Old 05-17-2011, 07:23 AM   #61
guns_equal_freedom
Oddometer: 5,535
Originally Posted by gmtcm View Post
I'm not sure why it needs a fuel pump when the tank is located higher than the FI?
Do you know how fuel injection works?
You should have Googled up "fuel injection" before you asked your question.
It's always best to start from a point of knowledge when asking questions.
guns_equal_freedom is offline   Reply With Quote
Old 05-17-2011, 07:31 AM   #62
gmtcm
KTM RIDER
Oddometer: 315
We always like a smart ass. You don't deserve to live on Whidbey Island.
gmtcm is offline   Reply With Quote
Old 05-17-2011, 07:42 AM   #63
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,173
How are the valves adjusted?
Sparrowhawk is offline   Reply With Quote
Old 05-17-2011, 11:47 AM   #64
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
well man you opened yourself up by asking why FI needs a fuel pump.
that's fundamental operations of the system you're confused on so what did you expect?
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 05-17-2011, 11:51 AM   #65
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
i have been staring at this pic and can't see it either?
one thought was a shim on top of the valve spring but how to move the rockers up & out of the way??? i don't see any thing near the cam lobes. do the rocker rollers come out and thus create room above the spring to get a shim in there? or do those 4 bolts (2 silver 2 grey) allow for the rockers to come out all together?
Alaska
Old 05-17-2011, 11:56 AM   #66
Velociraptor
TrackBum
Oddometer: 1,107
Nevermind. It helps for me to read the whole post so I actually answer the question asked......
2014 KTM EXC 500
2014 KTM 1290 Superduke R
2009 KTM 690r Enduro SOLD
2002 RC51 SOLD
2010 KTM 990 Supermoto R SOLD
Velociraptor screwed with this post 05-17-2011 at 04:41 PM
Velociraptor is offline   Reply With Quote
Old 05-17-2011, 01:25 PM   #67
yondering
yondering's Avatar
Oddometer: 1,100
Looks like the rockers are on shafts and would be removed the same way as most other rockers, pull the shaft out the side after removing the retaining bolts. I don't get why there are 2 retaining bolts on each shaft though, instead of just 1?
I'd bet this uses cupped shims over the tops of the valve stems. You wouldn't want those to bear on the valve springs themselves.
yondering is offline   Reply With Quote
Old 05-17-2011, 01:51 PM   #68
Sparrowhawk
Oddometer: 2,173
The head design looks similar to the current 530, etc. with shims over the vlaves shown as #25 in diagram.
Old 05-17-2011, 04:05 PM   #69
Moto Vaquero
Trail less traveled
Moto Vaquero's Avatar
Oddometer: 301
Yes, just remove 22,23 and 24 then slide the shaft out AFTER measuring and calculating what size to replace with. The shims sit in a dish on top of the springs. It's really quite simple (the second time).
I'm not day dreaming, I'm prerunning
21 days exploring Baja
http://advrider.com/forums/showthread.php?t=922187
Moto Vaquero is offline   Reply With Quote
Old 05-18-2011, 04:13 AM   #70
dirtbikeslob
Oddometer: 300
i seem to remember seeing a tool( somewhere on the web or maybe in my dreams )that depresses the valves, enough to remove the shim,when reshimmig the valves,looked pretty simple and saved having to dissassemble cams,but you must ensure motor@TDC
dirtbikeslob is offline   Reply With Quote
Old 05-18-2011, 12:20 PM   #71
Moto Vaquero
Trail less traveled
Oddometer: 301
I think if you depressed the springs (and valves) at TDC enough to replace a shim, the valve would hit the piston. There is very little clearance there hence the dishes cut into the pistons so the piston doesn't smash into the valves. Perhaps this is doable at 180* of TDC but you will still have to be carefull with the little valve keepers not moving out of place.
It really is quite easy to R&R the rocker shaft. With the valve cover off, I could change a shim in <10 min.
Old 05-19-2011, 12:50 AM   #72
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,610
so those 4 top bolts out and the 2 cover caps (on the backside of the pic) and the rocker shafts pull out from the backside of what we see in the pic? rockers moved out the way & then
replace with the proper calculated shim and reassy? actually that seems very simple compared to some of the OHV jap stuff.
Alaska
Old 05-19-2011, 09:27 PM   #73
Moto Vaquero
Trail less traveled
Oddometer: 301
Yes, if you're going to replace shims on both the intake & exhaust side.
After you remove the two top bolts and the cap on the end, you can thread one of the 6mm valve cover bolts into the end of the rocker shaft a couple of threads so you can pull the shaft out. If you use a magnet stick it makes it real easy to r&r the shims. Don't forget to tighten the top bolts to the proper torque and remeasure the gap, it's that simple.
Old 05-27-2011, 04:48 PM   #74
deminimis
I Eat Glue
deminimis's Avatar
Oddometer: 696
Okay, well what the hell is this 500exc all about?
I'm confused. Euro only? That power plant looks like a kissing cousin to my 505's engine....with a kick starter.
KTM 505 XC-F
Beta Rev 3 270
CRF150R for The Girl
YZ85 for The Boy
deminimis screwed with this post 05-27-2011 at 04:54 PM
deminimis is offline   Reply With Quote
Old 05-27-2011, 05:23 PM   #75
gmtcm
KTM RIDER
Oddometer: 315
Having the shims located on top of the bucket is nothing new. The early Z1 Kawasakis (73-80) had the shims located on top of the bucket and the camshaft rode against the shim. There is a tool that would hold the valve down so the shim could be replaced with one of the correct thickness.
Times are GMT -7.   It's 02:07 AM.
