Old 03-03-2011, 08:00 PM   #61
BackCountryCruizer
Gnarled Adventurer
BackCountryCruizer's Avatar
Oddometer: 440
Touratech GPS mount
Here's what I did. I had a bar clamp mount for my GPS. I used the straps on the back side for more support. I attached the relays for the lights to the bottom bolts.I have 30mm bar risers and everything fit with some minor tweaking. I left the threaded longer riser blots installed in case I want to remount the bar for a roll chart. The angle of the dash works for me both sitting and standing so bolted solid should be okay.
Four wheels move the body
Two wheels move the soul!
http://www.youtube.com/user/650tom
BackCountryCruizer screwed with this post 03-03-2011 at 08:11 PM
BackCountryCruizer is offline   Reply With Quote
Old 03-04-2011, 10:14 AM   #62
GiMoto Canada
KTM Submarine Capt.
GiMoto Canada's Avatar
Oddometer: 50
Looks great! Can you post a larger version of the photo in the top left?
I will be running a 2 1/4" bar riser above the current bar clamps. Do you see any issues with this height based on your install? I spend most of my time standing and I will be mounting my GPS in the same fashion...
http://www.roxspeedfx.com/cgi-bin/cart/showitems.cgi?subcat_id=269
Eat Sleep Ride Repeat
GiMoto Canada is offline   Reply With Quote
Old 03-04-2011, 11:29 AM   #63
Ian B OP
Fairing Manufacturer
Oddometer: 589
I don't think there would be any issues with this riser, except that you may block vision of the speedo on the odd occasion that you sit down !
Ian
www.britanniacomposites.com
Ian B is offline   Reply With Quote
Old 03-04-2011, 06:52 PM   #64
BackCountryCruizer
Gnarled Adventurer
Oddometer: 440
Dash back side
Here's the photo larger. I've got more if this doesn't show what you want to see. I did have to do some lever placement adjustments with the 30mm (~1 1/4") of rise. The front brake hose could give you some issues where it goes through the dash. I ended up having to loosen the banjo bolt on the lever and rotate the hose once the brake lever was where I wanted it on the handle bar. I think if you were to rotate the brake line around so it's coming out on the bottom, 6 o'clock position, you should be okay. I have mine at about the 1 o'clock position. It just clears the instruments and this was the only place it cleared everywhere.
Old 03-04-2011, 06:55 PM   #65
BackCountryCruizer
Gnarled Adventurer
Oddometer: 440
Wrong photo?
I just reread you query. I think I posted the wrong photo?
Old 03-04-2011, 08:32 PM   #66
GiMoto Canada
KTM Submarine Capt.
Oddometer: 50
BackCountryCruizer, that was perfect! Thanks...
Have you had a chance to ride with it yet? I take it you have a HID and a normal H7 high beam. Can you provide any real world feedback?
Thanks again...
Old 03-05-2011, 07:54 AM   #67
BackCountryCruizer
Gnarled Adventurer
Oddometer: 440
Thanks again...
I was hoping to get out this weekend but everyone around me has been sick the past couple of weeks. I thought I'd be the lucky one and not catch the bug. I woke up sick this morning so I'm no riding for me this weekend. Damn!! Once I get out for a ride I will post my impressions.
Old 03-07-2011, 09:52 PM   #68
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,672
I like that Lynx decal. Where did you get it?
Mr. Fisherman is offline   Reply With Quote
Old 03-07-2011, 10:57 PM   #69
Ian B OP
Oddometer: 589
Email me with a reminder of your address and I'll send you one or two
Cheers Ian
Old 03-10-2011, 12:03 AM   #70
toowheels
on a mission...
toowheels's Avatar
Oddometer: 963
Thanks again...
Hi GiMoto!
How's it goin?
I'm pretty sure you'll be happy with it!
When I met you at the GS Challenge @ RM House I had Ian's Phoenix fairing on the KLR (same lights as this Lynx) and it was great! A huge improvement. I was running HID low and the Halogen high. The spread on the low beam is really even and wide and the high beam throws way down the road...or trail.
I now have his Mirage 2 on my F8GS and it's also great (that one is no lights though, just fairing, windscreen and dashboard).
Take care and see you out there!
Dave
Moto Overland [MOD] -Skid Plates, Top racks, Tool Boxes etc for Adventure bikes
www.motooverland.com
toowheels is offline   Reply With Quote
Old 03-10-2011, 08:22 PM   #71
GiMoto Canada
KTM Submarine Capt.
Oddometer: 50
Originally Posted by toowheels View Post
Hi GiMoto!
How's it goin?
Dave
Thanks Dave! Just waiting for the tax return and the order will be placed. Will be doing the GS Challenge again, try to make it out if you get a chance.
Old 03-18-2011, 07:40 AM   #72
mtnrwild
Ramjet
Oddometer: 13
New Lynx
Ride report and pictures of the Lynx.
I have to say Ian is super to work with, and I would highly recommend both this fairing and his support.
It turned out to be a nice install with both HID high and low beams.
Night riding will be so much safer now. You can really see much better than stock and even better than the X2 lights this replaced.
The protection of the fairing makes this bike into a comfortable long distance traveler. With the windshield down, the air flows by you with out much turbulence. Aerodynamically much cleaner... triple digit comes on a lot quicker
With the windshield up, makes for a comfortable ride in cold weather.
Last weekend went for a 250 mile ride in the mountains with temps 35 - 45 deg. 1/2 was pavement, the rest back country dirt, mud and snow.
With out the Lynx, this ride would not of been as much fun
Here are a few pic's. fully dressed and naked.
mtnrwild is offline   Reply With Quote
Old 03-18-2011, 07:42 AM   #73
mtnrwild
Ramjet
Oddometer: 13
Fully dressed and ready for the long tour.
Old 03-18-2011, 07:44 AM   #74
mtnrwild
Ramjet
Oddometer: 13
Front view
Old 03-18-2011, 08:03 PM   #75
ridepjride
Migrant
ridepjride's Avatar
Oddometer: 308
What is the size of the rider...height and inseam...and what tires are those?
ridepjride is offline   Reply With Quote
Times are GMT -7.   It's 01:26 PM.
