Old 06-27-2011, 09:08 AM   #1
Grok OP
Grok's Avatar
Oddometer: 3,566
Harmonizer Vacuum Multi-Tool -- It ain't your Daddy's Twinmax
Temporarily Sold Out
More will be available later in the summer
Price - $129 USD
Domestic shipping $11
International shipping $18
California residents pay sales tax
International buyers pay duties if required by their country
Shipping - US orders shipped US postal service Priority mail. Delivery is typically 1-3 days.
International orders are shipped US postal service first class international. Delivery is usually about a week, but varies by country.
By
The Harmonizer - A 2-port Adventure Vacuum tool.
The Harmonizer is a small, portable, battery-powered, Vacuum Multi-Tool intended to aid powersports engine tuning and diagnostics. It works for both carbureted and fuel injected motors. In addition to vacuum and RPM measurements in two distinctly different modes, a few utility/convenience features have been included.
Vacuum Measurement and Tachometer Functions
The Harmonizer has two Vacuum modes that both include tachometer functions. Balancer mode and Gauge mode. The Harmonizer measures the period of the vacuum pulses to calculate RPM.
Balancer mode displays the difference in vacuum at the two ports. There is a center-zero representation similar to an analog meter, and a numeric representation in the range of +/- 999mbar. A smiley appears if the vacuum difference is 0 +/- 25mbar. The "needle" sensitivity auto-ranges. If you exceed the limits of the display, the sensitivity of the "needle" is cut in half. The numeric display always resolves to 1 mbar. In Balancer mode the tachometer is calibrated for 4-stroke motors with one cylinder/intake. For 2-strokes or motors with 2 cylinders/intake you must divide the tachometer reading in half.
Gauge mode is a heavily damped vacuum gauge, intended to measure vacuum on intakes that support one or two cylinders. Only one Harmonizer port is used. The other is left unconnected. A left-zero meter representation is displayed along with a numeric representation in the range of 0.00-29.00 inHg.
Gauge mode can be used to adjust idle speed with the tach function and mixture (carburetor) with the tach and/or gauge function. Gauge mode can also a be a powerful diagnostic tool.
In Gauge mode, if you use the yellow port, the tach is calibrated for 4-stroke motors, 1 cylinder/intake.
In Gauge mode if you use the red port, the tach is calibrated for 4-stroke motors, 2 cylinders/intake.
As in Balancer mode, for 2-strokes in Gauge mode you must divide the tach readings in half.
Features
Reliable, all electronic design, with digital signal processing and no moving parts.
Large, easy to read, LCD display.
Rugged housing with a clear polycarbonate top.
Vacuum hoses are removable. They attach to the unit with twist-on (finger tight) Luer type connectors.
Swivel-hook on top for hanging/attachment.
Simple one-button interface. Press/release button and wait for Auto-Zero calibration. The unit is now ready in balancer mode.
To access other modes and menu options, hold button pressed until desired function appears. Then release button.
The button is recessed to prevent inadvertent activation and breakage.
Auto Zero on power-up.
Auto Range.
Auto shutoff after 5 minutes of inactivity (except beacon and timed lantern modes).
Battery Voltage Indicator.
Automatic display backlight.
Bright White LED included for convenience.
Toggle LED on/off through menu or by a double press of the button for a quick flashlight function.
Rally/Tour/Camping LED modes.
Timed Lantern Mode illuminates the LED for 15 minutes then power-off. During timed lantern mode a single button press resets the timer to 15 minutes.
Beacon Mode flashes the LED in a randomly selected, 5-flash, repeating sequence. Potentially useful as an emergency flasher or locating beacon. (No, I'm not kidding).
Beacon mode does not time-out. It will persist until the mode is changed or the battery is depleted.
Specifications -
Storage temperature -20C to 70C
Operating temperature -10C to 50C
Vacuum Hose size/length 4mm (5/32) ID x 122cm (48 inches) SAE J1037 -40C to 125C (-40F to 257F)
Battery type 9V Alkaline battery (included) recommended
Typical current consumption and battery life (based on fresh Alkaline battery 500mA/hr 23C)
basic functions backlight off 11mA 45hrs
basic functions backlight on 16mA 31hrs
beacon mode (backlight on) 25mA 20hrs
LED on (backlight on) 34mA 15 hrs
Displayed Range (Resolution)
Balancer Vacuum +/-999mbar (1mbar)
Gauge Vacuum 0.00inHg - 29.00inHg (0.01inHg)
Tach 0-9990 RPM (<1500RPM 10 RPM steps, >1500RPM 50RPM steps))
Accuracy tachometer and internal timing +/- 0.5% @ 23C (+/- 2% over full operating temperature)
RoHS compliant
CE compliant
Notes on use:
Follow all safety procedures. Ensure your motor is adequately cooled during tuning and/or diagnosis. Do not leave a running motor unattended.
The Harmonizer is NOT waterproof. It should not be submerged or used in the rain.
Use on turbocharged motors in boost is not recommended.
The supplied vacuum hose is rated from -40F to +257F. It will melt if it contacts exhaust headers, exhaust manifolds, or catalytic converters.
There are restrictor tubes installed inside the hoses approximately 4 inches from the motor end. They work in conjunction with the hose volume to "snub" peak pressure impulses. They protect the Harmonizer sensor from backfire, racing motors with large valve overlap, motors with damaged intake valves, and motors that have large vacuum orifices (> 1.5mm). These restrictors should remain in place and the hoses should not be shortened.
The gauge function can be used on motors with 3 or more cylinders/intake (like a car) but the tach function may not work reliably and may not work at all (due to diminished vacuum pulse amplitude attenuated in the plenum) and the gauge is much more heavily damped than it needs to be for such motors.
Gauge readings are affected by altitude and weather (barometric pressure). By definition, gauge readings are with reference to atmospheric pressure.
The Harmonizer is extremely sensitive. Large temperature changes during use can affect the "zero" point (offset). If the "needle" doesn't return close to zero after switching the motor off, re-zero the unit and repeat the measurement. Avoiding direct sun and a changing temperature environment minimizes the need to re-zero.
The clear polycarbonate cover is very durable. But it can scratch, and it can be discolored or melted by a few aggressive solvents or extreme heat.
The battery voltage indicator icon displays only battery voltage. It is not always a precise indicator of how much energy the battery has left. Sometimes battery voltage can recover a bit after a period of rest. Especially if the LED has been in use.
You can't go backward if you are facing the right direction
Grok screwed with this post 05-21-2013 at 05:44 PM Reason: sold out
Grok is offline   Reply With Quote
Old 07-08-2011, 07:01 PM   #2
ErricZ
ErricZ's Avatar
Oddometer: 750
What is the duration of the inmate pre-order discount?
2002 BMW R1150GS - Graphitan, PB riding
2000 Aprilia Pegaso - Blue, for the trails!!
02 Pagsta Choppa, 85 & 86 GSX-R 750 (projects)
2005 Ford F-250 Super Duty XLT 4x4, do-it-all Pine Barrens Beastie
ErricZ is offline   Reply With Quote
Old 07-08-2011, 07:10 PM   #3
Grok OP
Grok's Avatar
Oddometer: 3,566
Early Adopter discount will be extended through the months of July and August 2011.
Old 07-09-2011, 06:26 AM   #4
ErricZ
ErricZ's Avatar
Oddometer: 750
Good, thank you very much! I can't wait to buy one .... probably in the next couple of weeks after a nice check comes in!
Old 07-09-2011, 05:45 PM   #5
Alexol
Chronic Farkoholic
Alexol's Avatar
Location: South La., where I-10 has a curve. One curve.
Oddometer: 607
Please tell me about this part:
"The gauge function can be used on motors with 3 or more cylinders/intake (like a car) but the tach..."
I'm especially interested in the 3 cyclinder part and will buy immediately if I can use this (easily) on my Laverda. using the Twinmax to balance A against B, then B to C and A to A and around the houses again is a PITA!
Thanks,
Alex
'14 GSA - '77 Laverda 1000 Jota - '74 Norton 850 Mk IIA (was a project - now a beauty!)
Alexol screwed with this post 07-09-2011 at 05:58 PM
Alexol is offline   Reply With Quote
Old 07-09-2011, 06:14 PM   #6
Andrew
Optimus Primer
Andrew's Avatar
Oddometer: 15,414
Splitting lanes, and splitting hairs.
Andrew is offline   Reply With Quote
Old 07-09-2011, 06:57 PM   #7
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,807
Thanks,
Alex
The 2 primary modes of reading the vacuum in the intakes are balancer and gauge modes.
In balancer mode the display shows the difference between the 2 chosen cylinders
In gauge mode only one cylinder is measured and the display shows the magnitude of the vacuum.
For your 3 cylinder engine the Harmonizer will be used much like the TwinMax ie. A to B, B to C, and C to A
If you want to be able to display all 3 cylinders at the same time you're gunna hafta wait for his next product, the 4 cylinder unit.
BUT this 2 channel unit will be MUCH better than the TM due to it's advanced design and inherent stability over the TM. This means it will be easier to use and will balance your triple quicker than the old TM.
The battery life issue alone will eliminate a huge variance, let alone the all digital circuitry used in the Harmonizer vs. the analog circuit in the TM.
JJ
The hidden harmony is found with joy, while the obvious brings indifference.
The farther you enter into the Truth the deeper your conviction for truth must be.
There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen screwed with this post 07-09-2011 at 08:29 PM
johnjen is offline   Reply With Quote
Old 07-09-2011, 07:01 PM   #8
Grok OP
Grok's Avatar
Oddometer: 3,566
Thanks,
Alex
Hi Alex,
I'm assuming you have a 3-cylinder Laverda?
The Harmonizer has only 2 ports, like the Twinmax. So for throttle synchronization in Balancer Mode you would leave one port connected to a reference cylinder (usually number 1) and synchronize numbers 2 and 3 to number 1 independently. This can be done by physically unplugging hoses and moving them or by using a valved aquarium manifold.
(something like this)
The Harmonizer is easier to use than the Twinmax, gives you calibrated numbers instead of variable arbitrary units, and has a tach display built-in.
But since it has only 2 ports, it may not solve your complaint.
I have a 4-port version in development right now, but it won't be production-ready for 4-6 months. It will allow direct synchronization of 2,3 or 4 cylinder motors without moving any connections or using any valves. It will be more expensive than the Harmonizer.
The line you quoted:
refers to the Gauge Mode that reads a single vacuum port and displays the result in inches of mercury (inHg). This mode is different than Balance Mode and uses only one port (the other is left unconnected). It isn't too useful for synchronizing multiple cylinders. It's intended more for diagnostics and tuning single carbs or single throttle bodies.
Hope this helps!
Old 07-09-2011, 07:01 PM   #9
Grok OP
Grok's Avatar
Oddometer: 3,566
Haha JJ, you beat me to it
Old 07-09-2011, 07:13 PM   #10
Alexol
Chronic Farkoholic
Alexol's Avatar
Oddometer: 607
Given that I already have a Twinmax, I'll wait for the next version, and thanks for the explanation.
I very definitely want to buy the next version for 3 & 4 cyl bikes - what's the best way of staying up to date on your developments?
Alex
Originally Posted by Grok View Post
Hi Alex,
Hope this helps!
Old 07-09-2011, 07:27 PM   #11
Grok OP
Grok's Avatar
Oddometer: 3,566
Alex
You are welcome.
I'm honestly not sure the best way to keep up-to-date. I'll start a 4-cylinder synchronizer thread at some point.
Since you are already subscribed to this thread, I'll post up about it here when there is something happening.
I may start a Facebook page for products and updates as well, but I'm still a social networking noob.
Thanks for the interest!
Old 07-15-2011, 06:04 PM   #12
Grok OP
Grok's Avatar
Oddometer: 3,566
Pre-orders shipped today
Thank you all for your pre-orders!
They were all shipped today.
Old 07-18-2011, 02:11 PM   #13
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,807
Ok so unless this is secret info or sumpt'n what is the count of sold units thus far?
JJ
WingMakers.com
Old 07-18-2011, 02:17 PM   #14
Grok OP
Grok's Avatar
Oddometer: 3,566
JJ
As of today the July 18th, around 45 units.
I'm guessing the orders will pick up when folks have a chance to use it and show it to friends!
We'll see!
Old 07-18-2011, 02:43 PM   #15
jet123
Using all my gears
jet123's Avatar
Oddometer: 4,578
Purchased...
I will report back after using it (may be a bit).
John
http://rerax.net/index.html
jet123 is online now   Reply With Quote
Times are GMT -7.   It's 08:17 AM.
