Old 07-09-2011, 09:00 PM   #466
saddlsor
my butt hurts
saddlsor's Avatar
Oddometer: 334
thanks for the info, I figured that would be the answer. I've dealt with bobs before and their parts have always been good quality. quess I need to give them a call.
as for the dyna 3 setup, that's what I had on my bike for the last 5 years until it died on me on a backroad in west virginia last week. I carried the points plate with me in case this happened so swapped it out and was on my way. it runs good with points so I'm going to stick with them going forward. thanks for the help.
I don't know where I'm going, not sure where I've been.
-john denver
99 dr350
78 r80
saddlsor is offline   Reply With Quote
Old 07-10-2011, 06:21 AM   #467
Caddy82rats
Caddy82rats's Avatar
Oddometer: 1,180
I think these points are identical to VW beetles and Combi airhead flat four, maybe same as BMW 2002 cars if my remembering is OK
Caddy82rats is offline   Reply With Quote
Old 07-10-2011, 07:03 AM   #468
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
Points for /5 through 78/7 are one off. Bean can points 79/80 can use VW/Porsche common points.
DoktorT is offline   Reply With Quote
Old 07-10-2011, 10:23 AM   #469
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,475
Originally Posted by doktort View Post
points for /5 through 78/7 are one off. Bean can points 79/80 can use vw/porsche common points.
+1
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 07-11-2011, 10:02 AM   #470
bradatlarge
Insha'Allah
bradatlarge's Avatar
Oddometer: 12,191
Originally Posted by Zodiac View Post
*subscribed
You have been warned.
bradatlarge is offline   Reply With Quote
Old 07-16-2011, 08:49 AM   #471
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,739
Hey guys, I'm just curious about something. Not gonna do it unless I hit lottery or a great job but wouldn't mind knowing a ballpark figure.
What would you expect to pay for a complete engine, tranny, and drive rebuild? Specifically if I take out of the frame?
My 88 R100RS (new to me) has 80k reading on the odo, but the odo is broken so who knows what's really on it. There is no record of an engine or tran rebuild, but records of everything else exist.
I'm starting to pout money into replacement parts, mostly body/electrical, etc but have that tiny little fear in the back of my mind = what happens if the engine quits after I do all this, and isn't it harder/more $ to do a rebuild after a seizure than before (of course it must be)....
I'm also thinking I have it slightly apart now, so now's the time to really get to the bones of the semi old airhead. It runs nice at speed, but I'm sure it's tired.
TIA
Black Shadow of Vincent, falls on a Triumph line
I've got my motorcycle jacket but I'm walking all the time...
Zodiac screwed with this post 07-16-2011 at 09:02 AM
Zodiac is offline   Reply With Quote
Old 07-16-2011, 09:04 AM   #472
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,472
80K + a bit more...no need to worry. If it blows smoke when tootling away from idle,eg at traffic lights, then maybe valve guides, otherwise it'll be fine. Get a compression or leak down test maybe?
Re: transmission...change the oil as per book and inspect the magnet for sharp slithers. That's when you pull the trans. Cost depends on what you get done, but I'd expect $1K+.
boxerboy81 is offline   Reply With Quote
Old 07-17-2011, 07:15 PM   #473
danedg
Horizontally Opposed
Oddometer: 6,598
You must have been reading my thread too much....
It ain't a /2...
If it runs great, change all the fluids and put fresh tires on it.
Ride!
Just a reminder, ride every chance you get. You just don't know how soon it can be taken from you. T.Low
danedg is offline   Reply With Quote
Old 07-17-2011, 08:23 PM   #474
Zodiac
loosely portrayed
Zodiac's Avatar
Oddometer: 31,739
thanks guys
-just changed the engine oil, tranny, shaft and final drive, changed the plugs and brake pads.... gonna clean it up minor paint work, and possibly change the charging system to something modern.
cheers
Old 07-25-2011, 12:41 PM   #475
TLTom
TLTom's Avatar
Oddometer: 196
Whoa, are you for real??
what are they smoking over there??
http://cgi.ebay.ca/ws/eBayISAPI.dll?...ink%3Atop%3Aen
TLTom is offline   Reply With Quote
Old 07-25-2011, 08:46 PM   #476
StevefrmGV
MotoBro's RetroCycle's
StevefrmGV's Avatar
Oddometer: 406
Ignition Coils
Does any body know of alternates for the 6V coils on the 1979 R100RS. This is the BMW p/n12131244142 for $120 each.
May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.
Edward Abbey
StevefrmGV is offline   Reply With Quote
Old 07-25-2011, 10:23 PM   #477
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,144
Lots of used airhead 6v coils available every week on eBay. If you get them from Beemerbone yard you can expect they meet spec ohms and will function just fine. Snobum gives the full treatise on optional coils.
Likely any 6v VW coil will do the job just fine. Just verify 3 ohms rating.
Old 07-26-2011, 12:47 AM   #478
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,472
http://www.euromotoelectrics.com/Bos...fslash-12v.htm
Old 07-26-2011, 11:07 PM   #479
StevefrmGV
StevefrmGV's Avatar
Oddometer: 406
Edward Abbey
Old 07-28-2011, 06:50 PM   #480
mtnseeker1
dirty me
mtnseeker1's Avatar
Oddometer: 39
TT 500 carb. help
There is a open hole that I think needs a 90* insert, aluminum, down facing directing for a clear hose on the right side just below the Idle set screw and I believe that I am missing this part.
I believe it to be a over flow for the top half of said carb.
Carb. is stock and it is a MIC. made in Japan that goes on a 1977 TT 500D Yamaha which I believe to be stock.
Or can anybody lead me to a stock diagram of this carb.?
Any and all help is greatly appreciated.
Hogs suck and pigs rule.
mtnseeker1 is offline   Reply With Quote
Times are GMT -7.   It's 12:54 AM.
