Old 03-23-2011, 11:32 AM   #16
mfp4073 OP
mfp4073's Avatar
Oddometer: 2,448
Ok, thought of something else. How much does the choke effect the air/fuel mixture once the primary circuit is engaged (twist the throttle). Is there another part of this that enriches the off idle mixture?
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 03-23-2011, 02:07 PM   #17
rufusswan
rufusswan's Avatar
Oddometer: 962
Once the "enricher" circuit is engaged, it engaged until you turn it off. The throttle position is irrelevant. It is a seperate carb, working by itself.
1971 BMW R75/5 Toaster LWB
1974 Honda CL200
http://zenhuckfinn.wordpress.com/
rufusswan is offline   Reply With Quote
Old 03-23-2011, 04:48 PM   #18
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,190
Exactly! If the choke stays on, the low end will definitely be richer.
Times are GMT -7.   It's 06:43 PM.
