03-02-2011, 03:02 AM
#46 |
Oddometer: 1,653
my faves are all the race bikes...
pursangs, astros, sherpa s... the later sherpa t's (like 198's) were their best trials bikes... the frontera's were probably their best enduros... i still have a bunch more to build - i'm in the middle of a 134 project, but have to build an early lobito 125 that i'm putting a 167 motor in and making a street bike out of it...should be a rocket... and i have 2 more 67's and 2 68's to do.. i'm always looking for parts bikes to cobble together...
current bikes 07 gasgas xc300-94 duc 900ss-86 morini camel (2)-84 IT200-83 IT175-78 guzzi lm1-77 pursang 250-76 morini 3 1/2 strada-76 frankentaco pursang 200-74 frankentaco pursang 200-74 morini 3 1/2 sport-74 mz ts250/0-74 puch 175 (3)-73 can-am 175tnt-71 guzzi frankeneldo-71 ossa Stiletto-70 frankentaco sherpa s(2)-66 morini corsarino(2)-63 morini corsaro + many more |
03-02-2011, 09:36 AM
#47 | |
Oddometer: 295
Dave |
03-05-2011, 06:21 PM
#48 |
Oddometer: 262
The weather has been cold and wet, but today it was beautiful.
I got my piston installed and mounted the cylinder and head. Then got the magneto cleaned up and pretty much got everything together. Here's how the motor is looking: ![]() ![]() ![]() ![]() I need to clean up the carburetor and get it installed, and that should just about do it for the motor parts. ![]() ![]() ![]() I need a couple of clear days to sand blast and powder coat the frame, because I have to do it outside. So I'm going to hold off on the carb for a the next couple of days and see if I can get the frame done. I sand blasted it this afternoon and will clean it up and prep it for the powder coating in the morning. Hopefully I'll have it done tomorrow.
Life is short, live and enjoy it !!! ================================= 05' BMW R1200GS - If you can only afford one bike... 06' VStrom 650 - Fond memories (gone) 06' Suzuki DRZ400 - Wish I could afford two bikes (gone) ================================= S.O. Bikes 07' VStrom 650 ABS (Silver) 05' VStrom 650 (Red) - Sold to get one with ABS |
03-05-2011, 09:01 PM
#49 | |
Oddometer: 295
Looks good. A little soda blasting of the carb and fire in the hole! |
03-06-2011, 11:46 AM
#50 |
Air cooled runnin' mon
Oddometer: 6,141
Good job! Looks great!
I used to be indecisive. Now I'm not so sure. "You only have too much fuel if you're on fire" unknown |
03-07-2011, 08:24 PM
#51 |
Oddometer: 96
parts
Where have you been getting your bits from? Esp Engine bits (rings etc...) I have a 68 Pursang I am wanting to restore.
03-07-2011, 10:57 PM
#52 |
Oddometer: 262
You should be able to get what ever you need from Bultaco.com or BultacoParts.com. But you can get things like seals and bearings locally or on the internet. One place someone mentioned was www.vxb.com, they seem to have just about any kind of bearing you could think of.
03-07-2011, 11:30 PM
#53 |
Oddometer: 262
I powder coated the frame yesterday and it came out good. Here's a couple of pictures:
![]() ![]() Today I got the carburetor cleaned up: ![]() ![]() ![]() ![]() ![]()
03-08-2011, 02:53 PM
#54 | |
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 643
Loks very very good, it's astonishing in which good status overall your carb still is. It looks like there is only little wear at the slide, this is very astonishing too me. The carbs I found mounted to my old bikes where mostly wrecks. slides worn out, screw heads damaged. The carb full with whitch gas layer, ... The powder coating looks got to, where do you "burn in" the powder, do you have your own room for heating up? |
03-08-2011, 08:42 PM
#55 | |
Oddometer: 295
Dave.
03-08-2011, 10:26 PM
#56 |
Oddometer: 262
I've been a potter for almost 40 years and I use one of my pottery kilns. With it's "computer" control, it is perfect for curing powder coating and the temperature you have to go to is nothing for a pottery kiln.
03-08-2011, 10:57 PM
#57 |
Oddometer: 262
Worked on the shocks today and also powder coated the tool box.
The Bultaco shocks I have are not in very good shape. I'm going to work on them later to see if I can rebuild them, but for now I'm going with these shocks from a 1970 BMW. Here's what they looked like when I started: ![]() I was hoping I could open them up and powder coat the main cylinder, but these are permanently sealed. So I cleaned them up the best I could and powder coated the spring. I still want to powder coat the end and the adjuster black. ![]() There is still a little clip I need to do on the tool box, but this is what I have done so far. ![]() ![]() I was curious how things might look together so I kind of set things up. Looks like I got the carb throat on upside down, but I didn't think it would clear the tool box the other way around. I'l reinstall tomorrow and see if that works. ![]()
03-10-2011, 11:07 AM
#58 | |
Oddometer: 643
To your positioning problem, I 'am not very sure but Bultaco's had already very early a rubber tube between the intake and the carburator mounted, maybe your intake is a very good "add - on" from any virtuous machanic. My Sherpa has this gooseneck type intake that allows the carb to be mounted higher, with a rubber tube between and upright too. But as already stated I 'am more keen on later Bultaco models, from the begiining 70's to the end. |
03-10-2011, 12:20 PM
#59 |
What could go wrong?
Oddometer: 4,984
Sweet, nice job. BTW what powder coating unit are you using?
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
03-10-2011, 12:57 PM
#60 |
Oddometer: 643
Just found out that your intake must be right.
This two year younger Matador had the goose-neck intake: ![]() The 66 model here has the same intake:
