04-27-2011, 09:24 PM
#16 | |
Dog Chauffeur
Oddometer: 2,689
![]() The thing is, NortwestRider, is that I really envy you. You have the ability to BUILD stuff. I only know how to MODIFY stuff. What yer doing in your shed is far more impressive than what I do in my garage. I'll definitely look you up in Chelan. |
04-27-2011, 09:35 PM
#17 |
The Road Scholar
I have seen these LED driving lights advertized, but have not heard any reports about how much light they throw out versus the small HID units that are available, or seen any photos showing the light they throw.
Are the current LED lights more for being seen by other drivers or do they actually thow out a beam that puts useful light on the road/trail?
Karl Kugler www.theroadscholar.net 2005 BMW R1200RT w/Hannigan-LT sidecar 2002 BMW R1150RA In Memoriam: Harley, 1993-2010 You will be missed. |
04-27-2011, 09:37 PM
#18 | |
Dog Chauffeur
Oddometer: 2,689
On the other hand, the front end does what any big pig does in the dirt--the front end gets yanked around by ruts and roots and loose gravel and softball-sized rocks. So I'd like to get a regular steering damper--like a Scotts or a Ralle-Moto--but I ran out of money. I tried rigging up a cheapo one of my own design, but failed (thread HERE.) DRONE screwed with this post 04-27-2011 at 10:03 PM |
04-27-2011, 10:02 PM
#19 | |
Dog Chauffeur
Oddometer: 2,689
Of course, I'm no Baja racer. At night, I take it easy. My night vision and my reaction time is not what it was when I was 20. So I don't really need any more light than this, and you could argue pretty convincingly that even this is quite a bit more than what I need. As for the see-or-be-seen thing, the LED bulbs have three levels (high-medium-low) and for daytime driving the low level is as much as you'd want to use for conspicuity. On low, they are really bright. At night, if there was a car anywhere in sight, I'd turn them off completely--too bright at any intensity. |
04-27-2011, 10:16 PM
#20 |
I like it... You did Goood.
'99 Ural Patrol '02 Ural Sahara BC '03 BMW CLC/Ural '06 Honda Ruckus /Sidecar '10 Ural ST Solo http://www.flickr.com/photos/ivanrider/ |
04-28-2011, 07:59 AM
#21 |
Oddometer: 1,104
Looks like Dauntless has seriously beefed up their lower mounts!! What was your build date? Melrone could have benefited from this one. :-(
Did you work with Barrry or Jay? Or Doug?
Olyrider Ob-la-di...Ob-la-da |
04-28-2011, 09:09 AM
#22 | |
Oddometer: 20
iHop screwed with this post 04-28-2011 at 09:47 AM |
04-28-2011, 09:22 AM
#23 |
Que la Chinga?!
Oddometer: 3,140
That is one gorgeous rig!!!!
"...when I handed the 40 ouncer to him, he got that far off stare that a cat gets when it just gets done licking its ass for the last 15". Yeah, THAT stare." -WTF-Over |
04-28-2011, 09:58 AM
#24 | |
Dog Chauffeur
Oddometer: 2,689
After I bought it, I took it to Jay for the car pusher conversion and the electric tilt. Doug did the work and also remounted the struts and did the alignment. So I didn't have to do any of that stuff. Credit for the easy steering and straight running is all DMC's. As for the bike, the PO did the canisterectomy, removed the ABS modulator, installed the Y-pipe, and he was the one who figured out the cool double-relay configuration for the offroad lights. DRONE screwed with this post 08-30-2012 at 11:02 AM |
04-28-2011, 10:21 AM
#25 | |
Dog Chauffeur
Oddometer: 2,689
I also wonder if because my rig runs so straight and true, with no wobble or shake, if maybe my struts won't develop metal fatigue as quickly as some other rigs where the stresses and strains are more or less constant. It's kinda nice living only 30 miles away from the DMC shop. If I have any troubles, it's not a big deal to get the rig looked at. I might even take it in there next month to brainstorm with those fellas. The problem with the 1150 is that there's no good place to attach a strut forward of the cylinder head. It can be done, but it would involve so many extenders and angles and joints that I'm not sure how much good it would do. Edit--Yeah, it did break, in June of 2012 after maybe another 10,000 miles, many of them on dirt and gravel. This rig has not been babied! Here's a pic-- ![]() But the struts are pretty robust. I had no trouble driving another 300 miles with the broken strut to Enumclaw where DMC was able to fabricate Jay's retrofit solution for this problem. Sorry for the bad pic-- ![]() Basically, they weld a collar around the frame then drill it and weld in a solid mounting post that's welded on the top and bottom of the frame. Much stronger than before. In defense of the DMC design, I must mention that the P.O. had mounted the car totally wrong (both lower struts upside down) and the frame got 4500 miles of abuse before that situation got fixed. Jay told me that the upside down strut mounting put extra strain on the upper front strut, and he warned me to keep a close eye on it six months before iHop mentioned it in the post above. DRONE screwed with this post 01-03-2013 at 03:05 PM |
04-28-2011, 10:43 AM
#26 |
Oddometer: 1,104
Dmc
Drone,
You might PM Mr. Cob, and see how he's addressing this on his 1150GS Dauntless build. He's been pretty tight-lipped about it on the board, but he might open up in a PM. Don't know, but worth a try.
04-28-2011, 11:34 AM
#27 | |
Oddometer: 500
Dauntless subframe and mounts bought new in 2005. ![]() Went then with Claude (picture taken before powder coating), cannot be more please with the result. No further comments necessary when you compare the 2 subframes and mounts, and for the same price!
04-28-2011, 05:53 PM
#28 |
Another Angry Hun !
Oddometer: 708
Passenger ????
Drone
Nice finish work your taste is excellent ! What's the name of that dark German sitting in it and is he or she a standard or a giant ? A real question, Does the gearing with the 15" wheel seem low enough ? DB
Patience: A minor form of despair disguised as a virture. Ambrose Bierce |
04-28-2011, 07:32 PM
#29 |
Oddometer: 64
WOW!
The Moon is mine, not Felix! |
04-28-2011, 08:54 PM
#30 |
Dog Chauffeur
Oddometer: 2,689
Bear in mind that my 1150 is an Adventure model with a lower gear ratio for 1st gear. And the car wheel/tire combo I'm using works out to the same outside diameter as the stock BMW wheel/tire combo. So I have plenty of grunt for the kinds of roads I go on. Which is to say, paved roads and dirt roads. I don't go on trails or tracks (my name's not Cob) and I'm not trying to out-Ural the Urals. Hell, I'm not even trying to out-Ural the KLR's! I just like getting out into the backcountry.
Oh, and he's a giant, but the runt of his litter. |
