| View Results: How did your failure happen? | |||
| No notice at all ,left me stranded on the spot. |
64 | 22.38% |
| Noticed a problem ,but was able to ride back to civilazation |
103 | 36.01% |
| Just checked and felt fine ,but died a few hundred miles later |
17 | 5.94% |
| Noticed problem,rode bike hundreds of miles without total failure |
102 | 35.66% |
| Voters: 286. You may not vote on this poll | |||
04-05-2011, 01:37 PM
#286 |
Woolf Barnato
Oddometer: 29,135
Wut?
What if you had to be back at work in less than two days? what if you were crossing the Atacama desert?
'Gonna get me a six pack...push people off the highway!' "they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood." "I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!" "Yeah, that guy sure is terrible at touching moms" |
#287 |
poser
Oddometer: 2,485
Looks like the input shaft seal to the FD might also be leaking
Current: 2001 R1150GS 1981 CB650 Custom 2011 Golf TDI - New tow rig |
04-05-2011, 01:53 PM
#288 |
Oddometer: 263
last year when I got my 6K mile service, they noticed the pinion bearing "had some play" and recommended I get it replaced before it fails... I inquired just how much play and would it be wise to replace it right away.. They said it could probably wait till next year.. So, I just got it replaced over the weekend.. No failure (thankfully) but still $500 I didn't want to spend.. Grrrr.
Hopefully it'll be fine for many more miles and I won't ever have to worry about it. |
04-05-2011, 02:03 PM
#289 | |
Tuscan rider
If I was in a desert I would have brought a bearing, a seal and a puller. As it is, I rode to the nearest town, pulled into a hotel, had an excellent dinner, and am now waiting for the parts to arrive. No big deal. I am in no way condoning the design of the FD! [TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here. Renting out motorbikes in Toscana, Italy Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index. IBA: 33616 |
04-05-2011, 02:05 PM
#290 |
Tuscan rider
Might be, but everything was severely spreyed with oil so it is hard to tell.
Thank you for alerting me; I'll clean it and keep an eye on it. [TaSK]
04-06-2011, 05:05 AM
#291 | |
"Cool" Aid!
Oddometer: 41,491
![]() Jim
04-06-2011, 08:22 AM
#292 |
Oddometer: 157
2005,75k
Mine too. My sister actually noticed the grinding noise on a lunch ride. No wheel play, top to bottom or side to side, but a noticeable grinding noise on rotation. Got the drive apart, and the bevel gear inner bearing is toast. Got all the bearings and seals on order, and am hoping they dont take too long to get here. About 300$ in parts.
Later, Randy 2005 1200GS |
04-06-2011, 09:49 AM
#293 |
Rinho Féroce
Oddometer: 971
first of all, I don't know all technical word for all these parts...
Mine fails (2 years ago) because the inner part of the bearing on the of the pinion had slide a little bit and had started to grind the diff case (I was told if happens frequently) Resulting in an oil pollution and the bearings "beginning of the end" However I was able to ride several hundred KM without being worried Leak appears right after a highly muddy weekend (GS Challenge)... Maybe the leak had nothing related to the diff "on his way" failure, but at least it helps me see it before it turn into drama. I replaced the part myself, but I bring the diff to be adjusted by a BMW mecanic master. IMHO, the preload adjustment is the key to have the diff lasts long. I even think the preload should be re-adjusted during the bearing life
'06 950 LC8 Adv S '02 F650GS (wife's bike) '99 LandCruiser '92 KTM 400 LC4 (the first 400 LC4 produced, pre-serie unit) |
04-06-2011, 10:27 AM
#294 | |
Woolf Barnato
Oddometer: 29,135
Because it's trouble and expense you shouldn't have to deal with.
04-06-2011, 03:54 PM
#295 | |
I have little to say
04-06-2011, 05:13 PM
#296 |
Rinho Féroce
Oddometer: 971
Right, and that's why I change the diff oil when doing the engine oil... to check and be sure the oil is not contaminated
04-08-2011, 07:16 PM
#297 | |
Oddometer: 75
www.motorcyclebum.com |
04-09-2011, 07:07 AM
#298 |
God Bless Texas!
Oddometer: 9
No Failures...Yet
On two oilheads with ~70K combined no failures yet, but it's always in the back of my mind. I bought BMW so that I would NOT have these types of failures. Lately, I've been re-thinking the simplicity of the chain. Chains typically don't just fail and leave you stranded. You get plenty of opportunity while cleaning and lubricating to inspect sprockets and chain for wear. If you don't take preventive action, then shame on you (or me!). Just MHO.
04-09-2011, 07:59 AM
#299 | |
Oddometer: 4,115
