05-21-2011, 08:48 AM
#31 | |
Exit Flagger
Oddometer: 224
Thanks to all for the suggestions. I'm the blind leading the ignorant when it comes to mechanical expertise. But I try to listen....
Press, your six is covered IBA#21709 BMW RA #29106 2007 1200GS ADV (Bedazzlement made affordable) 1971 Kawasaki 500 Mach III (under restoration) |
05-21-2011, 09:06 AM
#32 |
What could go wrong?
Oddometer: 4,957
There are seals on each side of each of the crank lobes, so thats 6 seals that stop anything leaking between cylinders. Over time they get brittle and start cracking, if air leaks in the cylinder runs lean and very bad thing happen.... like seizures and holed pistons.
The seals do not sit in oil so having oil in the engine is not a cure. A leakdown test will give you an idea of their condition but personally unless I changed them in the recent past or was positive someone else did I would (and did) take it apart and see what shape they are in. You will save money and heart ache.
Kawasaki H1 build thread 71- 450 Honda CL re & re Just another pathetic sheep following the herd |
05-21-2011, 09:18 AM
#33 | |
mach schnell
Oddometer: 1,434
****** Mess with me and you mess with the whole trailer park. |
05-21-2011, 12:37 PM
#34 |
Exit Flagger
Oddometer: 224
Thanks Big A! Great advice.
05-23-2011, 10:34 PM
#35 |
Exit Flagger
Oddometer: 224
05-23-2011, 10:37 PM
#36 |
Exit Flagger
Oddometer: 224
05-24-2011, 12:09 AM
#37 |
Taumarunui..Darwin..
Oddometer: 2,110
Once you get to that stage,if you have any doubts at all about the crankshaft (and sitting for years will do them no good)
Contact Damon Kirkland... he has a world wide reputation for crank building...fwiw
Les .. 1968 Husqvarna MF250 and MF360 - 1971 Norton Commando Fastback - 1973 Kawasaki H2A - 1973 Ducati 750 GT - 1973 Moto Guzzi Eldorado - 1974 Kawasaki H2B - 1974 Triumph TR5T Trophy Trail - 1981 Ducati 900 SD - 1986 Husqvarna 400 WR - 1998 Suzuki TL1000S - 1998 Suzuki TL1000S - 2007 Ducati Hypermotard 1100S - 2008 Suzuki DR780. |
09-22-2011, 01:56 PM
#38 |
Exit Flagger
Oddometer: 224
Put the triple tear down project on hold during the triple digit Louisiana summer. Just started back. Trying to get the stator rotor off the side of the engine so I can split the cases and get the crank sent in for repair.
But first, I need to order that special bolt puller tool to get the stator off. (I'm in way over my goggle strap.....)
09-22-2011, 02:15 PM
#39 |
Location: Berkshire, England. Just off the Beaten Track!
Oddometer: 2,572
Watching this with interest, as I am about to start rebuilding my 72 H1b over the winter
09-23-2011, 09:56 AM
#40 |
Exit Flagger
Oddometer: 224
09-23-2011, 09:59 AM
#41 |
Exit Flagger
Oddometer: 224
Tried several sized pullers but stator would not come off. Found out that a special threaded bolt pulling tool is required. ($19.99 on eBay)
Pulled pistons and marked each....
09-23-2011, 10:07 AM
#42 |
Exit Flagger
Oddometer: 224
09-23-2011, 10:09 AM
#43 |
Oddometer: 4,556
From the look of the pictures the oil that is in the engine is oxidized, normal when things sit for years.
You do need to have torn down, cleaned and renewed just to get the old gummy oil and gas mix out of there, and nice clean stuff. Oils now are much better, you will have nice long life as long as you ride it regular. Wait until you see the fork oil!!! And the wheel bearings, steering bearings, and swingarm bearings. Rod |
09-23-2011, 10:10 AM
#44 |
Oddometer: 2,294
Just use a metal pin and a bolt with threads matching the hole to pull that rotor.
BMW tries to sell that crap for way more than it's worth too. When I bought my charging kit for my r90, it came with a small metal dowel and a standard bolt. All it does is push that dowel against the bottom of the hole while the bolt threads into the rotor and pushes against the dowel to pop the rotor off the cone of the crank. If you're broke, think like a broke man I know I always do!
1974 BMW R90 /6 1968 Bultaco Matador MK3 1973 BMW R75 /5 Toaster LWB 1969 Bultaco Bandido MK2 2013 Husqvarna Terra TR650 |
09-23-2011, 10:57 AM
#45 |
turd polisher
Oddometer: 773
Can I take that for a spin when you're done? I promise I'll bring it back.
I wouldn't bring her home to Mama, but Mama ain't home tonight. |
