Old 03-29-2011, 10:07 AM   #16
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,818
Originally Posted by crazydrummerdude View Post
So, in the opposite mindset, should I put multiple carbs on my BMVW? It has one carb and four cylinders.
Well, the hot setup on the old 2002 BMW cars was four Weber side draft carbs, so why not?
You could at least a single dual throat carb on each side. I'm pretty sure they make hardware for that kind of setup on a VW engine.
Err, just notice in another thread...
caponerd is offline   Reply With Quote
Old 03-29-2011, 12:20 PM   #17
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 7,976
Originally Posted by Smallwheelsgood View Post
I have heard that carb icing may occur with such long inlet tracts, other than that I envisage that it would offer less complication and maintenance, and perfect balance with only a small reduction in top end performance. Any help would be much appreciated.
I'd say to look to history. When Ducati installed a single Weber (I think) on their late 1980's/early 1990's SS series the results were not good, and many owners went back to two carbs.
Setting up seperate carbs to work well can take a few minutes, but holds well between valve adjustements or longer. If you are concerned about the time it takes to keep a bike running well, perhaps an airhead is not the bike for you.
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 03-30-2011, 12:38 PM   #18
Smallwheelsgood OP
Smallwheelsgood's Avatar
Oddometer: 11
Ok, thanks to all. What about supercharging then? I know about the factory racer, but has it been achieved by anybody else since?
Smallwheelsgood is offline   Reply With Quote
Old 03-30-2011, 12:53 PM   #19
marksbonneville
marksbonneville's Avatar
Oddometer: 937
Seriously why not consider mechanical fuel injection if complexity is the goal. BTW what is the goal?
marksbonneville is offline   Reply With Quote
Old 03-30-2011, 01:00 PM   #20
Smallwheelsgood OP
Oddometer: 11
OK, thanks to all, sounds like a dead end. So what about supercharging an airhead? I'm aware of the factory racer, but has anybody else achieved this since?
Old 03-30-2011, 01:05 PM   #21
Smallwheelsgood OP
Oddometer: 11
The goal concerning the single carb was simplicity. As far as the above is concerned, just curiosity.
Old 03-30-2011, 01:07 PM   #22
Hawk Medicine
Coyote's Brother
Oddometer: 3,299
Thats another item that has been successfully applied to Airheads. Once again, there were several people who transplanted VW injector systems into Airheads in the late 80's/early 90's.
I would think that it would be much easier today but that stuff is over my head. I'm doing well to take care of what I have!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 03-30-2011, 01:39 PM   #23
Houseoffubar
fine beer sampler
Houseoffubar's Avatar
Oddometer: 1,560
Now your talking!
I don't think it would be easy, but supercharging would be a good way to get some healthy power out of an Airhead. Turbocharging works, but is not the best way to go with a twin.
I would look into an intercooler, and water/alcohol injection as Airheads are already detonation prone already.
Now you just have to figure where to mount it, and how to drive it!
Houseoffubar is online now   Reply With Quote
Old 03-30-2011, 01:43 PM   #24
marksbonneville
Oddometer: 937
OK gotcha, well the stock cv carb is pretty simple but I see where you are going. I had a Judson Super Charger on my VW for a while, did not gain much power but it looked cool.
Old 03-30-2011, 02:09 PM   #25
Grider Pirate
Grider Pirate's Avatar
Oddometer: 1,669
Hello all, newbie to this site, I have lurked for a while and have found a wealth of information and experience, plus some cracking pictures.
I have 2 no. R100RS's, 1 x 1978 in bits, 1 x 1983 running reasonably well. I have long wondered about converting to a single carb setup, does anyone know of this ever having being done? If not, what would be the pros and cons of such a setup. I have heard that carb icing may occur with such long inlet tracts, other than that I envisage that it would offer less complication and maintenance, and perfect balance with only a small reduction in top end performance. Any help would be much appreciated.
I have been curious about this for some time. I have two airheads that are running perfectly well, so maybe it's time to 'break' one of them. It turns out that one of the guys in my glider club has a dyno, so some figures would be available. I would expect, and accept, some loss of power. The icing issue was truly significant on the old VW's, and would likely also be a big issue on the airhead. I think it might be easier to feed warmed air to the air filter box (like aircraft)than to do it like a VW.
Please don't tell Mom I'm a pilot. She thinks I play piano in a whorehouse.
http://griderpirate.smugmug.com/
http://www.youtube.com/my_videos?feature=mhum
Grider Pirate is offline   Reply With Quote
Old 03-30-2011, 06:58 PM   #26
drhach
gorillamanufacturing.com
drhach's Avatar
Oddometer: 1,887
Less moving parts, less wear items, EFI seems simpler to me.
1976 R90/6
1972 XLCH
2010 Triumph Thunderbird SE
drhach is offline   Reply With Quote
Old 03-30-2011, 07:08 PM   #27
marksbonneville
Oddometer: 937
Well that would make sense and if we are going to be sensible then leaving the stock CV's would be the best option. I was just tossing out a really complicated idea that would cost a lot of $$ and make little power, kind of like adapting a single carb.
Old 03-30-2011, 10:26 PM   #28
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,297
Yeah, they call it a K bike.
Same basic system as the aircooled VWs
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 03-30-2011, 11:15 PM   #29
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 15,990
Originally Posted by Tosh Togo View Post
And you'd get a lot of questions beginning with "WTF were you thinking?."
Great thread.
Old 03-31-2011, 06:20 AM   #30
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 865
Originally Posted by kadesean View Post
If you are talented enough to pull off this mod you have to be talented enough to balance your carbs every 5-10,000 miles.
Very true ... but if you convert to the one-into-two throttle cables, that will be the last time the carbs need balancing until they're removed for rebuilding.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is online now   Reply With Quote
Times are GMT -7.   It's 09:08 PM.
