Old 07-11-2011, 09:32 PM   #31
radianrider OP
Adventurer wanna'be
radianrider's Avatar
Oddometer: 490
Carbs are all torn down and soaking in carb cleaner. New o-rings ready to install. Hope I can get it running tomorrow. A Suzuki rider from gsresources came by and helped me get them torn down correctly.
Can't wait to see if this resolves the issues I have been having with rough running.
radianrider is offline   Reply With Quote
Old 07-13-2011, 05:40 AM   #32
radianrider OP
Adventurer wanna'be
Oddometer: 490
Got the carbs back together. Need to remember how the choke assembly goes together and get the new intake boots installed.
Old 07-20-2011, 06:48 AM   #33
radianrider OP
Adventurer wanna'be
Oddometer: 490
Got it all back together and am now in the process of getting the carbs set up correctly. Pulls pretty good up to about 4k, then it gets pretty "vibey". Working on the air mixture set up. Valve adjustment to come shortly.
Old 07-20-2011, 12:53 PM   #34
Fire Escape
Fire Escape's Avatar
Oddometer: 1,589
Laugh 1st things first
Consider doing the valve adjustment first, if there are any significant changes you would probably need to resinc the carbs afterwards.
Bruce
No one calls the Fire Department because they did something smart!
06 DR 650, Moose RS Holder, Handguards and Skidplate, ProTaper bars, Garmin 60CSx, Motech racks w/ 20mm Ammo cans, Renazco 08 Scrambler, Conti Trail Attacks and BlackTiger Fork mod, 05 FSE 450, 03 KLR 250, 02 FXDX, 72 WR 250 (again), 72 SL 350 K2 (again), 72 TR6R, 06 XT 225
Fire Escape is offline   Reply With Quote
Old 07-21-2011, 03:08 PM   #35
radianrider OP
Adventurer wanna'be
Oddometer: 490
Makes good sense. Thanks.
Old 08-05-2011, 03:55 AM   #36
radianrider OP
Adventurer wanna'be
Oddometer: 490
Did the valve adjustment...one was very tight.
So far, have cleaned the carbs, replaced brake pads, replaced carb intake boots and o-rings, put new bars on. Have new rubber sitting in the garage and new steering head bearings as well.
Making progress toward a daily rider.
Old 08-05-2011, 06:13 PM   #37
vtwin
Air cooled runnin' mon
vtwin's Avatar
Oddometer: 7,491
Your making good progress.
"Alles hat ein Ende--nur die Wurst, sie hat zwei"
Monroe.
"You only have too much fuel if you're on fire"
unknown
vtwin is offline   Reply With Quote
Old 08-07-2011, 02:49 PM   #38
radianrider OP
Adventurer wanna'be
Oddometer: 490
Took the carbs back off again. Didn't check the float level or try to bench sync the carbs the first time I had them apart.
I adjusted the carbs a little bit and it runs much more smoothly at slow speed and pulls better higher into the rpm range. Still might benefit from a true carb sync.
At this point I think I'm about done with the basics except for changing the tires. Mine are at least 11 years old. Bought Shinko 230 Tourmasters to put on. Just have to figure out how to get it done.
Progress toward having a bike I can ride on a daily basis is being made!
Old 08-08-2011, 09:47 AM   #39
jbcaddy
Oddometer: 1,215
glad to see any old bike get back on the road. good on ya JB
jbcaddy is offline   Reply With Quote
Old 08-13-2011, 08:58 PM   #40
radianrider OP
Adventurer wanna'be
Oddometer: 490
Here's where things stand.
http://www.youtube.com/watch?v=L2myqX--jf0
Old 08-14-2011, 06:47 AM   #41
nedc
Oddometer: 58
My brother bought one of those new- I always liked it. I bought him the one tooth larger countershaft sproket which was a good mod. Yours sounds great!
nedc is offline   Reply With Quote
Old 08-14-2011, 07:38 AM   #42
vtwin
vtwin's Avatar
Oddometer: 7,491
Originally Posted by radianrider View Post
Bike is looking good and running sweet.
Monroe.
unknown
Old 08-14-2011, 07:43 AM   #43
vtwin
vtwin's Avatar
Oddometer: 7,491
Here's a thread I posted when I changed the tires on my Ulysses, but same method I used while doing the Tempters. A little hint, get front tires without the center groove or rib, they like to follow any kind of groove in the road like it's on a rail whether you want to go that way or not.
http://www.advrider.com/forums/showthread.php?t=329135
Monroe.
unknown
Old 08-14-2011, 12:43 PM   #44
radianrider OP
Adventurer wanna'be
Oddometer: 490
That's good to hear from another GR650 owner. Never heard one, other than on the 'net and wasn't sure I should think it was as good as I believed. Reassuring that you think I've got it close.
Old 08-14-2011, 03:28 PM   #45
Duck_Pilot
Retired Roadracer
Oddometer: 6,021
Good on ya!
I was working for a Suzuki-0nly dealership when the Tempters were new, and really liked 'em! There is no starter-interlock on the sidestand, just the clutch lever...... and that one can be disabled almost instantly Simply disconnect the polarized connectors from the switch to the harness, and plug the two harness connections together.
Thanks for sharing this restration!
" A man that can have patience, can have what he will." - Benjamin Franklin
"Man cannot imagine how life could be more difficult or complex. But Congress can." - Cullen Hightower
Honestly, I *do* like Socialists. They just need a little tartar sauce.
Duck_Pilot is offline   Reply With Quote
Times are GMT -7.   It's 08:55 AM.
