Old 07-22-2011, 08:38 AM   #46
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,507
TT exhaust.
Rick, if you find a proper source, let me know. I have done exhaustive (pun intended) searching and although there is stuff available for the CB/CL, like here http://jemcoexhaust.com/downloads/Je...ct_Catalog.pdf The late SL's have the twin downtube frame and it is uncertain if many of these aftermarket ones will fit.
I almost bought a pair of these http://cgi.ebay.com/ebaymotors/Honda...ht_1748wt_1167
but was uncertain if the 360 flange was the same as the 350 motor...and whether they would clear the frame due to their design.
This is why I suggested we find someone local to make pipes for us. This is also why I have been hoarding SL exhaust pipes, because they are rarer then hens teeth. I still want to find someone willing to make a 2 into 1 coming off the right side..this fixes the issue with drive chain contact with the pipe, and will be good when I dirt track the sucker
I hope you do find something that works..heck, for $119 bucks, those 360 TT pipes might be worth trying...I could always buy them from you for my CL350...if they don't fit and would fit the CL head.
Old 07-22-2011, 04:01 PM   #47
LC Garage OP
On Any Sunday
LC Garage's Avatar
Oddometer: 736
If memory serves (and that is questionable) it seems as thought the old 350 twin TT pipes fit any frame. I threw that question out in the previous post cuz you never know who may have a source. I'm still in for having some pipes made and have already talked to my buddy that works at Laser Cutting Service in Tualatin, about making several sets of the header flanges so we can eliminate those god awful heavy factory things and have also been pondering how to either use or not use the original clamp technology to hold the pipe in the head. We will have to iron out those questions when we go to build the pipes.
Everyone take care and have a great weekend, headed to Alsea Bay for crabbing trip.
Originally Posted by oregoncoast View Post
TT exhaust.
"Nothing can stop us but fear and common sense”
LC Garage is offline   Reply With Quote
Old 07-26-2011, 10:41 PM   #48
LC Garage OP
On Any Sunday
LC Garage's Avatar
Oddometer: 736
Rear Brakes
At long last, some quality time in the shop! Tonite's goal was to put the new rear brake shoes on, extend the rear brake arm and put the 15 tooth countershaft sprocket on.
First a side view of the brake set up, note the lengthened swing arm (originally lengthened exactly one inch) with stock brake arm and how it causes the brake panel to rotate backwards when the shocks are fully extended, throwing the cable in a bind. Combine that with the worn out rear shoes and the rear brakes were almost worthless.
Next is a view of the stock brake arm, along with the aluminum flat stock used to make the new longer arm.
From eye to eye measured 14.5 inches, but I decided to make the new arm 15.75 inches eye to eye to ensure the cable did not bind when the suspension was fully extended (imagine you come off a jump and the rear wheel binds, which could pitch the nose down, something I did experience in the last race!)
Next is a picture of the new shoes mounted on the backing plate. I used my new digital calipers to measure the shoe thickness and although they only appeared to be .010" thicker than the old shoes, I had to back the adjuster way off to get them into the drum, a good sign. Note; the picture is deceiving, they really are the same size shoes!! In this picture you can also see how far down the adjuster had been tightened in a vain attempt to get the worn rear shoes to work. After installing the new shoes, this adjustment was backed off almost 1 inch.
Last picture is with the rear wheel back on and the new longer brake arm in place.
With the rear brakes completed, I pulled the countershaft cover and swapped the 16 tooth countershaft sprocket for the 15 tooth off the donor bike. This will help keep the rpm's up and allow a little tighter spread thru the gearbox. Still lots to do and counting the days until the new rear springs arrive.
Old 07-28-2011, 10:01 PM   #49
LC Garage OP
On Any Sunday
LC Garage's Avatar
Oddometer: 736
Carbs
Tonite I decided to get the carbs changed. The CV carbs that I borrowed from OC worked well but seemed a little boggy coming out of the corners, so wanted to give the stock slide carbs a try. Their smaller size may cost a little power on the top end but should more than make up for that with their quicker response. We shall see!
Pulled the CV's, cleaned up the slide carbs from the donor bike, pulled the bowls, gave everything a quick check and then bolted on the smaller manifolds (bonus, they are in much better condition than the CV manifolds) and slipped on the smaller carbs.
These carbs also came with an aftermarket quick throttle and at first I thought that might be a good idea, but the throttle turns so hard I might have to go back to the stock slow turn throttle or maybe find some lighter slide return springs.
Also finally got around to changing the engine oil and putting in the synthetic. Next up; putting the electrical system back together. Two weeks to go, starting to feel that time crunch again!
Old 07-29-2011, 02:54 PM   #50
never2old4fun
never2old4fun's Avatar
Oddometer: 469
Going with those carbs will help, but just so you know on my old flattrack/ scrambles/ TT bike Ihad 32mm mic's on it.
More is info is always good.
never2old4fun is offline   Reply With Quote
Old 07-29-2011, 03:57 PM   #51
LC Garage OP
On Any Sunday
LC Garage's Avatar
Oddometer: 736
Agreed!
If I had more time and deeper pockets, might have opted for the Mikunis, but that will have to wait for this winter. I had the stock slide carbs and we are told they were working good and they looked fine inside, so should get me thru this race. Did you get your Mikunis new or find some used ones that worked? My friend Brian seems to have good luck with Keihins, any knowledge on those? I probably won't go as big as the 32mm, maybe 28mm or 30mm.
Definitely going to make some improvements and step up the power this winter!
Old 07-30-2011, 05:17 PM   #52
LC Garage OP
On Any Sunday
LC Garage's Avatar
Oddometer: 736
Wiring
Today was wiring day. Finished pulling all the old electrical off and did a quick comparison to the harness off the donor bike. Less stuff is good.
I began installing the "new" harness and as expected, found all kinds of loose connections, bad wires etc and repaired as I went along. Also removed anything that was not absolutely necessary. The toggle switch on donor bike had been mounted behind the motor, down low, but when I looked at the bracket I realized that it had been made to mount on the handlebar mount. Extended the wires and it fit perfect. Staying true to the barn fresh theme, I resisted the impulse to clean up, shine or otherwise beautify the bracket.
I also took the opportunity to pick the smallest rectifier of the three available and mounted it tight and inside, out of the way. With the slide carbs installed and the cleaned up wiring and smaller rectifier, should have room for the side panels now.
After it was all back together, turned on the switch and kicked it over with the plugs out and connected, and had spark. Success!
Last shot,the debris field. Why do I show these shots? Maybe it's kind of the same reason we have been leaving the bike raw and rough, it is the reality of the process, greasy hands, busted knuckles and an array of parts and tools spread everywhere. Tomorrow I'll clean everything up, get organized and begin again.
Old 08-01-2011, 07:54 AM   #53
Ron Peck
Ron Peck's Avatar
Oddometer: 182
Cl 350 1968
I raced one back in 1968/69; great bike
[/url]
1966 Triumph Street Tracker
2014 KTM 500 EXC
1947 Indian Chief
2009 BMW R1200GS
1941 Indian 741 Scout
Ron Peck screwed with this post 08-01-2011 at 02:00 PM
Ron Peck is offline   Reply With Quote
Old 08-01-2011, 08:05 AM   #54
oregoncoast
Racing Like a Noob
Oddometer: 4,507
Originally Posted by Ron Peck View Post
Bad links, I think.
Old 08-01-2011, 08:09 AM   #55
never2old4fun
Oddometer: 469
The 32's I had on my bike were new, but at this time you'd be paying premium for them now and if you are looking for more torque the smaller carb's will most likely work better for you anyway since you don't have high comp pistons, head work, or a big cam.
Old 08-01-2011, 09:49 AM   #56
LC Garage OP
On Any Sunday
LC Garage's Avatar
Oddometer: 736
Hello!
Ron, was this Ascot (TT with jump)? Can't tell from the black and whites photos, but that looks like red numbers on a white background, were you an AMA Novice in these photos? I rode a 350 twin as a novice (1973), have some great stories from that old beast!
Looked at the photos of your street tracker (66 Triumph), that is an amazing piece of artwork. Thanks for checking in on my humble project.
Old 08-01-2011, 09:51 AM   #57
LC Garage OP
On Any Sunday
LC Garage's Avatar
Oddometer: 736
Horsepower
By next summer will have a 400 kit, but probably stick with a stock or nearly stock cam with a better exhaust system and possibly ignition. Keep looking at those 350 twin road race bikes, lots of trick parts to be found there.
Old 08-01-2011, 11:04 AM   #58
Ron Peck
Ron Peck's Avatar
Oddometer: 182
Novice for sure
LG, red numbers on white plate; district 36 AMA novice. Picture was from Triple M Speedway Marysville, CA. Those were the days my friend.
2014 KTM 500 EXC
1947 Indian Chief
2009 BMW R1200GS
Old 08-01-2011, 11:54 AM   #59
oregoncoast
Racing Like a Noob
Oddometer: 4,507
Old 08-01-2011, 02:06 PM   #60
Ron Peck
Ron Peck's Avatar
Oddometer: 182
Cl 350
I found another pic
2014 KTM 500 EXC
1947 Indian Chief
2009 BMW R1200GS
Times are GMT -7.   It's 03:51 AM.
