Old 05-06-2011, 03:24 AM   #3886
PWRCRZR
Grumpy Old Bastard
PWRCRZR's Avatar
Oddometer: 6,499
It was just a short road but the only one I could find local..I hadn't ridden the old pig in about a month so it was nice to get out and about.
PWRCRZR is offline   Reply With Quote
Old 05-06-2011, 06:50 AM   #3887
Dr. Benny
Enjoying the Journey
Dr. Benny's Avatar
Oddometer: 659
Deals Gap
Motorcycle Mexico DVD - The easy way to prepare for your first motorcycle ride south of the border.
New Hampshire to Ushuaia 2009-2010
Dr. Benny is offline   Reply With Quote
Old 05-06-2011, 08:26 AM   #3888
terb0
terb0's Avatar
Oddometer: 18
Painted with Krylon Fusion Satin and stickered up like a P-40 Warhawk.
terb0
http://www.motorcycling.terb0.com
terb0 is offline   Reply With Quote
Old 05-06-2011, 02:19 PM   #3889
KLR PILGRIM
SICK ASS ADVENTURE RIDER.
KLR PILGRIM's Avatar
Oddometer: 863
Send a message via ICQ to KLR PILGRIM Send a message via Yahoo to KLR PILGRIM
I like it.
Scottland McFowl. U.S.M.C. Ret.
2009 KLR650 BIG BAD AND BLUE!!!!!!!
ADVENTURE RIDER
2009KLR650,Blue
2007KLR650 Red Sold
1975XL350 sold
2007 pontoon boat
2007 Gun Dog,
KLR PILGRIM is offline   Reply With Quote
Old 05-06-2011, 04:19 PM   #3890
fuats
...and for other purposes
fuats's Avatar
Location: Nothing here but potatoes...move along, move along
Oddometer: 6,345
Zoom in on the nose-art!
--fuats (the blasphemer)
"The final arbiter, sadly, will always be violence."
Simple Summation of my Worldview
fuats is offline   Reply With Quote
Old 05-06-2011, 04:41 PM   #3891
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 986
Laugh Here's a 1988 with 166,982 miles on it
She's wearing Hayes Diversified new take-off body work that has spent a few years riding around in the South Carolina sun... where do I start?
Mikuni TM41mm ProSeries flatslide carb w/stock location choke via custom cable; Magura Duo314 quick throttle w/custom cable; Megacycle x5 Camshafts w/KACR; R&D valve springs w/titanium tops shim/over type; Cylinder head mild porting & polished exhaust; custom Kibblewhite stainless steel valves; intake manifold spacer for float bowl/starter motor clearance; stock airbox w/modified openings & airbox/carb boot; K&N prefilter & K&N gauze-type filter; OEM kickstarter option; 3/5 Barnett HD clutch springs; KLR600 muffler; K&N air/fuel ratio monitor w/sensor bung welded to header; ]Magura Jack hydraulic clutch w/custom line & slave cylinder bracket[/URL], spiral metal heat guard, running 2.5wt suspension fluid; Lindemann custom fork springs; RaceTech Gold Valve emulators; custom Fox Twin-Clicker rear shock w/remote resorvoir; Tengai rear caliper carrier & disc protectors; DR650 serrated footpegs on stock welded-to-frame brackets; FZR1000 front turn signals; '88 FZR1000 dual headlight bucket w/custom carrier, relay-protected wiring harness & PIAA Intense White H4 bulbs; Euro headlight switch assembly; FIAMM dual horns w/relay-protection; Renthal Desert CR bars w/ 3/4" removed each end; Maier WoodsPro heavy duty full metal barkbusters; Maier large handguard/cups; EBC 320mm full floater front brake disc; ZX600A3 front brake master cylinder; ZX750A4 BACR-front brake caliper; custom stainless steel brake lines front & rear; 80-LED rear brake/running light bar under luggage rack; 32-LED 1157 rear bulb; Napoleon LH mirror short stem on KLR600 mirror bracket; ScotOiler w/dual-injector mounted in place of LH starter motor solenoid/bracket; redundant wiring & cables ziptied in place for easy trail or road-side replacement; 2RS bearings throughout; FT500 Ascot rear turn signals; unknown brand saddlebag guards in picture now hanging on the wall; Moose bash plate; stupid footpeg-equipped "engine protector" off the bike- a real p-o-s bent into my radiator hose and almost cut it when we fell at 0mph on hydraulic fluid at a stop sign- needs triangulation the square-tubing just kinks (hey it was free); Eagle Mike doohickey & torsion spring; custom 350w stator; Accel HT lead; Electrosport HD regulator/rectifier in custom location; custom engine mount plates & brackets; through-bolts on luggage rack (but not sub-frame!); Renthal RS4 chain w/rivet clip currently geared -1front +3rear running D606 DOT knobbies front & rear (D607s on in this photo w/+1front) An important addition: I used the internals from a ZX600A1 petcock in mine- now I have on, reserve and the all-important PRIME so I don't kill the battery sucking the fuel valve diaphragm back when I run out of gas... and we know how fast singles run out of gas, don't we?
She has worn ProCircuit 496s & a SuperTrapp w/19discs before- great power, just too loud for my liking as I've gotten older, now with the KLR600 muffler the bike is SO quiet I can sneak around at night and no-one's the wiser With the SuperTrapp & exhaust gas analysis I was able to double my stock horsepower and gained almost a 3rd more torque on Factory Racing's Mustang eddy-flow dyno in San Rafael California (thanks Marc!)
She's seen 122mph on flat ground many times (verified off other bikes), now I have a KTM950 Adventure for all that foolishness and max out just over 90 with the lower gearing
All in all the best bike I've ever owned, and has taken me more places and helped me do things I could never have done on another bike.
When my first doohickey failed in 1991, there wasn't even a nickname for this part. The cam chain jumped timing so it came apart @ 18,751 and that is when ALL the engine work was done (by me) with the exception of the 3-angle valve job by Mike Crowther of Engine Dynamics fame on a then-state of the art SERDI Valve Machine (I would eventually work for him years later). I went ahead and put a +0.5mm (1st over) OEM piston as I could get dealer prices back then.
I DON'T use or believe in the PCV valve "fix" (see my "Hoax" post) and she doesn't use oil, period. Having spent thousands of hours in the saddle brings confidence and I ride this thing hard all the time, unless I'm in stealth mode which usually means in a park illegally at night.
I have gotten as high as 57mpg when cruising on the slab... I have a universal windscreen that clamps to the handlebars and attaches in seconds and a throttle lock for making time easy...
This bike has run from the police (successfully 100%) 64 times and been crashed more times than I can remember. I looped a wheelie @ 60mph right after I put the carb on and was running rich- it cartwheeled down the street like it was in a Hollywood action flick- when it was over, I folded out the pegs and rode her home. Try that on a sportbike!
I've ridden cross-country, done Cal24hrs, Nevada1100 & Utah1000 on her, ridden in snow, sand, ice, across rivers and up creeks. I've dualsported her with knobs to the top of 14 states... couriered, Sunday Morning Ride (the original in SF CA), roadraced, barrel raced, track dayed, and taken some girls for the ride of their lives (thanks for being such a good passenger mount, adds to their confidence too)
I know when I get on stock KLRs (any year) I don't like how they feel and can't see how people can own one without modding the hell out of them- mine just fits me SO well now, so well planted
Speaking of I forgot the Fox Twin Clicker is off and a White Power fully adjustable is on her now, so much more compliance offroad as I had the Fox setup for hard, fast street riding in Northern California
she's no garage queen and I wear every scar and dirt with the pride of having been somewhere the guys in the SUVs & Jeeps haven't, and while putting myself at real risk
Brittus
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'88 KLR650 - +170K miles "looks like you've had a lot of fun on that bike..."
geometrician screwed with this post 09-27-2012 at 08:52 AM
geometrician is offline   Reply With Quote
Old 05-06-2011, 04:54 PM   #3892
Motojournalism
motojournalism.com
Motojournalism's Avatar
Oddometer: 1,579
Nice one Benny
I've borrowed that pic for the helmet-cam post on the blog:
Speaking of KLR pics, does anybody have a photo handy of how the choke cable is routed around the bars and forks? (older model)
"Absorb what is useful, Discard what is useless, Add what is uniquely your own" - Bruce Lee
Moto documentary Fifty Years of Kicks at motojournalism.com
Way Out West - Canada to the Darien Gap
Follow me on Twitter
Motojournalism is offline   Reply With Quote
Old 05-06-2011, 06:13 PM   #3893
spectrecat
Oddometer: 12
Originally Posted by Harry94025 View Post
Was a State Park Peace Officer on the San Mateo Coast for 10 years. Had a chance to ride one of those SMCSO KLR's when they were new, up the Old San Pedro Mountain Road, to the top of Montera Mountain, used them to watch over the communications towers at the top, just after 9/11. The SMCSO must have painted them black and white recently, because for years they were the stock silver/green kawasaki colors, they are 2001 models under the new paint.
If anyone is interested in a lightly used BMW R1150 GSP, Half Moon Bay Police has one, and they will most likely auction it off soon, as they will be absorbed by the SMCSO in July.
spectrecat is offline   Reply With Quote
Old 05-06-2011, 07:00 PM   #3894
tumbleweedracer
mmmmm...... dirt! :D
tumbleweedracer's Avatar
Oddometer: 47
Those cop bikes look tough!
Here's one of mine form tonight- I added the grips, seat cover, and painted the boots (no more blue!!!).
tumbleweedracer is offline   Reply With Quote
Old 05-06-2011, 08:02 PM   #3895
tumbleweedracer
Oddometer: 47
WOW! Very cool
Mikuni TM41mm ProSeries flatslide carb w/stock location choke via custom cable; Magura Duo314 quick throttle w/custom cable; Megacycle x5 Camshafts w/KACR; R&D valve springs w/titanium tops shim/over type; Cylinder head mild porting & polished exhaust; custom Kibblewhite stainless steel valves; intake manifold spacer for float bowl/starter motor clearance; stock airbox w/modified openings & airbox/carb boot; K&N prefilter & K&N gauze-type filter; OEM kickstarter option; 3/5 Barnett HD clutch springs; KLR600 muffler; K&N airfuel ratio monitor w/sensor bung welded to header; Magura KTM OEM hydraulic clutch w/custom line, heat guard & line running 2.5wt suspension fluid; Lindemann custom fork springs; RaceTech Gold Valve emulators; custom Fox Twin-Clicker rear shock w/remote resorvoir; Tengai rear caliper carrier & disc protectors; DR650 serrated footpegs on stock welded-to-frame brackets; FZR1000 front turn signals; '88 FZR1000 dual headlight bucket w/custom carrier, relay-protected wiring harness & PIAA Intense White H4 bulbs; Euro headlight switch assembly; FIAMM dual horns w/relay-protection; Renthal Desert CR bars w/ 3/4" removed each end; Maier WoodsPro heavy duty full metal barkbusters; Maier large handguard/cups; EBC 320mm full floater front brake disc; ZX600A3 front brake master cylinder; ZX750A4 BACR-front brake caliper; custom stainless steel brake lines front & rear; 80-LED rear brake/running light bar under luggage rack; 32-LED 1157 rear bulb; Napoleon LH mirror short stem on KLR600 mirror bracket; ScotOiler w/dual-injector mounted in place of LH starter motor solenoid/bracket; redundant wiring & cables ziptied in place for easy trail or road-side replacement; 2RS bearings throughout; FT500 Ascot rear turn signals; unknown brand saddlebag guards in picture now hanging on the wall; Moose bash plate; stupid footpeg-equipped "engine protector" off the bike- a real p-o-s bent into my radiator hose and almost cut it when we fell at 0mph on hydraulic fluid at a stop sign- needs triangulation the square-tubing just kinks (hey it was free); Eagle Mike doohickey & torsion spring; custom 350w stator; Accel HT lead; Electrosport HD regulator/rectifier in custom location; custom engine mount plates & brackets; through-bolts on luggage rack (but not sub-frame!); Renthal RS4 chain w/rivet clip currently geared -1front +3rear running D606 DOT knobbies front & rear (D607s on in this photo w/+1front) An important addition: I used the internals from a ZX600A1 petcock in mine- now I have on, reserve and the all-important PRIME so I don't kill the battery sucking the fuel valve diaphragm back when I run out of gas... and we know how fast singles run out of gas, don't we?
Brittus
Old 05-06-2011, 08:55 PM   #3896
Vic-klr
TEETET Aventuras T el T
Vic-klr's Avatar
Oddometer: 243
Send a message via MSN to Vic-klr Send a message via Yahoo to Vic-klr
nice man I love the sticker of the P-40 that is my favorite airplane +1
Dfrog
Vic-klr is offline   Reply With Quote
Old 05-07-2011, 02:47 PM   #3897
terb0
terb0's Avatar
Oddometer: 18
Here's the nose art zoomed in.
terb0
Old 05-07-2011, 03:14 PM   #3898
WhiskeyThrottle67
Oddometer: 20
Just added my dash from jwudualsport.com, with extra room for some addional upgrades later on.
WhiskeyThrottle67 is offline   Reply With Quote
Old 05-07-2011, 05:14 PM   #3899
NHMatt
NHMatt's Avatar
Oddometer: 269
2008 with new Shinko's
Hit a few dirt roads today in Southern VA and tried out the new tires. Felt real good on the gravel as well as the pavement.
NHMatt is offline   Reply With Quote
Old 05-07-2011, 06:05 PM   #3900
Vic-klr
Vic-klr's Avatar
Oddometer: 243
Dfrog
Times are GMT -7.   It's 09:22 PM.
