Old 03-08-2011, 12:46 PM   #1
mario33 OP
Howling around...
mario33's Avatar
Oddometer: 145
Eh? TT locking oilf filler cap - removal ?
I lost both keys for Touratech locking oil filler cap in my F8GS. And, guess what, I cant open it ! Anyone got similar problem and managed to open it WITHOUT KEYS ? Tried to dismantle it but with no luck (removing lock does not help much)... TT offered no help so far...
HELP ! As I cant use my bike
mario33 is offline   Reply With Quote
Old 03-08-2011, 01:08 PM   #2
Numb
Oddometer: 190
does it have pieces that secure it inside the filler neck (like a door lock that has pieces that extend when locked to keep it from being removed), or does the locking mechanism keep it from being removed by allowing the top to spin freely unless the key is used?
if the top just spins freely without the key inserted, you may be able to drill through that top part and into the portion that is in the threads of the filler neck - then insert a screw or something strong enough to "lock" the two halves together (free spinning outer part, and the rest that is in the filler neck) so you can remove it
just an idea...
Numb is offline   Reply With Quote
Old 03-08-2011, 03:08 PM   #3
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,764
Get a locksmith...
Cutting into this thing and potentially getting metal chips in your engine sounds like a bad idea.
EnderTheX is offline   Reply With Quote
Old 03-08-2011, 03:11 PM   #4
lmclamore
Citation Collector
lmclamore's Avatar
Oddometer: 412
Originally Posted by EnderTheX View Post
Get a locksmith...
+1 (or -1 as the case may be)
It would be really hard to ensure nothing falls into the sump.
"An expert is someone who has made every mistake possible within a very narrow field of inquiry"
-Niels Bohr
lmclamore is offline   Reply With Quote
Old 03-08-2011, 03:40 PM   #5
bumbee800
Oddometer: 67
take it to a lock smith
Just take the lock to a lock smith to get a new key made or take the entire bike to them if the lock is still attached to the bike. A good locksmith should be able to make you a new key. Hopefully you have not fuped the lock by taking it apart.
bumbee800 is online now   Reply With Quote
Old 03-08-2011, 06:32 PM   #6
EnderTheX
Drunken Squirrel
EnderTheX's Avatar
Oddometer: 2,764
In my area many locksmiths will come to you and make a key on the spot too
Old 03-09-2011, 04:34 AM   #7
JRWooden
Oddometer: 4,267
The answer awaits in the later posts of this thread:
http://f800riders.org/forum/showthre...r-cap-dipstick
Simple to remove once you know the trick
Old 03-09-2011, 06:25 AM   #8
Numb
Oddometer: 190
bah, cant' be that thick of metal - drill enough to get a self tapping screw going (if the design is the free spinning top).
Old 03-09-2011, 08:38 AM   #9
inmate-n00b
Ciao, Marco
inmate-n00b's Avatar
Oddometer: 1,006
are you able to see a serial number on the lock?
i know for some things, like givi bags, you can buy spare keys based on the serial number on the lock......
inmate-n00b is offline   Reply With Quote
Old 12-07-2012, 03:34 PM   #10
fractalsource
fractalsource's Avatar
Oddometer: 90
Nothing LOCKING about this cap.
What a waste of money! What a waste of money! What a waste of money!
I just got one as a gift...
- I screwed it in lightly. Locked it.
- Then reached down under the spinning cap and unscrewed the stationary dip stick cap, with my fingers!
And my oil filler port was open - for anyone! - Is this a novelty?
Someone can easily get into this oil filler port.
What a joke.
If yours is on tighter, use a adjustable end wrench and simply unscrew the non spinning part of the cap.
I suppose it could fool the average bozo, in a hurry, to do some tampering, on the sly.
There is nothing LOCKING about this filler cap in my opinion.
THE CENTER FOR LAND USE INTERPRETATION http://clui.org/ludb
Earthquake, Weather, Radiation LINKS
http://sincedutch.wordpress.com/1ear...diation-links/
fractalsource is offline   Reply With Quote
Old 12-07-2012, 04:16 PM   #11
Casejeep
Casejeep's Avatar
Oddometer: 736
Yes the whole idea seems like a wait of brain space. if your putting a lock on your oil filter... what about them steeling your GPS, wheel, or you.....
MY F800 GS Build
Casejeep is offline   Reply With Quote
Old 12-09-2012, 03:42 AM   #12
MikeMike
MikeMike's Avatar
Oddometer: 4,150
First, don't listen to anyone who doesn't own one of these damn things.
Locksmith, serial numbers, forget about it. I did it already so you can learn from my visit to Senor Locksmith here and save your money!
JR has the right idea, read my write up about it and you will understand the workings of it.
The fix is very simple when you understand how it works.
Take a look at the area of the locking cap that sits flush with the hole. That part can be grasped with a pair of pliers and you simply turn it and it will come out.
If you still have difficulty, send me a PM and I will help you.
As for anyone else contemplating the purchase of this item, think long and hard before wasting your money.
I doubt I would even sell mine to someone used.
Times are GMT -7.   It's 02:45 PM.
