Old 05-06-2011, 09:29 PM   #16
Oso Blanco
Oso Blanco's Avatar
Oddometer: 963
Originally Posted by Motorfiets View Post
With a nut instead of a washer, could that cause my clutch to be tight?
I sent you a PM too. Yeah, on my bike, I can't use the upper jam nut as the inner cable isn't quite long enough to give enough clutch freeplay. I added a washer on the top side in place of the nut. It worked OK.
I had a new inner cable made up an inch longer and re-installed the upper nut, now all is well.
Make sure you lever free play is within spec or you'll risk cooking your clutch.
Camel Tank auxiliary fuel system for F series BMW twins:
http://cameltank.com/
Oso Blanco is offline   Reply With Quote
Times are GMT -7.   It's 01:43 PM.
