Old 03-10-2011, 04:27 PM   #61
Abdelhub
Blanco Trasho
Abdelhub's Avatar
Oddometer: 727
Looks Fantastic. Keep up the good work!
Mike
the most valuable bike i own hasn't run in 20 years...
http://www.youtube.com/abdelhub
Abdelhub is offline   Reply With Quote
Old 03-10-2011, 11:47 PM   #62
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
Sweet, nice job. BTW what powder coating unit are you using?
Annony, I bought the system from Powder by the Pound it's called a:
SPECTRACOAT ES01-C POWDER COATING GUN SYSTEM
It's better than the Harbor Freight, Eastwood, Sears guns, but it's not really a professional gun. It can also be upgraded in the future to use their:
PSS ES PRESSURE HOPPER AND CONSTANT FLUIDIZING HOPPER
So far I'm pretty happy with the gun.
Had some "fish-eye" problems in the past and thought it was because of a contaminated batch of black, but it reared it's ugly head again yesterday. Had to grind and repaint some parts and the next time through it came out better. We think we may have isolated the problem, but need to run some more tests to be sure.
Life is short, live and enjoy it !!!
05' BMW R1200GS - If you can only afford one bike...
06' VStrom 650 - Fond memories (gone)
06' Suzuki DRZ400 - Wish I could afford two bikes (gone)
S.O. Bikes
07' VStrom 650 ABS (Silver)
05' VStrom 650 (Red) - Sold to get one with ABS
tenorjazz is offline   Reply With Quote
Old 03-11-2011, 12:00 AM   #63
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
I finished powder coating the shocks and I'm real happy with how they turned out.
They are from a 1970 BMW. I wanted to rebuild a pair of Bultaco shocks I have, but these were in much better condition so I thought I would use them for now and maybe try to fix the others later on.
S.O. Bikes
Old 04-06-2011, 10:16 AM   #64
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
Been busy working on the bike, but not going as quickly as I hoped. However it is coming along.
Cleaned up the forks and got the front wheel and brake done. Here's how that is looking:
Not real happy with where the brake cable has to go with this brake support, so I'm rebuilding it. Should have some pictures of the finished piece in a few days.
I cleaned up the rear wheel, brake and installed the new rear sprocket. Stuck everything on the bike, including the engine, so I could check alignment.
When I got the bike, the motor and wheel were attached, but there wasn't a chain. So when I wrapped a chain around the sprockets, I discovered a problem.
I knew the frame was modified and so I inquired about what changes were made, I found out the foot pegs had been reinforced. Yep!
In case you are wondering, I did get the slack out of the chain and tried to run it under the "new support" and still have a problem.
Looks like I might need to modify the frame again!!
S.O. Bikes
Old 04-06-2011, 12:05 PM   #65
blaine.hale
blaine.hale's Avatar
Oddometer: 3,104
I like that it's so small/light that you have it in a bicycle clamp. haha!
1974 BMW R90 /6
1968 Bultaco Matador MK3
1973 BMW R75 /5 Toaster LWB
1969 Bultaco Bandido MK2
2013 Husqvarna Terra TR650
blaine.hale is offline   Reply With Quote
Old 04-06-2011, 12:27 PM   #66
PSchrauber
PSchrauber's Avatar
Location: Summer: Kemiö, Finland; Winter: North Germany
Oddometer: 857
Mmmh, I don't think so, you dont have the chain thigtener installed, a Bultaco should have a Chain thigtener,
there is one for the primary drive and there should be, - as I know - one for secundary chain drive too,
without tensioner the slack as you mentiones would be to big. (There shoul otherwise be no way to get
the chain proper installed, the distance between rocker axis and front sprocket axis is too long) *(1
One other thing to not, You should to warp around a bit of a rubber tube
to the rocker axis, that's what I did to my model 221 Sherpa. There You
can also see the chain thigtener
Like here:
*(1 Is the security plate for the front sprocket nut already bend down, I couldn't see this on the picture???
PSchrauber screwed with this post 04-06-2011 at 12:34 PM
PSchrauber is offline   Reply With Quote
Old 04-06-2011, 12:38 PM   #67
PSchrauber
PSchrauber's Avatar
Oddometer: 857
Here a drawing of the chain tensioner, the part with the circeld numbers 9 and 12:
Old 04-06-2011, 02:41 PM   #68
blaine.hale
Oddometer: 3,104
What did you use to blast the engine casing? I'd like to do mine without outsourcing it but can't seem to find anything practical.
I've been looking mainly at soda blasters but I feel like I'd need something coarse to clean the cast like you did.
1974 BMW R90 /6
Old 04-07-2011, 12:41 AM   #69
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
Like here:
The only security washers I have are all messed up but I just got a new one and haven't installed it yet.
I like the idea of a chain tensioner, but I'm guessing they weren't used till 1967 or newer...
Here's some shot's of new bikes with the tensioner:
These bikes are more my vintage and I don't think they have chain tensioners on them:
I might still go with a chain tensioner rather than modify the frame, any opinions??
S.O. Bikes
Old 04-07-2011, 12:55 AM   #70
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
I tried soda but didn't like the results. I have been using glass beads for everything except the frame. I turn the pressure down to about 75-80 for aluminum and most of the steel work, but I shoot unregulated pressure for the really tough stuff. It's anywhere from 135 down to 90, where the compressor kicks back on.
I have a blast cabinet from Harbor Freight that leaks like a bad boat and it uses a syphon gun. For the frame I used really clean 70 grit sand from a brick supply place and had to use a pressurized tank system (also from Harbor Freight), outside, because the frame didn't fit in my blasting cabinet. The sand and pressure tank will strip just about anything.
I'm planning on building a bigger blast cabinet so I can do my next bike completely with glass beads, which leaves a much nicer surface, and work completely inside. Working outside really sucks!!
Bead blasting uses huge amounts of air so you really need a big compressor and if I am doing a lot of blasting I hook up a second compressor so it will keep up.
S.O. Bikes
Old 04-07-2011, 07:05 AM   #71
PSchrauber
PSchrauber's Avatar
Oddometer: 857
You have a support for a chain tensioner, I personal would use him.
As already mentioned without chain tensioner and with the big rear sprocket and the "hughe distance between rocker axis and front sprocket axis, there is no chance to get it work proper.
We don't have to forget the rear shock and the differences of chain
lenght you need when the rear shock is completly submerged.
Also the older bikes one had one, like this bike here:
It is maybe not original but it is a invention in matter of technic, maintance, durability and comfort.
The small version would be the installation of a chain roller on that pin like it is used on MX bikes.
By the way, the chain looks small too, surly not an 520?
Old 04-07-2011, 08:51 AM   #72
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
The chain came off another Matador so I think it's probably right. But it's not put together yet, I just hung it on to check alignment.
Since I don't have a chain tensioner, can anybody recommend where I could get one that I could make work?
S.O. Bikes
Old 04-07-2011, 10:24 AM   #73
darmst6829
Oddometer: 369
Hi Les,
I have one for you, I also have some nylon stock and maybe we can make a chain guide out of the stuff.
Dave
darmst6829 is offline   Reply With Quote
Old 04-07-2011, 12:32 PM   #74
tenorjazz OP
tenorjazz's Avatar
Oddometer: 263
Cool!!
I was kind of thinking of trying to build one out of a front sprocket, but I'll come by and see what you have. Probably would work just as well, for a trials bike, and would be easier and more authentic. Also need to pick up the exhaust gasket.
S.O. Bikes
Old 07-01-2011, 08:12 PM   #75
PSchrauber
PSchrauber's Avatar
Oddometer: 857
Cool!!
It's some couple of weeks ago you posted this. Did you made any progress to your bike, still haven't seen it here in complete rebuild which would be very very nice to see!
BTW: if not no problem, I'am also not ready yet but I have the impression that I can catch up with your progress in rebuilding, which I never thought in forehand.
Times are GMT -7.   It's 09:56 AM.
