Closed Thread
Old 03-18-2011, 12:21 PM   #586
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,025
Then your choice of air temp mods is the right one for you.
Yes the IICE Air uses remote sensors.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen is offline
Old 03-18-2011, 05:59 PM   #587
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by Babo View Post
I'd much rather have remote sensor encased in thin metal than a sensor buried under plastics that is subject to the bikes radiant heat. A trade-off I'm sure, and perhaps inconsequential.
If the remote sensor is anywhere on the bike, it is subject to the heat from the bike. The several and various tests I performed proved that. A consequence of those tests was that I proved it to myself, because I was believing the same thing.
If you want the sensor to not be affected by the heat from the bike, the sensor must be mounted 5 feet to the side of the bike. I'm not joking, that's actually how it is. I performed those tests too.
FWIW, I've tested the responsiveness of a remote sensor (boosterplug) with a GS911 and found that temp changes are almost instantaneous - certainly as quick as the AIT anyway.
Yes there is no substantive difference between the slightly slower response time of a metal enclosed sensing element, vs. a plastic enclosed element, vs. an exposed element.
Regardless, there are other reasons why some vendors use a sensor in addition to the stock AIT, and there are successful vendors that don't...does the IICE Air use one?
The IICE Air uses separate sensors and also uses the stock Intake Air Temperature sensor. Multiple sensors makes it adjustable.
Something to note Babo, if you decide to get the second IICE Cool product. If the IICE Cool is used in conjunction with other non-adjustable products, the motor runs too rich.
__________________________________________________
Pre-Order Sale - 7 Days Remaining
IICE Air Vendors Thread:
http://www.advrider.com/forums/showthread.php?t=667661
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 03-18-2011 at 06:47 PM
Poolside is offline
Old 03-18-2011, 07:42 PM   #588
grpweld
grpweld's Avatar
Oddometer: 321
While I have not preformed any scientific tests as you have, I have a hard time believing that traversing down a road at 35,45,55,65,75mph that the temp sensor would not see a difference if behind the oil cooler,next to exaust pipe, ect... than some where that gets outside ambient air flow.
respectfully
edit: are you saying that the intake track gets the same air as ambient outside air?
09 R1200gs
grpweld is offline
Old 03-18-2011, 09:13 PM   #589
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
respectfully
Good thoughts. I was thinking all those things before doing the tests.
Here's one way to visualize it. There is no "outside" airflow on a bike. You're either 'downwind' of something that's putting off heat, or your not. If you're not, then the airflow reaching you is ambient temperature.
In answer to your intake air temp question, yes. When the bike is moving, the intake air snorkel gets ambient air.
When the bike is stopped however, there aren't any cool spots. Everything is picking up convection heat. Under the seat, up around the steering head area, the intake snorkel, everything.
On kind of a side note, here's something worth mentioning. Heat also travels from one object to another through radiant transmission. Radiant transmission is based on whether the hot object is in your line of sight. If you can't 'see' it, and I mean that literally as 'in your line of sight', then it can't conduct radiant heat to you.
That's why a simple non-contact opaque surface will block radiant heat from an exhaust pipe, no insulation necessary. And why it's cooler (ambient temp) in the shade.
Also, radiant heat is independent of airflow. It doesn't travel through air, it travels through space, in all directions, in the form of infrared light.
So if you mounted an air temp sensor so that it could 'see' an exhaust pipe, then the sensor would receive radiated heat. By 'see' I mean that the exhaust is visible from the vantage point of the sensor element.
Poolside is offline
Old 03-19-2011, 08:40 AM   #590
Stinkyb
GS"eh" rider
Stinkyb's Avatar
Oddometer: 355
Ok, Ive been following this thread for some time...lots of long winded conversations.
Im not asking a complicated question as to the operational parameters or how the shit works......thank god
Do you have a site up an going for purchases and perhaps a simplistic explaination without having to sift through 10 pages of thread.
O and a pic by pic walkthrough installation, I like pictures
"Dear MCGuyver enclosed is a paperclip an elastic band and a toothpick, please save my dog"
Stinkyb is offline
Old 03-19-2011, 01:51 PM   #591
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,025
See post # 579
It's real simple.
Unplug the stock sensor. You'll know it is the right one because its on the air box.
Plug the IICE Air into the 2 available connections,
drive away.
About as simple as it gets.
JJ
WingMakers.com
johnjen is offline
Old 03-19-2011, 02:14 PM   #592
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 16,025
Originally Posted by J-Dub View Post
Poolside and JJ,
I've read the entire thread, and I may have missed it, but does altitude have any effect on the operation of this device, i.e., enrichening/leaning the A/F ratio? I'm thinking about fouled plugs, but maybe I've been messing with my old Triumph too much.
With modern fuel injection fouled plugs are a thing of the past. But if there is a problem with your ignition system or the EFI itself, it is possible to foul plug(s). But these mods won't be the cause.
JJ
WingMakers.com
johnjen is offline
Old 03-20-2011, 01:05 AM   #593
J-Dub
Combat Commuter
J-Dub's Avatar
Oddometer: 265
Cool, thanks. Order placed.
J-Dub is offline
Old 03-20-2011, 06:08 AM   #594
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by gonzo2k View Post
I have Jens booster plug on my 04 GSA... does your IICE Air supplement or replace it?
I'm confused.
Thanks,
Rick
I would call it a replacement. I mean, the IICE Air is a similar product, and it works the same way, except it's adjustable.
The adjustability lets it operate better over the full hot and cold ambient temperature range. And it will operate better in conjunction with the upcoming IICE Cool product. The non-adjustable devices if used with the IICE cool will run a little rich, but you can always disconnect them and run the IICE Cool alone, for a 2/3 improvement.
Poolside screwed with this post 09-09-2012 at 08:18 PM Reason: Removed an outdated announcement.
Poolside is offline
Old 03-20-2011, 07:44 AM   #595
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,646
I don't want to read this shit. Wouldn't understand it if I did.
1) Adjustable? Me no likey adjustable if by adjustable we mean I have to tinker with it (altitude, season etc) after I get it set for my home conditions.
2) Do it work?
Answer 1) and I'll trust y'all on 2). You seem like straight up fellas and...I know where to find you. lol.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is online now
Old 03-20-2011, 09:03 AM   #596
Babo
Babo's Avatar
Oddometer: 253
Pre-Order Sale - 6 Days Remaining
Hmmm...
While there are certainly some well know products in this category that don't adjust for ambient temperature, one of the features of the Booster Plug is that Jens has figured out a way to makes certain that the ecu reads a consistant temperature regardless of ambient temps. He's got pretty charts on his site that explain it, and it has been independently tested to be true.
I get that yours is user adjustable and will be optimized to work with you second, forthcoming product, but wonder why are you are specifically lumping the Booster Plug into this category?
Babo is offline
Old 03-20-2011, 10:18 AM   #597
Jltrd
Oddometer: 27
After reading and re-reading all of the posts there is one question that has not been answered. Why only one batch of the IICE Air? If your products are going to work as advertised why limit the amount of people that can buy it? I decided to get the booster plug after I read all of the positive user reviews. It would seem that positive reviews of your product would only increase interest. It takes alot of faith to buy something that no one has tried before especially when it is a one time only offer. P.S. How much is the IICE Cool going to cost?
Jltrd is offline
Old 03-20-2011, 10:32 AM   #598
Airman Jack
Faster! Lower! Faster!
Airman Jack's Avatar
Oddometer: 129
how to adjust
Have you sorted out exactly how we would be adjusting the IICE Air? Is it something that you have to twist with a phillips screwdriver, or will it have a knob that can be twisted by gloved or ungloved hands? How clear are the markings to indicate the current setting?
2004 BMW R1150GSA Adventure
Airman Jack is offline
Old 03-20-2011, 11:16 AM   #599
CamoGreg
Can you see me?
CamoGreg's Avatar
Oddometer: 4,639
From what I remember reading. It's a jumper setting. Just like on installing a hard drive. That's why there's a plastic snap cap.
It won't be something you can adjust on the fly.
CAMOGREG
"We're all travelers in this world. From the sweet grass to the packing house. Birth 'til death. We travel between the eternities." -Prentice Ritter
CamoGreg is online now
Old 03-20-2011, 06:58 PM   #600
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,887
2) Do it work?
Thanks sog!
It's adjustable to one of 4 settings. One click less when it's really hot, and one click more when it's really cold.
It adjustable like CamoGreg said above. A jumper setting under a pop top.
Or you can leave it in the middle setting all the time if you like. That is the same as the other non-adjustable products.
Poolside is offline
Closed Thread
Times are GMT -7.   It's 06:32 PM.
