Closed Thread
Old 06-29-2011, 07:17 PM   #961
slowoldguy
Tire Tester
slowoldguy's Avatar
Oddometer: 8,609
We're loosing money on every sale, but we'll make it up in volume…
Now you are stealing my business plan. Selling dimes for a nickel. I've made a small fortune that way. Out of a large one.
RTB V- The Texas ADV Rally- Hurry before we fuck this up!
http://www.rollthebonesrally.com/
"If you can't fix it with a hammer you can damn sure teach it a lesson".
slowoldguy is offline
Old 06-29-2011, 07:17 PM   #962
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,923
Originally Posted by Codewheeney View Post
I heard it was going to be a complete water-cooled R1300GS motor and drivetrain with brackets to fit into the 1150 frame.
JC
So the real question is are they gunna be stock brackets or custom ones?
JJ
• The hidden harmony is found with joy, while the obvious brings indifference.
• The farther you enter into the Truth the deeper your conviction for truth must be.
• There is understanding of the world precisely to the degree that there is understanding of the Self.
WingMakers.com
Collected Works of the WingMakers Volume 1 pg. 590
johnjen screwed with this post 06-29-2011 at 07:49 PM
johnjen is online now
Old 06-29-2011, 10:30 PM   #963
Geoffster
Fool - Born This Way
Geoffster's Avatar
Oddometer: 1,373
About a month ago I came close to selling my GSA and XCountry and buying an F800GS. (One bike can be better than two if it really fits.) The deal came to a screeching halt when I rode an 800 down a forest trail -- the bike has a WICKED on/off throttle transition that's well documented on this site. And all the work-arounds are uninspiring.
Yesterday, I rode Angeles Crest with a friend, he on a WeeStrom and me on my IICE Air-less GSA (grin), and I again wondered about the 800, so mid-sized and attractive.
Would installing an IICE Air on an 800 smooth out that transition?
Consider this before arguing with me:
You're an idiot if you argue with a fool!
http://www.flickr.com/photos/geoffster/sets/
Geoffster is offline
Old 06-29-2011, 10:51 PM   #964
sonic578
Oddometer: 740
The ADV chatter here points to the G2 cam solution. It looked promising. Not so? I've been doin' some pining after the 800GS as well, and was kinda counting on this.
Dave
'11 GS
sonic578 is offline
Old 06-29-2011, 10:58 PM   #965
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
L-u-u-u-cy! You have some splainin' to do!
Of course this whole 1st assembly product run is WAY more complicated than the next IICE product will be, so after this steep learning curve, IICE Cube (or is it D-coffee, or block ) will be a breeze in comparison…
Yes this thing is just super tedious is all. And many of the little steps required trial and error, and/or testing, and ended up scrap. It had to be this way, the smallest available enclosure, part waterproof, and adjustable, and etc., etc.
Now that I have it all worked out, I sort of don't want to stop selling them. Time in and all, you know? But I also do want to get on with the next products. What's the latest name from marketing? IICE-D Coffee?
The first of the next products, presently known as the IICE Cool (unless I get a memo to the contrary ), is all electronic and will be much easier to build.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside screwed with this post 06-29-2011 at 11:07 PM
Poolside is offline
Old 06-29-2011, 11:01 PM   #966
Geoffster
Geoffster's Avatar
Oddometer: 1,373
I consider it to be a crude -- and difficult (because of heated grips) -- sort of work-around.
Allowing me to more carefully modulate the bike's throttle plates doesn't address the unfriendly programming of the ECU. Nor does changing to a smaller countershaft sprocket to get the RPMs out of the most critical zone.
IMHO the F800GS needs serious ECU help, whether from the factory or via a POOLSIDE PRODUCT.
Old 06-30-2011, 01:18 AM   #967
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Well, my immediate answer would have to be, "Of course it smooths out the transition!" (In my best infomercial tone.) Yea I know, "What the heck are you trying to pull, Jim?"
I realize that may sound kind of silly. Especially since I've never ridden an F800. But I have have many technical reasons that inform me to answer yes to the question. Many, technical, reasons. So many you wouldn't want to read them all.
All right. I'll relent. Here's one technical thing about what causes the jerkiness. When the throttle is first opened, ideally the ECU should add some good amount of extra fuel. Momentary extra fuel over and above the amount needed for proper mixture. Without enough of that momentary extra fuel, when the throttle is first opened the motor makes momentarily less power. Then, when the throttle is opened a few more degrees, bam! the power comes on normally.
But you still want to know how it works, and here's a practical idea. There is something better than all the tech talk. Ask the people who bought one of the competitive products how well they work on their F800. You know, the Boosterplug, Accelerator, etc. Maybe do a search and read their reviews in the Parallel Universe forum.
Regarding the throttle workaround. I like that elliptical throttle bellcrank example. Those reduced-slope bellcranks work well. Again, I haven't tried that particular item on an F800, but on other bikes. It makes a big difference on a KTM Adventure, and on a couple of liter race-rep bikes.
I understand you'd rather not lose the right side heated grip, and there might be a way to save it. The elliptical cable bellcrank can be placed at the throttle body end of the cable instead of at the twist grip.
And a interesting tech note about drive-by-wire throttles. The electronic throttle servos open the throttle butterflies with the same reduced-slope profile as the mechanical versions.
Poolside is offline
Old 06-30-2011, 07:08 AM   #968
frogy
frogy's Avatar
Oddometer: 811
Wait a minute,stop waisting the spare parts.Im hoping for some overruns so I can still buy one.
frogy is offline
Old 06-30-2011, 08:33 AM   #969
Geoffster
Geoffster's Avatar
Oddometer: 1,373
Jim,
Thanks for your input! After cruising through postings on how competitors' products address the F800GS's on/off throttle issue, I will now pursue what many would consider a downgrade: GSA to F800GS.
Thanks for all you do for our community!
- g
Old 07-02-2011, 11:12 AM   #970
JRWooden
Oddometer: 4,249
...I understand you'd rather not lose the right side heated grip, and there might be a way to save it. The elliptical cable bellcrank can be placed at the throttle body end of the cable instead of at the twist grip....
Somewhere on one of the ADVRider threads there are some photos of a guy that did this (made the modification @ the throttle-body end).
In random commentary, I SWEAR the off-idle harshness mellows with time/age/miles....
JRWooden is offline
Old 07-02-2011, 01:31 PM   #971
David_Moen
David_Moen's Avatar
Oddometer: 1,276
I know that a G2 throttle cam made my dirt bike rideable. Mellowed out the mid throttle hit a ton but WFO is still available when required. My budget for replacement plastic is drastically reduced since installing it!
2013 KTM 350EXC-F, 2005 BMW R200GS, 1984 Kawasaki GPz 750
David_Moen is offline
Old 07-02-2011, 02:07 PM   #972
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,923
Originally Posted by itsatdm View Post
I know it doesn't belong here, but I did not start it. Want to solve the problem, do this. Add the G2 throttle tube. You can use your heated grips if you are not a klutz. Get a sharp knife, partially cut your hand grip and manfully tear it off. Under that is an electrical element. Pretty much like every other sold on the internet for 29.95. Peel it off and reapply on the new tube.
That solves 1/2 your problem. The other is a very lean running motor from idle to about 2200 rpm. An accelerator module or Booster plug will take care of that. It is plug and play with no history to worry yourself, if under warrany.
Buy the cheap one, $82 bucks. has all the same parts, the only difference is where one of the resisters lives. If you thought it made a difference you would not be posting here.
Uh, you do realize what thread you've just posted in don't you?
And while it will help solve the problem it really is only a work around. If the fuel injection mapping were correct to begin with then these sorts of mechanical work around's wouldn't be necessary.
edit: oh yeah they aren't resistors they're called thermistors, very different critter.
JJ
WingMakers.com
johnjen screwed with this post 07-02-2011 at 02:46 PM
Old 07-02-2011, 02:15 PM   #973
Poolside OP
Syndicated
Poolside's Avatar
Oddometer: 11,878
Dang JJ, I was just going to put a post up with essentially the same comments. But I was getting a bite to eat.
Poolside is offline
Old 07-02-2011, 02:27 PM   #974
McNeal
Oddometer: 1,738
You're eating? I figured your Marketing Department would be running roughshod over you like a sweatshop foreman so that you could finish the first product and start working on the second. I know how Marketing Departments like to drink Mojitos on the beach while others work.
McNeal is offline
Old 07-02-2011, 02:48 PM   #975
johnjen
I've Been Resigned
johnjen's Avatar
Oddometer: 15,923
The marketing dept approves this message. Especially the "Mojitos on the beach while others work" part…
JJ
WingMakers.com
Closed Thread
Times are GMT -7.   It's 07:36 PM.
