Old 06-01-2011, 04:40 PM   #11476
Boon Booni
Red Clay Halo
Boon Booni's Avatar
Oddometer: 11,177
Originally Posted by Bronco638 View Post
Yeah but can't you attribute that to the evolution of engine technology? I believe your DL is pretty recent where as the TA is ~22 years old. I'm not trying to argue or refute your observations but it seems that the comparison is a little more apples/oranges, to me. In other words, I would expect the DL to be better.
Without a doubt. But there seemed to be some sentiment that it really wasn't the case.
Either way though, it's a sticky situation. We love the bikes we have, including their shortcomings, which we don't really see as shortcomings. I like both the Strom and TA for various reasons.
One of my favorite bikes is my R90/6, which has 250cc on my strom, is slower, has a hinge in the frame, poor brakes, clunky transmission, poor suspension, but is super fun to ride, in many ways because of all it's shortcomings.
Maybe Old's Cool is a bunch of dirty old men who swear because , let's face it, old bikes run on blasphemy as much as they do gasoline and oil. --Jinx
You can be Han Solo, and I can be another Han Solo...
Old 06-01-2011, 06:58 PM   #11477
locorider
Loco, pero no estúpido!
locorider's Avatar
Oddometer: 2,266
Valve clearance
The manual specifies 0.1mm for valve clearance. Is this correct? I did it but dont like the way the engine sounds after the adjustment... Also, its running hotter. Do I have to syncro the carbs?
Carlos locorider
1974 Catalina 22....sailing, mi otra pasión!
"If you don't follow your dreams, you might as well be a vegetable", Burt Munro, The World's Fastest Indian
"Avoiding danger is no safer than outright exposure. Life is a daring adventure, or nothing" - Helen Keller
Longaniza Ride
Ruta del Café
Old 06-01-2011, 07:09 PM   #11478
old2wheeler
Former nÔÔb
old2wheeler's Avatar
Location: La Veta, CO except for the wind, it'd be heaven
Oddometer: 710
Intake: 0.15mm or 0.006 in.
Exhaust: 0.20mm or 0.008 in.
Roderick (Rod) {AKA o2w} House
DEFINITION OF A VETERAN
A Veteran - whether active duty, retired, national guard or reserve - is someone who, at one point in their life, wrote a check made payable to "The United States of America", for an amount of "up to and including my life."
old2wheeler is offline   Reply With Quote
Old 06-02-2011, 06:41 AM   #11480
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 2,899
Send a message via AIM to Bronco638 Send a message via Yahoo to Bronco638
True that. So far, I cannot find any "shortcomings" () even though I know there are. However, the TA works for what I want in an 'adventure' bike. And, that's good enough for me.
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 06-02-2011, 07:26 AM   #11481
danyila
danyila's Avatar
Oddometer: 26
Originally Posted by FolcoNitro 2KF View Post
This is my summer project.
3000 km in 10 days...
http://danyila.selfip.org/turafilmek/Albania_2010/
danyila is offline   Reply With Quote
Old 06-02-2011, 10:17 AM   #11482
locorider
locorider's Avatar
Oddometer: 2,266
I guess the specs you mention are for newer TAs.
Carlos locorider
Longaniza Ride
Ruta del Café
Old 06-02-2011, 10:43 AM   #11483
mas335
xendurist
Oddometer: 1,554
These specs are for 89-90 TA's
Transalps
mas335 is offline   Reply With Quote
Old 06-02-2011, 12:07 PM   #11484
mas335
xendurist
Oddometer: 1,554
Some time ago Ladder came up with a Air Filter mod which required removing all the paper from the filter frame and installing a cut down foam filter that I think was a UNI NU-4097 or something very similar in design.
I don't have images showing the exposed and altered raw frame but this isn't about that aspect of the mod but about the foam filter.
As I remember it the overall diameter made it a bit snug to fit back into the air box hole and the over all foam thickness also keep it from fitting perfectly into the recessed "tray" in the filter frame.
Well I was working on a friends NX125 which needed a new air filter and once it came in I checked out the size and ordered another one for the air filter frame, it's a perfect fit with no cutting of any kind, drops in and fits snug and is much cheaper than the UNI filter.
Transalps
Old 06-02-2011, 12:30 PM   #11485
mas335
xendurist
Oddometer: 1,554
I had to replace a valve cover gasket on a TA and got to thinking about how you can't tighten the valve cover bolts to add more pressure to the existing gasket.
It never occured to me before that the bolt shoulder is probably what is bottoming out and restricting tightening the cover some more. So I counted the turns on the bolt with the cover on and without the valve cover to see when the bolt bottoms out and stops, both were 10 1/3 turns.
This means that if you put a washer under the head of the chrome bolt it will in effect shorten the length of the bolt shoulder. As long as the overall diameter of the added washer is no larger than the valve cover bolt mounting then you should be able to increase the pressure on the valve cover gasket. I would not recommend over doing this bolt, you could deform or crack the valve cover but if you have a slight nagging drip from these gaskets this just might solve it or at least buy you some time.
I did not try this because I needed to know that stopping the gasket leak was a permanent fix the first time without trial and error, I simply did not have the time to experiment.
I think it will work and it would sure be a heck of a lot quicker than what you have to go through to replace these gaskets, especially after you re- assembled the entire bike from having it all in pieces only to discover the next day that they leak, do ask how I know this!
Transalps
Old 06-02-2011, 12:45 PM   #11486
mas335
xendurist
Oddometer: 1,554
Valve cover bolt and washer
Transalps
Old 06-02-2011, 12:54 PM   #11487
NorCalTA
Roaming ADV Gnome
NorCalTA's Avatar
Oddometer: 1,395
Hiya Mark
Is that a Honda filter for an NX125 or is it made by an aftermarket company? Do you have the part number and source to order from handy?
Thanks - Dave
NorCalTA is offline   Reply With Quote
Old 06-02-2011, 01:19 PM   #11488
mas335
xendurist
Oddometer: 1,554
Originally Posted by NorCalTA View Post
Hiya Mark
Thanks - Dave
Honda: 17213-KB7-000
Transalps
Old 06-02-2011, 03:12 PM   #11489
Ladder106
It's a short cut, really
Ladder106's Avatar
Oddometer: 4,268
OH....OK.....at first I thought that the entire 125 filter was identical to the TA filter but foam and was wondering why Honda would do such a thing.
What you're saying is that the FOAM from the NX125 filter can be removed, the paper on the standard TA filter can be removed from the cage and the NX foam is a perfect fit IN PLACE of the paper..
Right?
Also, people smarter than me have discovered that burning the paper off with a propane plumbers torch is a much faster and cleaner way to remove the paper.
BUT PLEASE......
realize that if you are performing this operation on an old filter, oil and fuel vapors will have permeated your paper and you may have more fire than you can deal with
As always do this in an open and well ventilated space completely away from all other fuel and combustibles.
One other thing....I think that breathing the fumes from the burning epoxy or whatever adhesive is used here is NOT A GOOD THING.
Ladder106 is offline   Reply With Quote
Old 06-02-2011, 04:40 PM   #11490
mas335
xendurist
Oddometer: 1,554
Ladder......What you're saying is that the FOAM from the NX125 filter can be removed, the paper on the standard TA filter can be removed from the cage and the NX foam is a perfect fit IN PLACE of the paper.. I had too much info on my mind and made some assumptions. When you order the NX125 filter number that I provided you only get the foam sleeve. I took this image just to show someone else that the NX125 air filter is a replaceable foam type over the triangular frame in the photo. You prep the TA air filter just as you would for the UNI filter. I think the list price on these foam filters is $14.00? The UNI plus shipping ran close to $30.00?
Right?
Also, people smarter than me have discovered that burning the paper off with a propane plumbers torch is a much faster and cleaner way to remove the paper. The paper is not that hard to remove and since the perforated metal center cylinder is also Epoxyed onto the main cover didn't want to disturb that so I did it the slow and dusty way with a dremel tool.
BUT PLEASE......
For what it is worth, the foam filter comes pre-oiled so expect that when you open the plastic bag.
Transalps
Times are GMT -7.   It's 12:54 AM.
