View Results: What should Tlub do with his R50?
Nothing 21 0.01%
Pimp it out and chrome the crap out of everything 4 0.00%
Repaint it to look like everybody elses' bike 314,159 99.99%
Voters: 314184. You may not vote on this poll
Old 03-20-2011, 08:56 PM   #541
danedg OP
Horizontally Opposed
Oddometer: 6,773
Sorry!
The purpose was to post as many words about /2's as possible,
but each pitcher is worth a thousand words...
So a pic/day might fill the bill...
54' R51/3, 65' R60/2, 68' R60US, 74' Moto Guzzi Eldorado, 95' Mystic, '78 Honda Hawk...... the Axles of Evil!
danedg screwed with this post 03-20-2011 at 09:31 PM
danedg is offline   Reply With Quote
Old 03-21-2011, 01:58 PM   #542
danedg OP
Oddometer: 6,773
The New Lighting System
Behold! The halogen 35w bulb that replaces the OEM incandescent 35w.
Both use the standard BA20D base. So you just swap one for the other.
Don't touch the bulb with your greasy fingers!!!
No one could tell me how much brighter it actually was, but a little research shows that on a lumens per watt basis, a halogen bulb will double the lumens of a comparable incandescent device.
It's twice as efficient/watt.
It's %100 brighter than it's predecessor...
It's like holding TWO candles in front of the bike at night instead of just one.
Old 03-21-2011, 05:20 PM   #543
danedg OP
Oddometer: 6,773
Crossover pipe
Before.
Let's face it, when you change your transmission oil, you pull the tranny plug, and EVERYTHING spooges out over the crossover pipe!
It's a fact of /2 life and death.
But, it can be cleaned once every 46 years!
All it takes is ELBOW GREASE!!! And a brass wire wheel on your drill press to cut through the burned on 90W... and WHIZ metal polish...
Here you can see the handmade header configuration. The chromed nut was installed and then the pipe was flared.
I saw the crossover pipe for sale on fleabay, complete with the 2 clamps!
There ain't no clamps at all to fit the exhaust. Just hangers.
danedg screwed with this post 03-21-2011 at 06:24 PM
Old 03-21-2011, 09:24 PM   #544
gertiektn
KetchikanBeemer
Oddometer: 76
Hey,, Bruce is my best friend.
Jim, KtN.
1959 R60 Hack "Slipper"
1960 R50 "Hanz"
(2) 1977 R75/7 "Gertie" & Green Lantern
2004 R1100S "RFAR 1"
No chains here!
gertiektn is offline   Reply With Quote
Old 03-23-2011, 05:46 AM   #545
Beamer Bum
Beamer Bum's Avatar
Oddometer: 349
brake lining
I just re-lined my brake shoes and for the first time I have semi-metallic linings. I'm sure they will brake better than the fiber linings I've always had. But, does anyone know how much wear they will inflict on the drum surface?
Beamer Bum is offline   Reply With Quote
Old 03-23-2011, 09:53 AM   #546
danedg OP
Oddometer: 6,773
Is that the stuff Benchmark sells?
Old 03-23-2011, 12:30 PM   #547
danedg OP
Oddometer: 6,773
68,000 mile valve adjustment
I adjusted my /2 R60 valves last nite.
Probably for the first time in 8 - 9000 miles.
In the first 10K after rebuild, I checked 'em every 500 - 1000m, and gave up after 12K, cause they hadn't budged.
Didn't check 'em at all last year. Another 8000 miles. Bike ran fine. There is one little tap, however.
So, being completely bored, I pulled covers yester, and whipped out the feelers. Guess what?
Dead on, both sides.
Then I reread Elaine's Tech Article on setting valves
I'd been doing right all along, but didn't realize that a push rod could be bent...and that might be the source of the unidentified tappety tap...
How badly could the rod be bent and still operate? And if it IS bent, how long will it continue to operate in that condition?
Another 68,000 miles?
danedg screwed with this post 03-23-2011 at 02:31 PM
Old 03-23-2011, 02:32 PM   #548
danedg OP
Oddometer: 6,773
Just because
Just because it's frikkin' SNOWING!!!!!!
Old 03-23-2011, 04:01 PM   #549
danedg OP
Oddometer: 6,773
Pawl
A common malady on kickstart /2's, is the first tooth on the segmented kickstart gear {the pawl}, often suffers a fatal injury and is broken off...
My kickstarter is no exception. I have to carefully feather the clutch, to engage the pawl to the internal idler gear at JUST the right spot, and THEN kick.
When MAX rebuilt the tranny I was given the option of replacing the segmented gear ($500), or not, with a new one. That piece alone was as costly as the entire refresherment of the tranny itself. At the time, the decision was made to not address the issue. I'll live with it....just like the other shortcomings of my existence.
Today, I get a phone call from the OTHER mentor of my /2 experience, saying that a method has been perfected that restores/repairs the first tooth of the pawl. Not only is the segment gear tooth repaired, but the idler gear is refreshed as well.
Hmmmmmm......
If you've got kikstart issues, maybe I could get it rebuilt for you.
This was discussed for several years, and was finally accomplished.
Old 03-23-2011, 05:36 PM   #550
Beamer Bum
Beamer Bum's Avatar
Oddometer: 349
I believe Dan at Cycleworks does kickstart segment repairs. He also does crankshaft and camshaft repairs.
http://www.cycleworks.net/
Old 03-23-2011, 05:41 PM   #551
Beamer Bum
Beamer Bum's Avatar
Oddometer: 349
Yeah, I got from Vech. I think he gets them from Mark Huggett in Switzerland.
With the old linings I've never had to get the drum cut. I'm concerned the semi-metallic linings will mean I have to cut the drums next brake job. A couple of cuts and I'll need to buy a new hub and lace the wheel.
Old 03-23-2011, 06:17 PM   #552
danedg OP
Oddometer: 6,773
I asked Vech about getting the drums cut. His response was, it's not really possible. If you increase the radius of the drums, the shoes won't match up, and your braking efficiency decreases.
Old 03-23-2011, 08:15 PM   #553
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
datchew is offline   Reply With Quote
Old 03-23-2011, 11:14 PM   #554
Carl
Carl's Avatar
Oddometer: 776
Not is it only possible, I've done it and so have many others. There's too much hearsay and second hand smoke clouding the air on these BMW pre-70 technical items.
The key is to fully review the hub and its brake liner to determine how and what needs to be machined. Then, and only then should the machining begin in either a brake or engine type lathe.
Carl
http://www.flyingtpot.com/
Carl is offline   Reply With Quote
Old 03-24-2011, 09:20 AM   #555
danedg OP
Oddometer: 6,773
Originally Posted by datchew View Post
What?
Times are GMT -7.   It's 02:55 AM.
