Old 02-25-2011, 10:55 AM   #1
rudolf35 OP
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 796
Question Airhead pushrod tube seals
This might be a silly question but why does one need to use a tool to seat the pushrod tube seal with a older airhead? I know I can make the tool with a 1/2" pipe but the reason escapes me - enlighten me.
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 02-25-2011, 11:45 AM   #2
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,559
I've never needed a tool for my seals.
crazydrummerdude is offline   Reply With Quote
Old 02-25-2011, 12:28 PM   #3
squiffynimrod
maximum shrinkage
squiffynimrod's Avatar
Oddometer: 1,212
Wouldn't that be the metal collar (?) on the older PRT's that you could cinch down a bit if they were weeping? Newer PRT's had a brazed collar that if you tapped them would break and leak even more. Is this for the 71?
CLICK THIS THREAD
http://advrider.com/forums/showthread.php?t=1017669
CLICK IT!
BECAUSE IT'S SECRET SANTA TIME!!
squiffynimrod is online now   Reply With Quote
Old 02-25-2011, 01:15 PM   #4
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,686
That's always been a very temporary fix at best. Spending a few bucks and a morning replacing the seals is a better solution. No special tools required, and it doesn't take very long at all.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 02-25-2011, 01:48 PM   #5
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 982
sent you a pm. Please check...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 02-25-2011, 04:26 PM   #6
Hawk Medicine
Coyote's Brother
Oddometer: 3,303
Temporary fix? Yes but it's also a reasonable solution to a frequent problem.
I've been able to reseal my PR seals using a seal setting tool and a hammer on many occasions and thereby extend the usefulness of my old seals for more than a year. It took maybe 1/2 hour to make the tool, the materials cost was zero, c clean bike? Priceless!.
I learned the trick from a trained BMW mechanic, who would always tighten up his customers seals during a regular service stop, if they showed need of it. That way, his customers could put that job off until it was time to schedule more extensive repairs, thus saving them time and money, while it also saved him time and made him money!
Nothing wrong with that!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 02-25-2011, 05:10 PM   #7
4ad
ochlacrat
4ad's Avatar
Oddometer: 2,592
These seals wear from constant expansion and contraction during the heat cycles of the engine. If you compare a new seal to an old one you'll see the ridges on the base are worn completely smooth on the old one....no amount of hammering will do much good for long and MAY even pull the pushrod tube from the cylinder....a pain to replace....and involves an angry wife wondering what the f&%k a cylinder is doing baking in her oven and stinking up her kitchen.
Besides...it's bad karma to hammer on an airhead.
Go ahead and change em...takes a 1/2 hr per side..and thats if you're slow.
This was all fun banter until 4ad posted a pic of a rapist/murderer.- GP640
4ad screwed with this post 02-26-2011 at 02:41 PM
4ad is offline   Reply With Quote
Old 02-25-2011, 07:01 PM   #8
durtwurm
Talented Amateur
durtwurm's Avatar
Oddometer: 4,408
New seals or old, put a hose clamp on the tube next to the seal. It helps keep them in place and prevents weeping of oil.
Go far or stay home.
durtwurm is offline   Reply With Quote
Old 02-25-2011, 07:53 PM   #9
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,355
I have been rewarded with years of service from seals that had been reseated. Like has been said, you can put the replacements in when you are doing more extensive service. If reseating doesn't stop the leaking, you are not out anything, go ahead and change them.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 02-25-2011, 08:20 PM   #10
Hawk Medicine
Coyote's Brother
Oddometer: 3,303
How are you going to remove a push rod tube from the jug by resetting the seals? You're putting pressure on a non-fixed keeper that presses against the seal but holds it's position through friction. The tube doesn't move with the keeper because they're not firmly attached to one another and you're only moving the keeper 1/16" to 1/8" at most anyway.
Still, Your statement got me to thinking, so I went out to the garage and looked some R90 and R100 jugs. My conclusion is that it's simply not possible to hammer or press a push a rod tube, out of a jug, while the jug is bolted to the engine. Even if the tube was loose you couldn't do it because the push rod tubes are too long and even if they weren't, the lifters and cam are directly in the path of extraction.
I'm not making this up and I'm not trying to make this an argument... Please go look at some Airhead Jugs and explain how your scenario could be possible.
As an aside: Last Spring my pro Airhead mechanic and I both tried hammering a correctly installed SS push-rod tube, out of a cold jug and we found it impossible to do. Those SS tubes go in so darned tight that you'd destroy the tube, the jug or both before you got em out. Also, with the spacers fixed on those tubes, you cant reset the seals with em anyway.
Hawkdude
Old 02-25-2011, 08:45 PM   #11
fishkens
Further...
Oddometer: 5,147
Folks, I may have missed this but it's important to stress that using a tool to hammer in the push-rod seal collar only applies to what, pre-1977??? bikes. After 1976??? the collars were brazed in place and hammering on them will make things worse.
I believe that tapping in those collars was a reasonable solution on earlier bikes but no solution at all on later bikes.
I know some of you know the precise dates so I'll leave clarification to yous.
I just don't want anyone with a late model airhead thinking they can resolve pushrod tube seal seeping with a hammer. For those bikes the ONLY solution is seal replacement.
Am I wrong?
fishkens is offline   Reply With Quote
Old 02-25-2011, 09:25 PM   #12
Yarddog
Oddometer: 322
I didn't use a tool...I just took some sage advice from more learned folks than I and laid some black RTV on em and snugged everything down...works fine...
Yarddog is offline   Reply With Quote
Old 02-25-2011, 10:14 PM   #13
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 3,406
This is quite simple. The push rod tube is pressed into the cylinder on all 1970-1995 Airhead Boxers. Always give them a little tap after at the collar after you have rebuilt your top end. Push rod seals and the sealing area should never ever have any sealant or oil when the are being installed. As the rubber dries up and shrinks you will need to do this again. I have also had success when they weep cleaning the area with brake clean very well and tapping them in.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
bmweuro is offline   Reply With Quote
Old 02-25-2011, 10:21 PM   #14
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,968
Funny you should say that, since the advice I got fifteen or twenty years ago was to grease them up so they slide on the tube. Grease them all over.
So I've used Silicon grease since it's most compatable with rubber and plastics and doesn't dry them out. The ones I've done this way seal and don't dry up later - I never have to mess with them again.
I agree not to use sealant, it doesn't work. And it's a total bitch to clean up next time around.
Old 02-25-2011, 10:34 PM   #15
bmweuro
Mad Scientist
bmweuro's Avatar
Oddometer: 3,406
Interesting. I was edgimicated 25 years ago by old German dudes and they always said clean and dry.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Times are GMT -7.   It's 06:11 PM.
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
