Old 02-28-2011, 06:10 AM   #16
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,502
Originally Posted by Reryder View Post
Last time I changed the chain on my 81 R100RS I stumbled over a new trick that makes it easier.
Those single chains are really quick and easy to do. It's the duplex chains that are a pain in the arse.
Rob Farmer is offline   Reply With Quote
Old 02-28-2011, 09:08 AM   #17
The Raven
The Raven's Avatar
Oddometer: 4,811
Small zip tie to hold them together while you insert the ML...
The Raven is offline   Reply With Quote
Old 02-28-2011, 10:10 AM   #18
brentde3 OP
Should be outside
brentde3's Avatar
Oddometer: 545
Thank you all for your very helpful advice.
I've got some parts on order and I'm ready to dive in when they get here...
If anyone's interested, I ordered a kit from motobins:
http://www.motobins.co.uk/bmw-parts....20valve%20Twin
Click "engine parts" and then in the drop down menus click "timing chain kits." The whole shebang for $65ish, depending on the exchange rate when you click "buy."
2012 Honda NC700X ; '90 PW50
IBA# 49512
brentde3 is offline   Reply With Quote
Old 02-28-2011, 12:14 PM   #19
r2adv
r2adv's Avatar
Oddometer: 526
Sprocket
Make sure you look at the sprocket carefully. I took my chain off and noticed some significant wear on the upper sprocket.
Note the worn teeth on the old one - right.
Horizontally opposed to a vertical twin world
R12GSA, R100 GSPD, R80G/S, R75/5, R90S
r2adv is offline   Reply With Quote
Old 02-28-2011, 12:28 PM   #20
supershaft
Oddometer: 9,110
That is a very good photo of a very worn sprocket. To a somewhat lesser extent usually, I see worn crank sprockets like that almost every time I replace a chain. I have never seen a worn simplex cam sprocket myself although I did see a picture of one on the net. I see them on duplex setups about half the time. The duplex setups just don't wear as well for some reason.
Old 02-28-2011, 12:32 PM   #21
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Thanks for that.
I'm due on my 89GS and I was wondering if I had to take it all apart before knowing what to order.
datchew is offline   Reply With Quote
Old 02-28-2011, 04:46 PM   #22
brentde3 OP
Should be outside
brentde3's Avatar
Oddometer: 545
Do you usually see the same problem with the lower sprocket? And, is it a good idea to just order the sprocket(s), or tear it down and see exactly what the condition is?
IBA# 49512
Old 03-01-2011, 06:41 PM   #23
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,399
Same trick of putting the old link in from the front to hold the chain together while you fiddle the new link in from the rear would work on a duplex too.
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Old 03-01-2011, 07:05 PM   #24
Carrizojim
Still stumblin along
Oddometer: 68
I did the double row chain on my '77 R100/7 without much trouble. My sprockets were in good shape, I didn't want to remove them (and I didn't have any pullers). So I cut the chain with a cutting wheel and installed the new chain and master link. I did replace the tensioner assy... I didn't have any real trouble. I have put about 10k miles on it since...
I'm on bike bike number 20 something, I think I lost count. '77 R100/7
Carrizojim is offline   Reply With Quote
Old 03-01-2011, 08:18 PM   #25
fishkens
Further...
Oddometer: 5,147
It seems the bolt cutter solution might be a preferred approach to avoid sending cutting debris places where it may get washed into the sump? (I guess that's a question.)
fishkens is offline   Reply With Quote
Old 03-02-2011, 08:52 AM   #26
Carrizojim
Oddometer: 68
Yes, that would be preferred, I plugged openings and then washed everything down before assembling and closing things up. I wrapped up the upper bearing before cutting.
Old 03-03-2011, 08:16 AM   #27
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,472
The A#1 chain breaker! Just used it on my dr 650 drive chain also. For the double row chain even a large bolt cutter like this won't cut all the way back. You need to cut a gap in the first row of chain and then reach in to get the back links.
JT
www.northwoodsairheads.com
www.jefftrappwindsors.com
"Between two explanations, choose the clearest; between two forms,
the most elementary; between two expressions, the shortest."
Between two motorcycles the simplest (DW)
Eugeni d' Ors (1881-1954); Spanish writer.
jtwind is offline   Reply With Quote
Old 03-03-2011, 08:27 AM   #28
brentde3 OP
Should be outside
brentde3's Avatar
Oddometer: 545
I want to build a table like that! Any info?
IBA# 49512
Old 03-03-2011, 08:38 AM   #29
jtwind
Wisconsin Airhead
jtwind's Avatar
Oddometer: 3,472
No that is r2adv's table. He posted the photo of the sprockets earlier in this thread. I'm sure he'll tell you what's up if you PM him or maybe he'll see this. But in general what you see is what you get. I think they are going to trim the side 2x's so there is more access.
JT
Old 03-03-2011, 02:45 PM   #30
Hawk Medicine
Coyote's Brother
Oddometer: 3,302
I've been cutting my old timing chains out using bolt/chain cutters for years.
I got to the point where I could swap a /6 chain at night on the back patio, using a trouble light.
Once you've done it two or three times, timing chains are a snap. Not fun, but you know what I mean!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Times are GMT -7.   It's 02:11 AM.
