Old 03-11-2011, 11:47 AM   #16
Grayghost66 OP
Grayghost66's Avatar
Oddometer: 213
Thumb
Originally Posted by The Raven View Post
The 6mm are the spacers
The 1.18mm are wave washers and belong on the outside of the frame under the nut.
I still stick with going with Maxes Fisch and replace the spacers the way they are supposed to be. I had a lot of Fked up stuff on my bike....amazing what can get changed out over 25 years
Hey Adam,
First, many thanks for all your input with this. I pulled up Max's fiche on the computer and not only is there the exploded diagram BUT there is also digital images of the washers and spacers next to a rular!!! All shown have the gold anodized/or aladine finish to them. I only have the two thinner gold "washers" and not the much larger (almost 10mm) "spacer".
What had me baffled was that since I bought my bike new from the dealer (it was literally in the shipping crate and not assembled for delivery when I bought it) I made the assumption that the bike had never had the engine removed.
I never considered that when the bike was assembled at the factory they might have run out of a particular spacer and substituted stacked up washers to the appropriate thickess - after all these are spacers NOT bearing shims. Could have been the day after Oktorberfest as well.
I am going to buy the correct spacers and reassemble the engine based on the fiche. Again many thanks.
My GS pulls to the right...or the left...depending on what side of the road the Tim Horton's is on.
Grayghost66 is offline   Reply With Quote
Old 03-11-2011, 11:58 AM   #17
The Raven
The Raven's Avatar
Oddometer: 4,811
It's funny, one of the methods of pulling the trans is to actually pull the front spacer and tilt the engine. Don't know what drunk tech though of that one, but in returning the pin back I did what you did. Not having the common sense or advice to actually go and look at MAXBMW. I installed the big spacer on the oil cover side figuring that made more common sense. Not so....I didn't realize this until I put about 4K on the bike. When I went back to correct it the frame had bent and made putting the correct spacer a PITA. Gladly it's settled back where it's supposed to be now, as I pulled the engine and she slipped back in without so much as a grunt.
Originally Posted by Grayghost66 View Post
Hey Adam,
The Raven is offline   Reply With Quote
Old 03-11-2011, 12:20 PM   #18
Grayghost66 OP
Oddometer: 213
Eek
Holy crap. I just remembered that I had the "dealer" in Toronto do a spline lube some years back! I wonder what technique the tech used to gain access to the trans spline????
Thinking that a flat rate shop would want to do the job as fast as possable (read short cuts).... would they have pulled the engine pins, and loosened the swingarm pivots to seperate the engine/trans? If this was the case.....it could have been the dealer.
Old 03-11-2011, 03:01 PM   #19
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,803
Doubtful... the easiest way to pull the trans is to removed the swingarm pivots, pull it back and just lift the trans out... no need to move the engine mount bolts
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 03-11-2011, 04:38 PM   #20
The Raven
The Raven's Avatar
Oddometer: 4,811
Yup. But the BMW Factory repair manual at least for the R80G/S says to remove both pins and lift engine forward and tilt. It's right there
Old 03-11-2011, 05:29 PM   #21
Solo Lobo
airhead or nothing
Solo Lobo's Avatar
Oddometer: 8,803
Well yeah, that's what the manual says... but in the time I worked for a BMW shop, spent time hanging at shops I have yet to see a trans pulled the way the manual says to...
And, I've had mine out at least five times only pulling the swing arm back and away!
R65LazaruS
Old 03-11-2011, 05:38 PM   #22
The Raven
The Raven's Avatar
Oddometer: 4,811
The best and only way is to pull the swingarm. I only did the manual way once....it was enough. I've pulled the trans three times.
Old 03-11-2011, 06:26 PM   #23
Grayghost66 OP
Oddometer: 213
Thumb
This was my first time pulling the transmission and I recall my major problem was when pulling the transmission back it hit on a frame member and I couldn't get the internal clutch (thrust?) rod to clear. As I was doing this with no helper I remember trying to get the transmission to clear and the damn clutch rod was getting in the way.
In hindsight (with a helper) I could have pushed the rod into the transmission to get it to clear. Next time will be easier. Would be nice to pull the swingarm, and not deal with the engine pins.
Old 03-11-2011, 06:34 PM   #24
The Raven
The Raven's Avatar
Oddometer: 4,811
Pull the clutch rod and remove the actuator pin that goes through the trans...makes life a lot easier.
Old 03-12-2011, 09:53 AM   #25
Beemerguru
Beemerguru...G/S guy
Beemerguru's Avatar
Oddometer: 975
The push the engine forward is a carry over from the previous models..especially the /2 era. Easier than messing with the twin shock rear swing arm.
I tried it on a G/S exactly once...never again.
Moving the single swing arm is SO much easier. With the right tools and experience, the tranny is on the bench in 30 minutes or less.
Just did it this morning..in fact for the R100GS it's even faster since you have more room.
Greg Hutchinson
BMW Club of Northern California, Ambassador, BMW MOA, Vice President Vintage BMW Club
http://gregsgssite.shutterfly.com/
Beemerguru is offline   Reply With Quote
Old 03-12-2011, 11:15 AM   #26
The Raven
The Raven's Avatar
Oddometer: 4,811
Sadly, With so many conflicting ways of doing things in the manuals It's almost a better idea to just come to ADV and read up as well as ask questions
Old 03-12-2011, 03:54 PM   #27
Grayghost66 OP
Oddometer: 213
Laugh
In hindsight...ths would have made life alot easier! Oh well. I'm having fun renewing alot of the parts and giving the bike a good going through.
While the trany is away (did I mention I am also going to get a taller 5th gear - swiinnnggg!!!), powder coat a few parts and renew alot of rubber bushings, and rebuild the BINGS. I have hoping what rolls out of the garage is a sweet ride.
As a special gift to the bike I am treating it to a new Wilbers Shock to replace the stocker. The story if anyone asks is I need it for safety as the original is 20 years old. Yeah thats it.....SAFETY
Old 03-12-2011, 04:02 PM   #28
The Raven
The Raven's Avatar
Oddometer: 4,811
That's the fun part about these bikes, as long as you dont screw something up too bad you can learn a lot by wrenching. So many other bikes are not very home mechanic friendly.
Times are GMT -7.   It's 07:09 PM.
