05-03-2011, 11:14 PM
#1501 |
Oddometer: 705
About the decomp cable, I had one made 3 cm longer to make it fit nice and loose because I have 4,5 cm of risers....
M.
ENDURO DALMATIA LC4 Adventure parts for sale: http://s485.photobucket.com/albums/r...%20for%20sale/ |
05-04-2011, 07:18 AM
#1502 | |
crash test dummy!
Oddometer: 2,059
you can see the size diff between those and the rally pegs. the rally pegs are bigger than the stock pegs. laramie
DON'T TRUST CUT 7! HE IS A CROOK! ASK ME HOW I KNOW. '12 LC8 990R, '02 LC4 640, '05 WR 450f (part-out), '98 XR400R, '76 KE100, '05 525 (Step-Child)
05-04-2011, 05:02 PM
#1503 |
old, not dead
Oddometer: 74
Thank's Laramie,
Should the right side be a direct fit? |
05-04-2011, 07:53 PM
#1504 | |
slave to gravity
footpeg extensions
Riff Raff 2012, 2011, 2010, 2009 Skibum Soiree 2012 Skibum Soiree 2011skibum soiree '10 RIP ITsteve, ride in peace my friend save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk skibum69 screwed with this post 05-05-2011 at 05:56 AM |
05-04-2011, 08:15 PM
#1505 | |
Registered Lurker
Ride safe!!!! J There are 3 kinds of people in this world: Those that make it happen- Those that watch it happen- And those that stand around sayin---WHAT HAPPENED? 2001 KTM 640 Adventure R (back home in my garage with a fresh brand new engine! She is purring like a kitten! 2002 KTM 520 EXC (plated) BMW MOA #137435 |
05-04-2011, 08:34 PM
#1506 |
Big Bike, Slow Rider
Oddometer: 490
David 2005 KTM 640A 2008 Wee-Strom |
05-05-2011, 04:01 AM
#1507 | |
Still gettin faster
Oddometer: 939
05-05-2011, 05:07 AM
#1508 |
crash test dummy!
Oddometer: 2,059
yup, the right goes right on without issues. laramie
05-05-2011, 05:55 AM
#1509 |
slave to gravity
Riff Raff 2012, 2011, 2010, 2009 Skibum Soiree 2012 Skibum Soiree 2011skibum soiree '10 RIP ITsteve, ride in peace my friend save $5 on a new smugmug account, use this coupon7frrnSRiTt9Fk |
05-05-2011, 05:30 PM
#1510 | |
That ... Umm ..... "Dude"
Oddometer: 5,260
![]() G.
03 Caponord "The Funness out-weighs the Dumbness ....." - Mr. Jetmoto |
05-24-2011, 09:17 AM
#1511 |
Oddometer: 223
stumble at idle when warm
I posted this last fall on the BST 40 section but I have since replaced the carb with two others with the same results and so I feel I can rule that out.
My 99 LC4 E starts fine and runs good when cold. After its warmed up fully and ridden around a little it starts to stumble at idle and occasionally die. Especially if you try to feather the clutch and go slow but it also does it just sitting there in nuetral. It starts right up each time after it dies but then does it again right away (assuming its stull warm). When I let it sit for a while it starts to run normal but quickly begins the stumble again (as it gets warmed up faster since it didn't sit long enough to become completely cold). Im thinking it has to be electrical. The plug is new and I just cut the tip off the plug wire and screwed the cap back on with no results. Anyone experience the same thing? Im am all ears. Or does anyone wanna buy this bike as is for a discount in the Seattle area?
2005 Yamaha Roadstar 1700 2008 KTM 450 XC (540) ATV 2005 KTM 450 EXC |
05-24-2011, 10:22 AM
#1512 |
Never It's enough
Oddometer: 552
Lot of oil smoke when I cold started the engine
Hi, mates!
I have posted this issue at the thread "KTM 640 Adventure owners, sign in please...", but had no luck. Following the same procedure as always, I have cold started the engine with the choke set to the level which maintain 3.000rpm, until the engine gains 1 line in the temp scale. Then my bike started to produce that smelly grey oily smoke we all know someday must happen... but not with 45.000Kms on the clock... I immediately released the choke, despite I was sure the smoke will keep going out of the exhaust, but... it actually stop. Then I put the engine @4.000rpm and no smoke. Then I put it @5.500rpm, this time riding to my office, and nothing! 1 week later it has never appeared again. What the heck is going on??? I know there must be a reasonable explanation, and I hope it does not include a severe damage... ![]() What do you think, guys? Thanks in advance for your help... . .
'Long Life to Dirt Riders' __________________________________________________ _______ Argentina-Chile-Peru - Home of the Dakar ... again ... and again... and again!
05-24-2011, 11:43 AM
#1513 | |
Still gettin faster
Oddometer: 939
Since It's done this with 3 diff carbs, Check valve clearence. Temp related problem could also be an intermittant open coil. |
05-24-2011, 02:23 PM
#1514 |
Oddometer: 223
Im going to try to check the coil(s) tonight. Laramie posted what the ohms should be for me on TT. I have never done this and dont even know where to put the meter to test. Anyone have pictures?
05-24-2011, 02:28 PM
#1515 |
Oddometer: 8
Check the valves too, I read somewhere it can be the issue if the LC4 dies or is hard to start when hot
