View Results: How did your failure happen?
No notice at all ,left me stranded on the spot. 66 22.37%
Noticed a problem ,but was able to ride back to civilazation 107 36.27%
Just checked and felt fine ,but died a few hundred miles later 17 5.76%
Noticed problem,rode bike hundreds of miles without total failure 105 35.59%
Voters: 295. You may not vote on this poll
Old 04-05-2011, 01:37 PM   #286
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,975
Originally Posted by tagesk View Post
No big deal.
[TaSK]
Wut?
What if you had to be back at work in less than two days? what if you were crossing the Atacama desert?
'Gonna get me a six pack...push people off the highway!'
"they live off the carrion of our mutual distrust and bribe us with symbols that equate hatred with manhood."
"I mean at the end of the day, I was addicted to Starting Fluid for Christ's sake!"
"Yeah, that guy sure is terrible at touching moms"
Anorak is offline   Reply With Quote
Old 04-05-2011, 01:37 PM   #287
(none)
poser
(none)'s Avatar
Oddometer: 2,623
Looks like the input shaft seal to the FD might also be leaking
Current:
R1150GS
GN400
LC80
JK Rubi
(none) is offline   Reply With Quote
Old 04-05-2011, 01:53 PM   #288
TomDac
TomDac's Avatar
Oddometer: 309
last year when I got my 6K mile service, they noticed the pinion bearing "had some play" and recommended I get it replaced before it fails... I inquired just how much play and would it be wise to replace it right away.. They said it could probably wait till next year.. So, I just got it replaced over the weekend.. No failure (thankfully) but still $500 I didn't want to spend.. Grrrr.
Hopefully it'll be fine for many more miles and I won't ever have to worry about it.
Hayward, CA
2006 R1200GSA - aka "Gretel"
http://www.flyv65.com
TomDac is offline   Reply With Quote
Old 04-05-2011, 02:03 PM   #289
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,227
Thumb
Originally Posted by Anorak View Post
Wut?
No big deal FOR ME IN THE CURRENT SITUATION.
If I was in a desert I would have brought a bearing, a seal and a puller.
As it is, I rode to the nearest town, pulled into a hotel, had an excellent dinner, and am now
waiting for the parts to arrive.
No big deal.
I am in no way condoning the design of the FD!
[TaSK]
'02 R1150GS - Adds life
My Riding in Tuscany-thread is here.
Renting out motorbikes in Toscana, Italy
Proud contributor to Wisdom and GSpot FAQ and European Ride Report Index.
IBA: 33616
tagesk is offline   Reply With Quote
Old 04-05-2011, 02:05 PM   #290
tagesk
Tuscan rider
tagesk's Avatar
Oddometer: 3,227
Thumb
Might be, but everything was severely spreyed with oil so it is hard to tell.
Thank you for alerting me; I'll clean it and keep an eye on it.
[TaSK]
IBA: 33616
Old 04-06-2011, 05:05 AM   #291
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,984
No big deal.
[TaSK]
That is the attitude of an adventurer! Even break downs are part of the adventure, so why not go with it?
Jim
JimVonBaden is online now   Reply With Quote
Old 04-06-2011, 08:22 AM   #292
StYd
StYd's Avatar
Oddometer: 162
2005,75k
Mine too. My sister actually noticed the grinding noise on a lunch ride. No wheel play, top to bottom or side to side, but a noticeable grinding noise on rotation. Got the drive apart, and the bevel gear inner bearing is toast. Got all the bearings and seals on order, and am hoping they dont take too long to get here. About 300$ in parts.
Later, Randy
2005 1200GS
StYd is offline   Reply With Quote
Old 04-06-2011, 09:49 AM   #293
rinho
Rinho Féroce
rinho's Avatar
Location: back in France but Soul still in North America
Oddometer: 1,117
first of all, I don't know all technical word for all these parts...
Mine fails (2 years ago) because the inner part of the bearing on the of the pinion had slide a little bit and had started to grind the diff case (I was told if happens frequently)
Resulting in an oil pollution and the bearings "beginning of the end"
However I was able to ride several hundred KM without being worried
Leak appears right after a highly muddy weekend (GS Challenge)...
Maybe the leak had nothing related to the diff "on his way" failure, but at least it helps me see it before it turn into drama.
I replaced the part myself, but I bring the diff to be adjusted by a BMW mecanic master.
IMHO, the preload adjustment is the key to have the diff lasts long.
I even think the preload should be re-adjusted during the bearing life
Sans un sou mais plus riche qu'avant
rinho is offline   Reply With Quote
Old 04-06-2011, 10:27 AM   #294
Anorak
Woolf Barnato
Anorak's Avatar
Oddometer: 33,975
It's all part of the adventure. Why not go with it?
Because it's trouble and expense you shouldn't have to deal with.
Old 04-06-2011, 03:54 PM   #295
def
Ginger th wonder dog
def's Avatar
Oddometer: 10,200
I agree...if the preload is set correctly and lubrication is maintained, a FD failure probability is dramatically reduced.
def is online now   Reply With Quote
Old 04-06-2011, 05:13 PM   #296
rinho
Rinho Féroce
rinho's Avatar
Oddometer: 1,117
Right, and that's why I change the diff oil when doing the engine oil... to check and be sure the oil is not contaminated
Old 04-08-2011, 07:16 PM   #297
Enprize
Oddometer: 82
No big deal.
[TaSK]
Pullers are nice, as you can see from my photos I had to chisel mine off half way down the copper canyon! Next time I carry a puller too.
www.motorcyclebum.com
Enprize is offline   Reply With Quote
Old 04-09-2011, 07:07 AM   #298
MotoPerro
God Bless Texas!
MotoPerro's Avatar
Oddometer: 9
No Failures...Yet
On two oilheads with ~70K combined no failures yet, but it's always in the back of my mind. I bought BMW so that I would NOT have these types of failures. Lately, I've been re-thinking the simplicity of the chain. Chains typically don't just fail and leave you stranded. You get plenty of opportunity while cleaning and lubricating to inspect sprockets and chain for wear. If you don't take preventive action, then shame on you (or me!). Just MHO.
MotoPerro is offline   Reply With Quote
Old 04-09-2011, 07:59 AM   #299
kubiak
Oddometer: 4,829
i always thought if they had a belt drive on the gs that would be nice, they would have to enclose it somehow though to keep debris out. then just carry a spare belt if it ever needed one.
Times are GMT -7.   It's 07:40 PM.
