Old 05-08-2011, 09:38 PM   #16
anonny
What could go wrong?
anonny's Avatar
Oddometer: 5,699
I just happen to know a guy in Oregon who may be interested
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 05-09-2011, 08:05 PM   #17
Homeskillet OP
Exit Flagger
Homeskillet's Avatar
Oddometer: 235
5/8/11 Pull engine and start cleaning frame with wire brush and sand paper.
Homeskillet is offline   Reply With Quote
Old 05-09-2011, 08:07 PM   #18
Homeskillet OP
Exit Flagger
Oddometer: 235
Front wheel rust. Attack with wire brush and sandpaper.
Press, your six is covered
IBA#21709
BMW RA #29106
2007 1200GS ADV (Bedazzlement made affordable)
1971 Kawasaki 500 Mach III (under restoration)
Old 05-09-2011, 08:10 PM   #19
Homeskillet OP
Exit Flagger
Oddometer: 235
Photo taken this afternoon, 5/9/11, five minutes past Miller Time.
IBA#21709
BMW RA #29106
Old 05-09-2011, 08:30 PM   #20
MSrider
Rebel with a sixfiddy
MSrider's Avatar
Oddometer: 4,275
Bike looks pristine
Nice project skillet. There's no way I would take that bike down to the frame and spray bomb it. Powder coat it, or spray some polyurethane on it. You'll be glad you did.
Is that your Vette?
KOKA
MSrider is offline   Reply With Quote
Old 05-09-2011, 08:36 PM   #21
Homeskillet OP
Exit Flagger
Oddometer: 235
Is that your Vette?
I hear you, but my checking account is bone deaf.
That's my '65 /327/4 speed that needs painting, too.....
Old 05-09-2011, 09:11 PM   #22
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,742
Caponerd, check yer PM's...
S.t.t.G. is online now   Reply With Quote
Old 05-12-2011, 07:23 PM   #23
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,742
Any more progress?
Old 05-12-2011, 07:32 PM   #24
caponerd
Kickstart Enthusiast
caponerd's Avatar
Oddometer: 1,980
Spray cans on the frame are ok, I've done it before when money was an issue.
I do think that sandpaper on the rims is a bad idea.
Extra fine steel wool and wd40 will do a good job of cleaning up the rust.
Better to go ahead and take the wheels apart first. That gives you a good shot at cleaning up the rims.
Spokes can be cleaned up with wd40 and a rag. Don't use an abrasive on those zinc plated spokes.
Clean the rims afterwards with de-greasing solvent, and paint the areas that were rusted with phosphoric acid to neutralise any remaining traces of rust.
Re-assemble the wheels, and take them to a shop to have the spokes tightend and the rims trued. It's worth the expense and time.
(see you in a couple of weeks, Sttg?)
caponerd is offline   Reply With Quote
Old 05-13-2011, 12:23 PM   #25
S.t.t.G.
Mind over metal...
S.t.t.G.'s Avatar
Oddometer: 1,742
Yup, wanna look over the parts "collection"...
Old 05-13-2011, 01:22 PM   #26
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
Originally Posted by Homeskillet View Post
My first bike, a 1969 Mach III, back in 1970.
I am surprised you are still with us!
" The people who cast the votes decide nothing. The people who count the votes decide everything."
Straight Out Da Trailah!
Sniper X is offline   Reply With Quote
Old 05-13-2011, 01:24 PM   #27
Sniper X
De Oppresso Liber
Sniper X's Avatar
Oddometer: 33,347
Hopefully, I can just clean/paint the frame, rebuild carbs, and put fresh tires on it. I'm no mechanic, this is my first rodeo. Any hints/guidance will be welcomed with open arms and ears.
Yes, whatever ya do don't take the heads off.
Old 05-13-2011, 05:42 PM   #28
Dave in Wi
Dave in Wi's Avatar
Location: Madison WI (40 Square Miles Surrounded By Reality)
Oddometer: 2,031
I was wondering about that.
Might as well pull the cylinders, new rings, port it, mill the heads, new seals, expansion chambers....
Pandora's box.
Dave in WI
2002 ZRX1200R
1975 XL100
1988 DT50
"Daddy, it's five o'clock sometime!"
Dave in Wi is offline   Reply With Quote
Old 05-13-2011, 08:23 PM   #29
anonny
anonny's Avatar
Oddometer: 5,699
I would take a serious look at the crank seals.
Old 05-14-2011, 05:42 PM   #30
Frank06
Oddometer: 235
+1 Now's the time! It's easy to pop the cases apart and send the crank off for rebuild. Well worth the time/money. The last thing you want to have happen is to get the engine reinstalled in a nicely painted frame and find it doesn't run well and have to yank it out again.
Don't ask how I know...
Frank06 is online now   Reply With Quote
Times are GMT -7.   It's 10:58 AM.
