Old 06-19-2011, 02:11 PM   #46
BrokenR80RT OP
But I'll fix it.
BrokenR80RT's Avatar
Oddometer: 157
Originally Posted by supershaft View Post
Have fun with it. I only hope you got out your lab coat and pipe out while making the graphs. Penny loafers with no socks? And a sharp haircut! Oh the horror!
Thanks for your input, Supershaft. Completely invaluable.
BrokenR80RT is offline   Reply With Quote
Old 06-20-2011, 02:18 AM   #47
bush pilot
bush pilot's Avatar
Oddometer: 2,526
My old r90s was pretty consistent about getting 47-49 mpg at reasonably sane speeds (65-70). Those slide carbs and the tall rear axle ratio were great.
USA travels 09'
Anchorage to Ushuaia
RTW...part: Europe
Iron Butt #35784
bush pilot is offline   Reply With Quote
Old 06-20-2011, 05:00 AM   #48
Carrizojim
Still stumblin along
Oddometer: 68
Originally Posted by bikerfish View Post
45+ on both my r100's, 78 /7 and a 93 r100r. I can squeeze 50 out of them if I want to.
+1... 45mpg usually... it will go way over that if I'm milking it along at 65 or less... My sweet spot is right at 69-70 mph, great mileage, smooth as glass...
Pretty fresh carbs rebuilt in in Dec 2010, carefully synched and tuned by Renner... 130,000 original miles, no engine rebuilds or "restorations".
I'm on bike bike number 20 something, I think I lost count. '77 R100/7
Carrizojim screwed with this post 06-20-2011 at 05:08 AM
Carrizojim is offline   Reply With Quote
Old 06-20-2011, 05:33 AM   #49
Big John Sny
Big John Sny's Avatar
Oddometer: 669
I don't know how this affects your results, but the fuel here in Dallas and many other large metropolitan areas in the US has changed quite a bit in recent years. I am getting significantly lower fuel milage numbers in all of my vehicles. Any additives they add will add volume of fuel without adding energy (some of these additives are seasonal). The addition of ethanol adds less energy per equivilant volume of gasoline it is replacing.
I was getting a consistant 31mpg till I moved the needles back to the factory setting and started getting 35. I would really love to get 40, but my car that used to get 34 is now getting 30 and my minivan that was getting 25 is now getting 20 (both get slightly better when I get gas outside the metroplex), so I don't see that happening. I have used my wifes 250 ninja to go to work that should be getting 65 and I get just over 50, so maybe it is just me (although my wife says both cars get 2 mpg better when I drive them than when she does).
4 out of 3 people have trouble with fractions.
1999 Ducati Monster, 1979 XS650, 1976 Aermacchi/Harley SS250, 1976 Aermacchi/Harley SS175,1981 R100
Big John Sny is offline   Reply With Quote
Old 06-20-2011, 08:40 AM   #50
pit0rz
Off on a bimble...
pit0rz's Avatar
Oddometer: 811
84 R100RT (currently nekkid) - 36MPG spirited back road riding w/ VERY limited Interstate jaunts. VM38 Mikunis and K&N Filter in stock airbox and Epco pipes (kinda loud)
Steve P.
Upstate NY
take the long way home
pit0rz is offline   Reply With Quote
Old 06-20-2011, 09:10 AM   #51
Rapid Dog
bikes, booze, broads...
Rapid Dog's Avatar
Oddometer: 9,543
'81 R100RS 40mm Bings, 9.5 psitons, Lufty pipes, dual-plugged
Saturday, 49.5mpg average. 164 miles of freeway, canyons, open road, slow rough stuff.
'91 R100GSPD Derelict Deux , '81 R100RS Rattlecandy Red/'06 950 ADV Orangeboom/91 R100GSPD Derelict etc.
Rapid Dog is offline   Reply With Quote
Old 06-20-2011, 09:40 AM   #52
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,978
I check the gas mileage once or twice a year. Mileage has been typically in the 47-49 mpg range over the years. A bit lower with spirited/high speed riding, and a bit higher with a light throttle. I've not seen much change with the introduction of ethanol-laced fuel, although cold starts are most affected.
"YMMV"
'73 R60/5 Toaster
Old 06-20-2011, 11:29 AM   #53
BrokenR80RT OP
But I'll fix it.
Oddometer: 157
Next time you are filling up instigate that pump and let us know how much ethanol your fuel has. That is one bad additive which will scalp your fuel economy. Gallon for gallon, ethanol has about 25% less potential energy than straight gasoline.
Old 06-20-2011, 01:11 PM   #54
bgoodsoil
Dare to be Stupid
bgoodsoil's Avatar
Oddometer: 4,607
40
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring--Never Leave a Man's Behind
Proud SmugMug User Support ADV: Don't give those cheap bums your discount code
bgoodsoil is offline   Reply With Quote
Old 06-20-2011, 02:36 PM   #55
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,236
45/50 r80
Uncle Pollo is offline   Reply With Quote
Old 06-20-2011, 03:52 PM   #56
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,888
its 10% here. :sad
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 06-20-2011, 05:02 PM   #57
Lornce
Lost In Place
Lornce's Avatar
Oddometer: 18,138
That's 60mpg imperial on a 2.91 equipped RS.
I knew short gears was the only thing holding me back.
Old 06-20-2011, 05:09 PM   #58
Mr. B.
Climate Controlled
Mr. B.'s Avatar
Oddometer: 151
I just did a 1700 mile trip on my 1978 R80/7. Based on my sloppy book keeping records I averaged about 47 mpg.
Mr. B. is offline   Reply With Quote
Old 06-21-2011, 04:49 AM   #59
Gimmeslack
furthur
Gimmeslack's Avatar
Oddometer: 2,492
G/S usually 2-up.
Varies according to type of riding I'm doing, but generally around mid-40's. Call it 45mpg.
"If you hold a cat by the tail, you learn things you cannot learn any other way."
Twain
Gimmeslack is offline   Reply With Quote
Old 06-21-2011, 05:36 AM   #60
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,888
Good god. Do I just ride like an asshole? Sometimes I forget which crowd I'm hanging out with
Times are GMT -7.   It's 09:21 PM.
