Old 06-02-2010, 01:05 AM   #61
Bushwhacker
Dirt, Sweat & Gears
Bushwhacker's Avatar
Oddometer: 442
Originally Posted by The Griz
14.7:1 is known and has been known for decades to be the perfect air/fuel mixture for gasoline-burning engines.
No such thing as a perfect air/fuel ratio.
14.7:1 is the ratio that has a Lambda of 1. That means you thoeretically have exactly enough air molecules to burn all the gasoline molecules. That is what the EPA thinks is perfect because it produces the least emissions.
A slightly lean mixture - 15.4/1 - generally gives the best fuel economy.
A slightly rich mixture - 12.6/1 - generally gives the best HP.
I have read that a bit leaner - 13/1 - produces the most torque.
Also leaner engines run hotter and therefore are more prone to pre-ignition, ie knocking.
Richer mixtures run cooler and most likely add to engine life.
Also a flat air/fuel curve is not necessarily the best although it does give the smoothest, most predictable power delivery, however it would seem to me that an Air/fuel curve that starts out at about 13 or a bit higher/1 and then decreases to about 12.5/1 over the RPM range would give the best torque in the lower RPMs and the best power in the upper range. This would cost you in fuel economy but I am willing to give up a bit of economy for a bit more power.
Plus this entire discussion is for pure gasoline/air ratios. Gasoline additives change the analysis and every vehicle has to be tuned on a dyno with the fuel it is going to run to obtain optimum results.
And finally, all of this is for normally aspirated engines and forced air induction engines (turbocharged) should be run richer still for both optimum power and engine life.
JMHO - YMMV
09 F800GS ABS Yellow/Black
When you look like a rude, crude, scum sucking cretin, people tend not to ask you stupid questions!
Bushwhacker is offline   Reply With Quote
Old 06-02-2010, 10:16 AM   #62
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
JMHO - YMMV
Well, I can tell you right now that if I had tuned my KLR to 15:1 or higher I would have been seriously overheating and damaging many things. When I was going through the paces with tuning that bike, I remember hitting 15:1 and being far to lean on a test run. I got home, pulled into the garage, got off the bike, and noticed my header was glowing bright orange. 15:1 or higher for the KLR for any extended period of time: NO GOOD.
Read my previous post. You're basically echoing exactly what said. We've already been through this in this thread.
Old 06-02-2010, 10:27 AM   #63
LukasM
Oddometer: 5,415
Griz,
All you ever wanted to "achieve" was 14.7 and now 15:1 would seriously overheat and damage the bike.
If you really have still not understood it, you don't tune for ONE specific number, and 14.7:1 is not known and has been known for decades to be the perfect air/fuel mixture for gasoline-burning engines - unless you are talking about emissions.
Like I said from the beginning, you tune for load/throttle position, going from slightly lean at cruising RPMs (where it will not damage anything) to rich under full load (to produce max power and protect the engine from detonation and overheating).
Now please stop posting more BS, or at least read through the previous replys as we have been through all this already.
Old 06-02-2010, 10:37 AM   #64
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Originally Posted by LukasM
Griz,
OMFG Lukas, seriously. You're not reading what I'm posting. You're the classic case of someone who constantly talks but doesn't listen.... always thinking about what you're going to say next instead of listening to what the person in front of you is actually saying.
I have NEVER said that I EVER want to achieve 14.7:1 at all times under all throttle positions and under all loads and conditions. We all "shoot for" 14.7:1 is all I was saying. So yes, we've been through this. You're the one who's not getting it.
Mods, please nuke this thread.
Old 06-02-2010, 10:40 AM   #65
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,939
so, with all of this back and forth banter...is there a solution?
IMO, open up the exhaust, the intake doesn't appear to be a restriction and a re-map to enrichen it up a bit.
In summary.
Exhaust can
header (optional)
Power Commander (or equivalent)
tune.
No?
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 06-02-2010, 10:43 AM   #66
LukasM
Oddometer: 5,415
You are so full of it and still don't see it. Nobody except you (and the manufacturers for emissions reasons) is aiming for 14.7.
Because, again, what you said below is BS:
And btw, 14.7:1 is completely safe. In fact, contradicting such a fact would be disagreeing with decades of hard scientific evidence regarding the internal combustion engine!
In summary.
Exhaust can
header (optional)
tune.
No?
Thats a good plan. The key here is the PC to richen up the mixture if you open up intake and exhaust.
Old 06-02-2010, 10:46 AM   #67
ride2little
Oddometer: 1,939
Oh...additionally, I've done this on all other bikes I've owned (usually a re-jet). And it does NOT cause your MPG to suffer. Rather it usually improved it.
Your motor works more efficiently. It actually works less for the same amount performance. The only issue is that once you see your motor perk up (improved throttle response), you may get into the throttle more which WILL cause the MPG to suffer.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
Old 06-02-2010, 10:57 AM   #68
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
I have to post it again I guess:
Did you hear this time?
14.7:1 is completely safe: on an engine running at a constant RPM under constant atmospheric conditions and loads. I never said that it is safe for a motorcycle at all times under all loads and conditions. I said it's what we "shoot for".
And, yes, contradicting the 14.7:1 stoichiometric ratio is going against 80+ years of hard scientific evidence.
The Griz screwed with this post 06-02-2010 at 11:03 AM Reason: To underline, color, and bold the important points so hopfully Lukas will listen.
Old 06-02-2010, 11:04 AM   #69
ride2little
Oddometer: 1,939
This thread has since lost all of it's usefulness.
Can you folks please take this debate off-line? Or at least delete your back and forth?
Thanks.
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
Old 06-02-2010, 11:05 AM   #70
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
This may help:
http://en.wikipedia.org/wiki/Stoichiometry
http://en.wikipedia.org/wiki/Air-fuel_ratio
Old 06-02-2010, 11:19 AM   #71
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
Thanks.
Good call.
Old 06-02-2010, 12:02 PM   #72
The Griz
North Forest Rider
The Griz's Avatar
Oddometer: 3,782
+1 This was my exact result after re-jetting my KLR650.
Old 03-31-2011, 03:20 PM   #73
EmmettC
EmmettC's Avatar
Oddometer: 1
Tuning
I hope this thread is still being used.
I had my bike run on a dyno the other day, it's got a remus exhaust system and an Arrow can. It's making 82.51 HP.
The guy who runs the tuning shop (in Edinburgh) reckons it running very rich at full throttle, and very lean while cruising. I've ordered a PC so he can tidy up the fueling, I'm not looking for more power, I just want it to run well.
I'm a little worried about the fuel consumption increasing, as the tank is soooo small it really needs to be very frugal to be any use.
I'll update once the tuning work has been done. hopefully more torque, the same or better fuel consumtion, and If there's more power too, I won't complain.
EmmettC is offline   Reply With Quote
Old 03-31-2011, 03:31 PM   #74
Gangplank
Advenchaintourer
Gangplank's Avatar
Oddometer: 2,294
Yes!! Really happy someone decided to take this one. I've been thnking about it myself but don't have the time or a good tuner withing 4.5 hrs drive. Let us know the results. I have a similar set up to you with the Leo V. pipe so might be able to apply your results.
Ride more, bark less
Gangplank is offline   Reply With Quote
Old 03-31-2011, 03:50 PM   #75
ebrabaek
Oddometer: 4,727
You might wan`t to look into Dynojets autotune box along with the PC. It will allow you and your bike to tune outside the dyno....and makes for a awesome user friendly package, that you can work yourself.
Erling
Times are GMT -7.   It's 05:30 AM.
