Old 05-25-2011, 11:10 AM   #556
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,143
Originally Posted by jbeem View Post
When the GS is on the centerstand and in gear, how much radial movement is "normal" if I try to spin the rear wheel?
A couple inches at the tire perimeter is normal. The gear mesh of the ring and pinion need a bit of slack, otherwise heat expansion could lead to excess wear and binding.
Spline wear can add a bunch. Expand a mm of spline wear to the tire perimeter and you got an extra 10mm slack.
DoktorT is offline   Reply With Quote
Old 05-26-2011, 01:13 AM   #557
oz_airhead
Oddometer: 192
ATE Caliper pistons..
G'day.
I'm chasing a set of 38mm ATE caliper pistons (2x).
I already have the seals..
Motobins have some at 78 pounds each.
These are not Stainless.
Anyone know of any substitutes, or other sources?
OZ.
oz_airhead is offline   Reply With Quote
Old 05-28-2011, 12:53 AM   #558
Boxer Metal
Mad Scientist
Boxer Metal's Avatar
Oddometer: 3,462
Originally Posted by oz_airhead View Post
G'day.
OZ.
I haven't found any aftermarket on these. You might try your BMW dealer.
BOXER Metal
BMW Biker Scum
BMW Mad Scientist!
Old 05-28-2011, 08:41 AM   #559
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,418
G'day.
OZ.
Where are you? Most Oz cities have someone with stuff. pm me.
boxerboy81 is offline   Reply With Quote
Old 05-29-2011, 09:08 PM   #560
pthomas
Oddometer: 179
G'day.
OZ.
Where did you source the seals? I need the seals but I have the caliper; I looked at Max BMW and it looks like it's only sold as a kit.
Paul
1974 R90/6
pthomas is offline   Reply With Quote
Old 05-29-2011, 09:46 PM   #561
oz_airhead
Oddometer: 192
G'day Paul.
Motobins in the UK.
http://www.motobins.co.uk/
They sell either seals AND piston or just the seals only. In either the 38mm or 40mm size.
Also motoworks in the UK as well.
You could also try Ted Porter in California
www.beemershop.com
HTH
OZ
Old 05-30-2011, 02:25 PM   #562
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,143
G'day Paul.
www.beemershop.com
HTH
OZ
+1 for Ted Porter. Super source for Airhead knowledge and parts. Above and beyond customer service. If he went public, I might buy stock.
Old 05-30-2011, 04:28 PM   #563
pthomas
Oddometer: 179
G'day Paul.
Motobins in the UK.
www.beemershop.com
HTH
OZ
Thanks. Amazing to see that the seals are cheaper when I import them from the UK, even after shipping, that buying them in the US. We're truly a global in this day and age.
Paul
1974 R90/6
Old 05-30-2011, 05:26 PM   #564
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
There was someone on the net selling SS caliper pistons 0n Ebay and one of our inmates tried using a set.
If I remember correctly, the outcome was not good.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 05-31-2011, 04:40 AM   #565
oz_airhead
Oddometer: 192
Yep I saw that. They were 40mm if I recall from ebay,
You'd reckon someone would turn up a few and sell them in stainless.
These bikes are getting on with ATE swinging calipers - was '79 the last of them? And you'd have to agree that the majority have some sort of corrosion due the age of the dust seals that finally give up the ghost.
That means either cleaning them up as a bandaid, or replacing with OEM.
Cheers & thanks.
OZ
Old 06-01-2011, 06:32 PM   #566
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
1980 were the last models (in the US ) to have these goofy things.
www.wirewerkes.com
Old 06-11-2011, 07:10 PM   #567
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,143
I worked on Euros for many years, 90's and back. I've seen hundreds certainly of all the common BMW/Mercedes/vwporshceaudi/volvo models with Ate calipers. I never did measure the seals/pucks. Just put in the OEM kit. Amongs those are certainly common examples of 38 and 40mm seals and pucks.
Seems if you could identify which yrs/model used those sizes, sourcing those might just work ding dang dandy for the early Airheads, including boots.
If it's a dual puck kit, it would do both Airhead calipers for the S/RS/RT.
None of the parts lists I have researched on this give the size, just the application.
Old 07-15-2011, 02:05 PM   #568
Claytonroy
Oddometer: 288
Valve Cover Stud Removal from Head ? ? ?
Greetings folks...I tried a search of this topic but didn't come up with the info I need, so...
What's the best way to remove the center stud from a cylinder head?
I'm switching out a bad left head (stuck intake valve) with a used head. The used one didn't come with the central threaded stud that secures the valve cover.
I already put PB blaster penetrating oil on it...have not tried anything else. Am I going to need heat, etc. what's the best way to get a solid grip on the 'lil bugger so I can back it out?
If there's anything else I should watch out for when reinstalling the head...feel free to elaborate
Thanks in advance for your input!
Claytonroy is online now   Reply With Quote
Old 07-15-2011, 05:32 PM   #569
Zebedee
Zebedee's Avatar
Oddometer: 799
It might need to be warmed up a bit if the stud is in with some flavour of Loctite, but asking the obvious first, have you tried using two nuts in the thread to form a lock nut.
You know the trick, tighten one nut against the other and then just wind the stud out using the lower nut ...
John
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 07-16-2011, 08:49 AM   #570
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,011
Heat certainly won't hurt - I'd go to just spit-sizzle hot but not much more. (I can't spit accurately so I flick water drops from my finger or small drops from a baby nose syringe).
I've had marginally better success on some stubborn Ducati studs using one of the common cam type stud pullers instead of the doubled nuts which work well much of the time. Can't remember where I got the stud puller, probably an auto parts store. They are round gizmos about 2" in diameter with an offset hole and a smaller internal cam. A 3/8 ratchet handle locks the cam onto the stud as you apply force to make it self-tightening. But like I said, mine is only marginally better than the two nuts.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Times are GMT -7.   It's 05:21 PM.
