Old 03-14-2011, 07:07 AM   #1
Rapid Dog OP
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,661
Question Airhead Brake Light wire, which one?
I installed a Kisan signal minder. Plug it in where your turnsignal relay goes.
Now you have running lights, self canceling signals, and 4 way flashers.
Pretty cool!
It has a 3 wire plug with one each wire going to your left and one to your right turn signal wire/
A third wire goes to your 'brake light on' wire.
I'm a colorblind old fool when it comes to reading the Clymer wiring diagrams.
Anyone know the color of this 'brake light on wire' in the headlight shell?
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 03-14-2011, 07:53 AM   #2
The Raven
The Raven's Avatar
Oddometer: 4,811
If it's anything like the g/s it's not in the shell. On it, it's a green and red wire.
On your diagram find the brake light switches, and the rear tail light. The common color wire is the "brake light" wire.
edit...it is green and red:
The Raven screwed with this post 03-14-2011 at 08:00 AM
The Raven is offline   Reply With Quote
Old 03-14-2011, 08:16 AM   #3
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 6,054
The color-coding is standard European, so the color codes should be the same regardless of the model (that is, IF that function is on the bike!) ... eg. brown is ground (earth), grn/black is switched power, red is always-on power, etc etc... you see it in Mercedes, Volkswagon etc wiring diagrams....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 03-14-2011, 08:18 AM   #4
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,661
R100/R100S/R100RT/R100RS all have there electrical junk in the headlight shell along with plug-in boards that are clearly marked.
The GS is different.
I just need to know which is the brake light wire in there.
Here's the PDF instructions, it's model SM-1...
https://www.kisantech.com/brochures/SM-inst-manual.pdf
Old 03-14-2011, 08:25 AM   #5
The Raven
The Raven's Avatar
Oddometer: 4,811
No it's not all in the headlight. If you look at the bottom of the posted diagram of the r100S wiring...it's there. There is no reason for the wire that is going from your hand, and your foot, to go all the way forward then all the way back.
I may be wrong about wire location, I DARE YOU TO FIND A GREEN/RED WIRE IN YOUR HEADLIGHT SHELL
Old 03-14-2011, 08:27 AM   #6
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,661
...that's odd if true, cuz the kit comes with a foot long wire and mail connector and a crimp-on plug-in connector to tap into the 'brake light on' wire.
Old 03-14-2011, 08:39 AM   #7
The Raven
The Raven's Avatar
Oddometer: 4,811
It's impossible for a company to know every configuration on bikes. You may need to just run an extension, OR tap into your hand brake wire as it'll be the closest.
NOW; if it's the dimmer running light and not the brighter stop light you are after..then you will find the green/BLACK wire in the headlight housing
Old 03-14-2011, 08:58 AM   #8
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,661
Oddly enough I plugged directly into the board for the left and right turn signals. I now have running lights and self-cancelling signals.
I don't know what the third wire is for, I think for flashing brakelight. Seems to me the front brake wire of which you speak should do the do.
so is that this wire of which you speak?
looks like green/ yellow sorta to me...
Old 03-14-2011, 09:01 AM   #9
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 6,054
Looks green/red to me: that is the power to the brake light. Those switches at the top of the diagram are for the front and rear brakes, and when they close they send +12vdc to the bulb....
The grey/black is the power to the tail light (it is turned "on" with either ignition, or light switch, and the brown is the ground (-).
Loving the 80ST
Old 03-14-2011, 09:05 AM   #10
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,661
Bluhduh
...O.K. guys, lemme be clear, I am RED/GREEN color deficient, had to tell those colors apart or variances of either. So when I look into a Clymer manual with it's shitty printing I can't see the contrast.
That's why I'm askin'...and I was hoping there was a place on the board or a wire to tap into.
gt it?
Old 03-14-2011, 11:38 AM   #11
The Raven
The Raven's Avatar
Oddometer: 4,811
gt it?
Ouch...Then it's going to be tough without another set of eyes. Having color issues both brake light wires will look the same. You NEED to know which one os one will be live all the time and the other only when the switch is actuated.
If you look on the diagram on the left where it says "connector block" that is I believe the board you keep referring to. If you are looking for a spot on that board to find a live brake wire you will be looking for quite some time as it's not there...only the running light wire that comes on when you turn the key. It would be one of the fused connections.
Old 03-14-2011, 12:02 PM   #12
Rapid Dog OP
Rapid Dog's Avatar
Oddometer: 9,661
Laugh
...I see...said the blind man...
Got an answer from Kisan, they've been doin' BMW stuff for a long time..
"FYI, brake wire is grey/yellow."
...mmm...I'll ask my wife out to the garage...
Old 03-14-2011, 07:05 PM   #13
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,566
Brake light wire is green with red and sometimes the brake light switch wire is brown with yellow.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Boxer Metal is online now   Reply With Quote
Old 03-14-2011, 07:29 PM   #14
bmwrench
Oddometer: 2,352
It's Grey/Yellow only on very late model bikes. It'll be Green/Red on an R100.
bmwrench is offline   Reply With Quote
Times are GMT -7.   It's 04:20 PM.
