Old 03-23-2011, 04:38 AM   #166
Motorfiets OP
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Originally Posted by Oso Blanco View Post
Good choice. You'll be happy with them I'm sure
It's all your fault that I'm going pelican...
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 03-23-2011, 03:59 PM   #167
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,513
No, it's your fault for dropping the bike and smashing the Holans!
Camel Tank auxiliary fuel tanks for KTM 1050/1190/1290 and F-series BMW twins. www.Camel-ADV.com
Camel ADV is offline   Reply With Quote
Old 03-23-2011, 06:45 PM   #168
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
Originally Posted by htmon View Post
Hi,
Great bike by the way!
I have the Holan Pannier racks on my bike.
How do you find getting the centre stand down with the rack mounting on the pillion pegs.
I find it near impossible with my riding boots on to get enough purchase on the centre stand.
If you have fixed the problem please let me know.
kinda use my lower leg to lever against the footpeg in the down position... dunno... seems to work for me?
Ben
My Photo's
Old 03-25-2011, 10:45 AM   #169
ride2little
MoveAlongNothingHere
ride2little's Avatar
Oddometer: 1,988
What are you going to do about tires?
What do you plan to run?
Carrying extra?
Got shops planned out along the way?
~MK~
BMWF800GS
KTM 400 EXC
AMA-262640
ride2little is offline   Reply With Quote
Old 04-07-2011, 03:47 PM   #170
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
Latest Installment...
As many of you know, no one makes crashbars that will fit fit the Touratech Tank (TT.) After doing much research as to what bars are avalible, I asked the dumbest question. "What crashbars offer the least protection?" Givi popped up in my search along with other companies but they all offered high "hoops" that covered the fairing. With the TT tank sticking well beyond the dimensions of where the fairing used to sit these hoop designs would simply A) work but require alot of fabrication or B) simply require too much fabricating that a custom self bent tubing would be easier. After get much laughter asking around for the least protecting bars I bought the Givi bars. When they came in I was truely excited being that they almost fit perfectly with out any modification! Don't get too excited on me now.... they do require some! which I will gladly do for anyone if they do not feel comfortable enough doing alone..... NOW enough BS and lets get to the pictures!!!
First is how the look on a normal none TT-ed F800GS
Now take note of the cross brace connecting the two "halves" so to speak. the bolt, spacer and welded bolt tabs are on the bottom....
again
enough of other peoples bikes!!!
urgh! slow internet.....
Ben
My Photo's
Old 04-07-2011, 04:27 PM   #171
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
Success!!
just everyday looking GIVI's right?
but! mine mount backwards!
example of where the original mounts would be
the trick
by cutting off the cross braces off the bars and switching sides with them.... right goes left and left now goes right... they flip upside down and clear the TT bracket
original holes
now they DO fit tight.... no touchy to the tank but close
adventure spec taken down with the plasma cutter
now many aren't gonna like the closeness off the bars.....
my solution:
the red tape to the top bolt shows a hole, grind off the tab, rotate it on the tubing but to be more vertical down.... all this still pivots on the lower front bolt.... no problem aye? not so easy.... the lower tab then contacts the engine casing.... no good! but can be modified! however by doing all this you once again raise the cross brace vertically and ever so much closer to the TT bracket which is what started this all....
rotates here:;
tab weld grinded off and spun off tubing causing it to spin backwards thus creating more room but more problems....
Ben
My Photo's
Old 04-07-2011, 04:35 PM   #172
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
sneak peak!
who said you have to mount pelicans like normal panniers on holan racks?
Ben
My Photo's
Old 04-07-2011, 10:22 PM   #173
Camel ADV
aka Oso Blanco
Camel ADV's Avatar
Oddometer: 1,513
Looking good!
Old 04-08-2011, 08:06 AM   #174
LukasM
Oddometer: 5,427
Nice work on those Caribou latches! I contacted Roger a while ago since I was also considering the Pelican cases on a Holan balanced rack, but he said he doesn't make them to fit 18mm round tubing. Looks like you figured it out, now he just has to copy and perfect it for mass production.
Old 04-09-2011, 08:34 AM   #175
ebrabaek
Oddometer: 4,873
Nice........ FYI....... Contour now has the app for the blue tooth hookup to use your smart phone as a controller, and display....In case you have not seen that....
Is that scrape marks on the side of the tank.........How deep are they???? Looks nasty....or just superficial........ If you don`t like the wind noise on the contour..... I hacked mine.....and installed a wired mike that I clip inside the helmet, and are now able to hear other things...... Like @$#%&...and Ohhhh....no.....
Erling
Old 04-09-2011, 09:30 AM   #176
KnuckC
F8er
Oddometer: 199
Nice job but your capacity on the pannier is pretty limited.
KnuckC is offline   Reply With Quote
Old 04-09-2011, 09:34 AM   #177
inmate-n00b
Ciao, Marco
inmate-n00b's Avatar
Oddometer: 1,006
I was wondering if you could give some details on your wheels from Woodys.
Did you go with the 50/50 (street/dirt) version?
Are they the oem size?
Did you get them sealed or "nuetech tubliss"?
Thx.
inmate-n00b is offline   Reply With Quote
Old 04-09-2011, 12:57 PM   #178
fastredbike
out riding
fastredbike's Avatar
Oddometer: 542
wow
Did not know about that app, just looked it up... very, very cool - ordering now!
thanks Ebrabaek!!
fastredbike is offline   Reply With Quote
Old 04-09-2011, 01:45 PM   #179
ebrabaek
Oddometer: 4,873
thanks Ebrabaek!!
Yeppers.......
Erling
Old 04-09-2011, 09:11 PM   #180
Motorfiets OP
Motorfiets's Avatar
Oddometer: 2,997
Looking good!
problem is you gotta weld the tabs onto the frame... not a big deal but little bit of work involved...
Originally Posted by ChiTown View Post
Awesome!
Nice work, thanks for documenting it so well.
Now I have to figure out what I'm going to do... would be great if I could salvage my SW bars and do a similar mod.
Cheers
You bet SW-motech's have the top loop i was talked about... but did at one point consider getting something like them and running a cross brace thru the frame and bolt both sides much like the adv-spec stuff
Erling
saw that! looks really cool! problem is I dunno if its worth the money for me at lease!
not too deep at all really.... the tank is durable as all get out!
Thx.
just had the front wheel superlaced with an excel rim smaller size... more narrow... none tubeless and still 21"
Ben
My Photo's
Times are GMT -7.   It's 11:28 PM.
