Old 04-10-2011, 10:59 AM   #1
The Raven OP
The Raven's Avatar
Oddometer: 4,811
airhead cyl compression question
This question is in my thread, but figured I would toss it out to all to get some more responses.
My r80 when cold has 80lbs compression in the left cylinder and will not immediately fire. My right cyl when cold is 115lbs
The valves are in tune at last check and the tapping sounds fine when started.
Today I tossed in some marvels mystery oil and let it sit a few hours. Blasted it out, tossed the plug in and she started fine. Well with a bunch of smoke
I let it run a couple minutes to burn the oil out then did another test. Left cylinder went from 80 to 122, right cyl went from 115 to 125.
Thoughts?
I'm guess a stuck and rusty ring from winter condensation?
The Raven is offline   Reply With Quote
Old 04-10-2011, 11:03 AM   #2
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
carbs off, or at least sliders held up and open?
if so, and oil brings up the readings that much, RINGS.
but even still it is a little low.
How many miles on the valve job?
What's the leak down test tell you?
It's actually the better, more important of the two tests.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 04-10-2011, 11:13 AM   #3
The Raven OP
The Raven's Avatar
Oddometer: 4,811
Oil actually brought it to about 165 from 80
After I burnt the oil out and got it to stop smoking it dropped to the 120s and inline with the RHS.
Not sure how to do a leak down test?
10k on the valves
Old 04-10-2011, 11:39 AM   #4
The Raven OP
The Raven's Avatar
Oddometer: 4,811
OK, did the compression test with the cyl at 90 degrees F, carbs off, both plugs out and grounded.
Results:
L&R 132lbs of compression.
This still does not explain the the low compression while cold. Will be interesting to see the result tomorrow after it's stone cold.
Old 04-10-2011, 11:49 AM   #5
herman maire
Oddometer: 164
My r75/7 after not running for 20+ years before I got it, I tested it cold since its not running yet at there even at 90psi. its on the low side but I hope it increases like your bike did.... I dont feel like another engine project.
Maybe a good highway run will even your compression out.
herman maire is offline   Reply With Quote
Old 04-10-2011, 01:56 PM   #6
Big Bamboo
Aircooled & Sunbaked
Big Bamboo's Avatar
Oddometer: 3,629
As far as I know...
Compression should be checked when the engine is hot, not "stone cold".
Big Bamboo is offline   Reply With Quote
Old 04-10-2011, 06:32 PM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,160
The G/S doesn't have a high compression ratio, so 130 doesn't sound bad to me. The more important thing is comparable figures side to side, which you now have.
My guess is there was carbon build up you blew out, that was sticking the rings.
Old 04-10-2011, 09:51 PM   #8
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,368
Another thing to consider is that when you introduce a bunch of extra oil to the cylinders, it will take a good brisk ride to burn/blow it out of the ring grooves. I have heard up to 100 miles. I think that is a little excessive, but even if it doesn't take near that long, a good hard ride is needed.
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 04-10-2011, 10:56 PM   #9
jimbee
Airhead Intermediate
jimbee's Avatar
Oddometer: 334
Originally Posted by The Raven View Post
...both plugs out and grounded.
If you don't mind, next time you're doing this, could you please take a picture of how you ground the plugs? This is something that I haven't got my head around yet. many thanks
R100GS for going far, FZ1 for going fast, TE250 for getting dirty, and DR650 for when one of the others needs work
jimbee is offline   Reply With Quote
Old 04-11-2011, 03:19 AM   #10
The Raven OP
The Raven's Avatar
Oddometer: 4,811
No need for a photo.....take plugs out, insert into wires, then rest plug on the head, ground accomplished.
Old 04-11-2011, 07:49 AM   #11
mykill
odd
mykill's Avatar
Oddometer: 1,166
self healing?
My Norton came to me after sitting for 10 years. I did an initial compression test and had 80# in each. Fired it and rode it a bit and have had 128# in each ever since. Your rings just need to get friendly with the barrels again.
Leakdown is the best diagnostic test.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Old 04-11-2011, 08:19 AM   #12
bpeckm
Grin!
bpeckm's Avatar
Oddometer: 5,813
I'll second that! I would not obsess over it... though I know how we feel after a winter's wait....
XS650 becomes a VT BackRoadRunner
Loving the 80ST
I love projects that take twice as much effort as should be needed. Should be an Airhead motto. (disston)
bpeckm is offline   Reply With Quote
Old 04-11-2011, 10:34 AM   #13
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,708
just pull the hot wire from the coil, no need to worry about loosing the ground
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 04-12-2011, 09:03 AM   #14
jimbee
jimbee's Avatar
Oddometer: 334
Hey neat idea.
The reason I was asking because I've always been curious about snowbums "other" method for carb sychronization, but after reviewing his tome, I see now that it does not involve removing the plugs.
Old 04-12-2011, 10:05 AM   #15
One Less Harley
Oddometer: 4,708
Of course you know I'm not referring to the high tension lead from coil to spark plug, but the actual power leads to the coil!! Also for compression test not synch.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Times are GMT -7.   It's 05:38 AM.
