Old 09-29-2010, 05:39 PM   #1
ebrabaek OP
Oddometer: 4,759
Talking Hid install .....With pictures......
I know that there are other threads covering this install...... But none of them covers any before and after pictures....... So I thought I`d post a new thread. I also decided on a little different mounting than most decide to do. I looked at it once.....and......ehhh.... yep..... one.....must.....make......a....carbon fiber....bracket....... Really..... Most people elects to put the ballasts on the middle bracket behind the brake line..... I wanted to illustrate a different way to make a composite bracket. Most of the composites I make....is on the outside......, but this stuff ,can be used in many applications. This one took a total of 30 minutes to make. I wanted the ballasts up in the front behind the fairing.......And first had to make a bracket that would serve as a mold for the composite.....
Then cover it with aluminum foil so the epoxy won`t stick.......
I used 4 layers of 5.7 oz. 2x2 twill carbon fiber......max-clr hp epoxy....... Done and installed the ballasts.........
I will route the wires in the morning........and post back tomorrow night....with the after pictures. The HID`s are H7`s from 1off motorsports..... I used m4 ss hardware....and 3 threaded 3/4 inch collars...to create a 6mm space between the ballasts for cooling purposes. I called and asked 1off motorsports....they said that I could mount them on top of each other.....but just to be safe......Until then.....
Erling
Old 09-29-2010, 07:36 PM   #2
BMW_BIKER_KEITH
BMW_BIKER_KEITH's Avatar
Oddometer: 395
I installed one of their HIDs as a replacement for the low beam... Awesome bright lite! I see you are installing two... so are you also replacing the high beam with HID, or are you going to totally blow us away and somehow intall them on those new CF handguards?
Inquiring minds.... O)
BMW_BIKER_KEITH is offline   Reply With Quote
Old 09-29-2010, 08:00 PM   #3
ebrabaek OP
Oddometer: 4,759
Hi-Hi..... Evil genius at work..........Nahhh.... In the future....there will be a set of high power led blinkers in the guards.......... The other is for the high beam. Not the norm..... But here in the desert southwest.... when I ride at night..... I do use the high quite often...... Whereas if you live in La....perhaps not. Like in many car applications, where only the low beams are hid`s.....when you flick on the highs.... It`s a very disappointing result. Lots of people states that it does not work for flashing...... But in all practicality.... After the arc has been struck once while riding...... It flicks on very fact.... every bit as fast as it`s halogens counterpart. So I opted for the dual setup. Another thing...... The 1off motorsports setup strikes the arc at a full 55watt, so not to create any issues with the canbus..... When it stabilizes..... It lowers to 35 watt.... The latter I confirmed with a amp meter.....
Erling
Old 09-29-2010, 08:03 PM   #4
ebrabaek OP
Oddometer: 4,759
So for starters.... Here are the before pictures....with stock halogens..... Among some of the best stock halogen MC lights....imho......
Low beams.....
High beam......
We shall se tomorrow......how many hot spots the hid`s will create......
Erling
Old 09-30-2010, 03:09 PM   #5
ebrabaek OP
Oddometer: 4,759
In routing the wires....I found it much easier to feed the loom through the 7/8 inch hole I just drilled....If I took apart the feed connector..... You use a small screw driver to push on the little pin inside....then the plug slides out....
Then after feeding it....when you put the connector back together....this is the little tap you bend in the prior step....bend it back again....insert the prong in the plug.... Note where plus and minus is....
This is how it looks out of the housing.....
Then zip tie the wires in the front...
Then re-check all is working.....
Time for a few shots of espresso.....wait until darkness.....I`l post a few pictures later.......
Erling
Old 09-30-2010, 05:46 PM   #6
TowPro
Lets ride
Oddometer: 3,217
When you turn the front end, how bad does the brake hose get tied in your wires? I brought my HID connector out the same place, but had to pull the wires to pretty much a right angle at the rubber connector to keep the brake hose from hitting on them.
I plan on adding bar risers at some point, so that will move the brake hose out of the way a little :)
2015 KTM 690 Enduro R
2014 R1200GS - My Naked Street Touring Bike
2000 KTM LC4 640 E - currently up for adoption with 3200 miles
TowPro is offline   Reply With Quote
Old 09-30-2010, 06:29 PM   #7
ebrabaek OP
Oddometer: 4,759
Not at all..... But I have a 19 inch brake line rather than the standard 17 inch.... Plus my cockpit is raised about one inch,
So perhaps mine is not the best to compare with.....
Erling
ebrabaek screwed with this post 09-30-2010 at 07:34 PM
Old 09-30-2010, 07:41 PM   #8
ebrabaek OP
Oddometer: 4,759
Pictures....before, and after...
Here are the comparison pictures...... Same road..... Same parked car in the front.......
Halogen low beam....
Hid low beam......
Halogen High beam......
Hid High Beam.......
The first thing that gave it away.... was the fact the camera had trouble focusing on the halogen low beam...... When the halogen high beam was added...it was fine..... It focused fine on either Hid beam..... The picture of the halogen is " enhanced " by the camera`s shutter, and is really yellower than it appears. In general this very great stock light is now greater......with very little hot spots. Very pleased.......
Erling
Note......The beam drop is not identical..... I goofed and took the first pictures ( stock halogen) with the bike on centerstand....., and HID off the center stand with me standing up straddling the bike..... Sorry I did not catch that It really only has an affect on the low beam...... as the stock halogen high beam is illuminating the house far down the street...... Note as well that you can make out the fence in front of said house with the hid......Not really with the halogen.
ebrabaek screwed with this post 10-02-2010 at 04:33 PM
Old 10-02-2010, 02:55 PM   #9
MSH
The Salt
MSH's Avatar
Oddometer: 3,213
Did I miss? What kit and how much?
~KTM 640 Adventure R~
"Lately it occurs to me what a long, strange trip it's been"
MSH is offline   Reply With Quote
Old 10-02-2010, 04:28 PM   #10
ebrabaek OP
Oddometer: 4,759
1offmotorsports.com...... $89 for low beam....$159 for both low/high..... Bought it from San Diego BMW....but you can purchase it directly from 1off.... They have great cust. service....and guarantee their stuff for life..... Nice....
Erling
ebrabaek screwed with this post 10-02-2010 at 04:36 PM
Old 04-30-2011, 06:30 AM   #11
SportFaller
Dirt dont hurt, MUCH
SportFaller's Avatar
Oddometer: 668
I may be resurrecting a dead thread....but,
Its been a few months now, have you noticed any damage to the reflector? There has been a fair amount of talk about the HID's melting the reflectors and lenses....
Any comments? I have a set of aline HID's I'm debating on installing.
"The chokers, and the chain saws, and the log trucks have been stilled, now spotted owls, and hippy gals, run freely through the woods!"
Bikeless in WY
http://www.dakotadualsportriders.com
SportFaller is offline   Reply With Quote
Old 04-30-2011, 07:05 AM   #12
ebrabaek OP
Oddometer: 4,759
I have put a few thousand miles on it, and have looked carefully for the plastic discoloration..... Mine still looks like new. They draw less energy than their Halogen counterparts..... Only thing I`m not sure about...is the UV radiation..... That`s what seems to get to any plastics. I`m in the desert southwest....so we have plenty of that as well. I`d do it all over again. The light pattern is awesome.....with very little hot spots.....
Erling
Old 04-30-2011, 12:34 PM   #13
TowPro
Lets ride
Oddometer: 3,217
Now that you have been riding with it for some time, do you have a problem with the way the high beam turns on slowly compared to a halogen?
I been thinking of doing the high beam also, just never got around to it yet.
Old 04-30-2011, 01:48 PM   #14
ebrabaek OP
Oddometer: 4,759
Personally no..... But I have never used the high beam to flash people. You se.... here they will just look at you like deer in the head light...... Not having a clue as of why I`m high brighting them..... But In Scandinavia....before I moved over here.... It was a very useful tool. If you want to cheat.... You can drive for a minute or two...with the high beam on.... then turn it off.... The capacitors will remain charged....and your high beam will strike the arch a lot faster. I am contemplating a set of LED aux spots..... But just have`nt done it yet. They would work fine....if the high bright flashing was a necessity. I`d do this mod all over again....
Erling
Old 04-30-2011, 07:13 PM   #15
TowPro
Lets ride
Oddometer: 3,217
Erling
I notice with mine when I first start the bike (in the dark garage) the HID flashes like a flash on a camera. I bet when you hit the flash to pass it would do the same thing. Of course someone will tell us it's bad for the bulb, but I bet they still last longer then the stock bulbs do. Plus if you shop around, there like $50.00 a pair with digital ballasts so the don't cost much more then a stock set of stock bulbs. Of course I can't buy a replacement HID in any auto store, but the HID's leave the stock plug on the wire harness, just plug in a stock bulb if your blow one on the road
Times are GMT -7.   It's 06:49 PM.
