Old 05-27-2011, 11:54 AM   #406
Mane
Mane's Avatar
Oddometer: 419
Thank you!
Thank you lomax!
I'll be ordering a couple of pairs.
regards,
Mane
'94 BMW R100GS Bumble Bee
'08 Triumph Tiger 1050 (Sold it, solid performer)
'06 KTM 640 Adventure (Sold it and regret it since day one)
'03 BMW R1150GS Adventure (Death because of hopistalary infection R.I.P.)
"Never wrestle with a pig. You both get all dirty, and the pig likes it".
Mane is offline   Reply With Quote
Old 05-27-2011, 01:32 PM   #407
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,072
+1 on those bullet style inline filters. I've tried the slightly larger paper type filters on a couple of bikes including the Ducatis I used to own which had low pressure fuel pumps, and the F650 with just gravity feed - not enough flow.
On the R80 and the F650, the bullet style filters work just fine.
I get mine at one of the local dealers since lots of motocrossers and dirt riders use lots of them. And I keep a spare on each bike just in case when I'm traveling. But I have yet to have one clog up.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 05-31-2011, 02:51 AM   #408
davorallyfan
Commonist
davorallyfan's Avatar
Oddometer: 16,305
R80G/S headlight shell rear
A mate is after a BMW R80G/S rear headlight housing - needed to finish project (he hit a roo)
He is now looking globally - any leads
7th Day Adventourist.
Re-incarnated
Terrafied
I have learnt a lot from my mistakes. I am heading out to make a few more.
davorallyfan is online now   Reply With Quote
Old 05-31-2011, 02:58 AM   #409
Bulldust
Bulldust
Bulldust's Avatar
Oddometer: 836
A rear headlight? Has he got a reverse gear too?
Bulldust is offline   Reply With Quote
Old 05-31-2011, 07:26 AM   #410
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,549
Bluhduh Motorrad Elektrik Alpha Ignition
Has anyone here actual used or had any experience with this set-up?
Prequel - I'm workin' on a major bitch rant if things don't pan out soon...
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 05-31-2011, 10:15 AM   #411
airheadpilot
Le Poulet du Désert
airheadpilot's Avatar
Oddometer: 287
Yep - I have about 10K miles on the one in my R80ST. Works fine. I don't really have anything else to say about it, but the bike always starts, timing is always correct, and there's always spark. We'll see how it holds up over the years and miles to come. FWIW, I've had the stock Hall effect bean can fail on every airhead with electronic ignition I've ever owned (n=4 and counting).
If you're going to rant against Rick for a problem, you should probably do it over in the Vendors section...
Andrew
Big Ass Titties!
airheadpilot is offline   Reply With Quote
Old 05-31-2011, 10:19 AM   #412
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,639
Originally Posted by Lomax View Post
I use these and have never had a fuel starvation problem.
http://www.ascycles.com/detail.aspx?ID=1550
I used those same filters and after about a month, they both cracked and leaked.
crazydrummerdude is offline   Reply With Quote
Old 05-31-2011, 09:24 PM   #413
Beemerboff
Oddometer: 2,331
My experience with inline filters are that the bullet /bronze ball style let some of the fine stuff through anyway, and they clog up PDQ if there is much coarse stuff, and the pleated paper are fine on both but the ones I got couldnt cope with a little water in the petrol and virtually stopped flowing as soon as they got wet.
Others may be better, but I dont have the inclination to experiment.
So, on balance I would sort the problem first, clean and recoat the tank and use the bullet ones to protect from introduced dirt.
And change them as a mojor service item.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is online now   Reply With Quote
Old 06-01-2011, 12:36 AM   #414
davorallyfan
Commonist
Oddometer: 16,305
a BMW R80G/S rear headlight housing is the back part of the black plastic clamshell that houses the headlight. See where the * is pointing (and yes it looks like a spider) any help with one of these - even a busted one that could be fixable is OK
No reverse needed but thanks...
Re-incarnated
Terrafied
Old 06-01-2011, 03:22 PM   #415
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,521
Andrew
What is this part? I can not find it on his website.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-01-2011, 03:25 PM   #416
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,549
Cool2
Bean can ignition: http://<font color="Yellow">http://w...pha.htm</font>
E-me or PM me and let's chat.
Andrew
Not sure what you're gettingat there Andrew, but I'm not gonna blow a gasket just yet. Glad you've had a good experience.
Old 06-01-2011, 03:56 PM   #417
airheadpilot
Le Poulet du Désert
Oddometer: 287
Sorry Rapid, I thought you were working on a rant about the Alpha ignition.
Actually, I've been having some surging problems on the ST and thought it was fuel starvation, since it tended to happen on the freeway in 5th gear at 75 mph. I went through the fuel system and made sure the petcock screens were clean, float height was set, jets were clean and free, all the usual stuff. Didn't have the problem for a while so I figured that fixed it.
It happened again this morning. As it was happening, I thought to myself "gee, this feels a lot like when points and/or a condensor goes bad..." Turning the ignition off and back on appeared to correct the problem. So I called Rick today. He said he hadn't heard of that before, but he's going to send me a new Alpha control unit to see if that solves the problem. If not, then it's probably my ICU going south.
Andrew
1971 Ambassador
1972 R75/5
1983 R80ST
2003 XR400R
2005 FJR1300A
2012 XT1200Z (soon)
Big Ass Titties!
Old 06-01-2011, 05:18 PM   #418
Rapid Dog
Rapid Dog's Avatar
Oddometer: 9,549
...exactly, Rick is sending me one also, as I have surging and blubbering, and off idle sputtering.
Actually he sent another and it was dead...so I'm waiting.
I was told that 'some of the modules were bad'...
Likee I said, I'm staying positive...
Old 06-01-2011, 05:48 PM   #419
Boxer Metal
Mad Scientist
Oddometer: 3,521
Seems like they are a little more pricey than stock, but if they last longer then I would go for it.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 06-02-2011, 03:05 AM   #420
Beemerboff
Oddometer: 2,331
If turning the switch off and on cures it dont rule out the switch as the problem -DAHIK
Times are GMT -7.   It's 01:44 AM.
