Old 04-18-2011, 11:33 AM   #1
hrach1 OP
hrach1's Avatar
Oddometer: 192
Does anyone know which wire is the high beam wire?
Hello fellow GS riders. I have a 2010 F800GS and I want to install the auxiliary driving lights. I have done this before with my other BMW bikes where I would attach the trigger wire to my high beam wire that comes out of the high beam switch. However, I am having difficult time finding the wire on my F800GS.
Would anybody know which color wire is the high beam trigger wire?
Any help would be much appreciated.
hrach1 is offline   Reply With Quote
Old 04-18-2011, 12:16 PM   #2
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
give me till later tonight to tell you....
I'm gonna take my front fairing off later to re-do some work on fuel lines and I'll see which wire I spliced.... basically did the same thing
Ben
My Photo's
Motorfiets is offline   Reply With Quote
Old 04-18-2011, 12:23 PM   #3
hrach1 OP
hrach1's Avatar
Oddometer: 192
Thanks a lot!!
Old 04-18-2011, 01:54 PM   #4
JoelWisman
JoelWisman's Avatar
Oddometer: 1,392
At the headlight plug.... The white wire is the switched 12v positive for high beam.
I don't know what color the wire would be at the switch, nor do I know if that wire at the high beam switch is switched 12v or CANbus talk to the ZFE.
A lot of switches on the F8 are CANbus talk to the ZFE. I wouldnt use any other point to tap for a trigger other then the white wire that plugs into the headlight unless someone else has already tried it and NOT burned out their ZFE or screwed up the CANbus.
Owned to date. Honda Aero 50, Honda Elite 80, Honda Elite 250x2, Suzuki Katana, Suzuki RF600, Yamaha YZF1000R, Kymco Xciting 500, Suzuki GS500, Suzuki Burgman 650, BMW F800GSx2, BMW S1000RR, Aprilia Scarabeo 200, Aprilia Caponord, Aprilia Sportcity 250
I love and miss you Jeneca and I'm sorry.
JoelWisman is offline   Reply With Quote
Old 04-19-2011, 02:19 AM   #5
hrach1 OP
hrach1's Avatar
Oddometer: 192
You are right! I better take it from the back of the head light.
Thanks for the advice!.
Old 04-24-2011, 08:21 PM   #6
Dockstrada
Dockstrada's Avatar
Oddometer: 238
Hey hrach1,
This is the high beam wire running through the harness; it’s just tucked just under the air duct, as you can see I cut away the black tape insulation to expose it and tapped in to the white wire to activate the relay.Its working great not a problem .
Hope this helps
Dockstrada is offline   Reply With Quote
Old 04-24-2011, 08:36 PM   #7
hrach1 OP
hrach1's Avatar
Oddometer: 192
Wow,
Thanks a lot!
Taping into the wire is much easier from here. Thanks again!
Old 04-29-2011, 06:16 AM   #8
Flashback
Mommys Lil Monster
Flashback's Avatar
Oddometer: 3,079
Question. Does that mean that you aux lights come on when you flip the high beam switch or do they have a separate switch?
DON'T PANIC
Flashback is offline   Reply With Quote
Old 04-29-2011, 10:14 PM   #9
Dockstrada
Dockstrada's Avatar
Oddometer: 238
I have the Aux lights on a seperate switch ,in this way you can have a choice of only OEM high beam or both OEM high beam and aux spot lights .
Old 05-01-2011, 09:31 PM   #10
dacrazyrn
ED RN Adventurer
Oddometer: 495
There happen to be a blue and white wire (hopefully from the turn cancel switch) lurking about in there? I am installing an Autoswitch for the Floods and gonna hook the Spots into the High beam wire. Good to know prior to cutting away (and getting the side panel off).
Tracy E / Photos4Aidan.com / dacrazyrn.dpcprints.com / Can you SPOT me?
“When you do things RIGHT, people won’t be sure you’ve done anything at all.” God in Godfellas-Futurama
Life is Risk Management
'09 BMW F800GS-Fate Honeyed GSabelle
dacrazyrn is offline   Reply With Quote
Old 12-07-2012, 03:08 PM   #11
Meritlane
Meritlane's Avatar
Oddometer: 63
if white is the high beam, which is low beam. I want to tap into both for my setup.
Meritlane is offline   Reply With Quote
Times are GMT -7.   It's 11:08 PM.
