2007 BMW 650 XChallenge..
2009 BMW R1200 GSA..(Gone.. )
2004 BMW R1150 GSA (Gone.. )
"You think dogs will not be in heaven? I tell you, they will be there long before any of us." Robert Louis Stevenson
mtncrawler is offline   Reply With Quote
Old 02-25-2011, 11:35 AM   #11
libratrades
libratrades
Oddometer: 93
19/17
I did the 19/17. But probably going to also order the 21 as well. Send me a pm with your email address. I will send you the pictures.
Old 02-25-2011, 12:08 PM   #12
mtncrawler
mtncrawler's Avatar
Oddometer: 1,193
Thanks LT - Pm'ed ya...
Old 02-25-2011, 12:23 PM   #13
rider1150gsadv
Fl Keys Fishing Guide
rider1150gsadv's Avatar
Oddometer: 5,914
Wicked
I can confirm that, as I did Haul road on the stock GS rims and Bridgestone 501/502's. Most of the TAT is doable with the big bike too, as long as you keep an eye on the weather. You know the 'pig' likes rolling in deep mud a bit.....
rider1150gsadv is offline   Reply With Quote
Old 02-25-2011, 07:17 PM   #14
LTCOliverNorth
Peeping Tom
LTCOliverNorth's Avatar
Oddometer: 786
How much was your set of Wheels?
2007 BMW G650X Challenge
2005 BMW R1200GS
2002 Ural Patrol T
LTCOliverNorth is offline   Reply With Quote
Old 02-26-2011, 08:01 AM   #15
ROAD DAMAGE
Oddometer: 1,117
Cast Wheels
Hey BMW-K
OK, You have to tell us how you thrashed a pair of cast wheels. Were you jumpin the pig? Come on, just a hint, so none of us inmates make the same mistake.
You can find some smokin' deals out there if you're not set on Woodys or new OEM ----- and if you have some time to shop. I bought a pefect set of cast wheels this month for $700, including brake rotors. I saw another pair that went for $450 this month. I missed them by hours. I've got a pal who bought a spoked set for $800 last year.
As far as bling, I'm sending my new (used) cast wheels to Woody to powdercoat them ----- RED. Maybe those red wheels will make my GSA run like a DUCATI! Rob
Formerly known as: Routt County Rob
ROAD DAMAGE is offline   Reply With Quote
Times are GMT -7.   It's 03:05 PM.
