08-16-2011, 06:34 PM
#1 |
sheperd
Oddometer: 18
As a noob, this may be a silly question, So I humbly seek advice from those of you who may have the knowledge.
I found a nail in my rear tire today. Rode home slowly and just am wondering, should I buy one of those plug kits to repair it? Seems like a failure of the repair job would be ugly!!! I am not independently wealthy, but I have a long ride coming up this weekend. Tire is a tourance with 1500 miles on it. |
08-16-2011, 06:46 PM
#2 |
Still a stupid tire guy
Oddometer: 7,268
What kind of bike? Is the tire mounted tubeless? If not, then no, you can't plug it.
Plugging a tubeless tire is perfectly acceptable.
"Nearly all men can stand adversity, but if you want to test a man's character, give him power." - Abraham Lincoln |
08-16-2011, 06:55 PM
#3 | |
sheperd
Oddometer: 18
Any plug kits that you recommend? Also any other tips are appreciated. Thanks and thanks |
08-16-2011, 07:05 PM
#4 |
Oddometer: 2,074
I've plugged many tires with the "sticky rope" type plugs and have never had one fail. YMMV. Just follow the instructions on the package.
08-16-2011, 07:12 PM
#5 |
Rhymes w/piecejunkie
Location: The only county in Illinois with no train tracks
Oddometer: 4,763
Go ahead, get a kit and make sure you read the instructions, and get an air pump (there are quite a few people who like to get the $10 slime pump from Wal mart and take all the plastic bits off so they get pretty tiny) and go ahead and ride.
With any new tire repair, it is a good idea to check the tire pressure a few times for the first couple of days. It may lose a couple pounds while the string seats in but it should be stabilized after a day. If not, redo it IMHO.
Grow a WW1 Victory Garden this year! |
08-16-2011, 07:19 PM
#6 |
sheperd
Oddometer: 18
Thanks one and all
Thanks to all for advice.
I will repair it and ride. Camping at Big Sur this weekend with old high school buddies ( about 450 miles round trip ) so I wanted to be sure about the repair.Anyhow, Thanks again
08-16-2011, 07:55 PM
#7 |
"Cool" Aid!
Oddometer: 41,488
08-16-2011, 08:02 PM
#8 | |
sheperd
Oddometer: 18
08-16-2011, 08:18 PM
#9 | |
Whatever...
Oddometer: 2,460
I have NO issues with plugging my tires with the sticky strings and riding them to the end of their useful life. |
08-16-2011, 08:20 PM
#10 | |
Oddometer: 757
...............shu |
08-17-2011, 01:04 PM
#11 |
Yinzer
Oddometer: 1,202
all my bikes have always used tubed tires, so no plugs in those.
but i have plugged more cage tires than i can remember (all with the self-vulcanizing plugs...no glue). only ever had one fail...and that "failing" was a very slow leak--had to make sure to put air in it about once a week. if you are uncomfortable about the plugs, though, you can remove the tire from the rim and patch it from the inside "the right way". they sell those kits in auto parts stores, too. (it's kinda like an innertube patch, but you put it on the inside of the tire instead of the outside of a tube.) |
08-17-2011, 01:50 PM
#12 | |
adventure commuter
Oddometer: 3,168
As a goodyear certified tire jocky and retreader, the super preferred method is to plug (seals the cords from water & corrosion) and a patch on the inside (seals the liner). This is for truck tires BTW... should be major overkill for autos and cycles.
That said, I think I have plugs without patches in about 4 of the 8 cage tires between the wife and I. Plug away. Some companies make some fancy rubber plugs, but like many above, I have nothing bad to say about the sticky ropes. Plus you can find them anywhere.
1974 Suzuki TC-185 (The little 10 speed) 1986 BMW K75c Quote:
08-17-2011, 02:48 PM
#13 | |
Yinzer
Oddometer: 1,202
he said if you use both a plug and a patch, you can get air trapped between the plug and the patch...when the tire gets hot, the air expands, and causes either the patch or the plug (or both) to leak. is that really an issue? if so, is there anything special you do to prevent it? thanks. |
08-17-2011, 05:59 PM
#14 | |
Oddometer: 7,268
People have good luck with the plug patches, but I've not used them very often.
08-17-2011, 06:20 PM
#15 |
Yinzer
Oddometer: 1,202
good to know. thanks man!
