Old 08-27-2011, 11:52 AM   #226
JensEskildsen
Oddometer: 1,012
Originally Posted by HighFive View Post
Kind of leaves you speechless, I guess.
HF
WE are speechless, thats why
2003 xt600e 150.000km
1986 xt350 100.000km
JensEskildsen is offline   Reply With Quote
Old 08-27-2011, 11:55 AM   #227
Reposado1800
Juicy J fan!
Reposado1800's Avatar
Oddometer: 5,776
The results are just awesome. Thanks for the hard work and money spent to make this happen! Now we know what this bike can do with the right mods.
Hate gets you nowhere.
Old 08-27-2011, 09:14 PM   #228
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Originally Posted by montesa_vr View Post
Sorry HighFive, I had been checking so often I finally gave up on you and decided to wait a while, so I didn't see the results until today. 20+% increase from the kit alone is a staggering gain for any performance modification short of a blower, so you should be proud of yourself.
I have to admit I cringed when I saw your head and port modifications. From what I've read, porting and combustion chamber shaping often requires more trial and error than theory. Some of the old gray-haired geniuses like Bob Braverman, Gordon Jennings, and Kevin Cameron have told from bitter experience about discarding cylinder heads after even the most obvious-seeming improvements turned out to be steps backwards. So I was relieved when I saw the big gains. If nothing else, you couldn't have screwed it up too much. And I was especially surprised at the gain in upper rpm horsepower, which is not a typical result of a bore increase. So maybe your porting had something to do with that.
You are to be commended for putting an incredible amount of time and money into sharing your experiment. Many of us have bought magazines for far less information. I don't expect anyone to step up and put the same amount of effort into documenting the stroker kit, but I hope at least you will get a chance to ride a stroked bike side by side with yours and offer some thoughts.
I fully understand your "cringing". I'd be lying if I said I wasn't a bit nervous about it myself. But, you know how it is when two old friends get together and start pondering What If. One thing leads to another......and then another. It took a stiff shot and a steady hand. Ok, maybe four.
I didn't expect much from the porting, as I'm well aware money spent on 4-stroke head modifications is typically the worst money spent in the "gain per buck" department. But apparently, I'm just not the typical type. We did the work ourselves, so no money was spent.
And, I already had plenty of riding time on the Athena Big Bore to know its performance characteristics fairly well....at least by feel. So, I had a specific target in mind before we messed with it. Not something for the weak knee or faint heart. That's for certain. No one should attempt anything like it just willy nilly. And, I'd say your interpretation of the results is fairly accurate. At the least, we got lucky and didn't screw it up. At the most, I gained some additional mental HP.
HF
'13 Husky TR650 Terra, '11 Husaberg FE390, '10 KTM 450 XCW Six Days, '12 BMW R1200GS
The Okie-Dokie BDR Terra-izing the CDR Bergs Over the Rainbow
Texas or Bust! Rocky Mountain HighFive The Other Side of Nowhere
Athena Big Bore Project
HighFive is offline   Reply With Quote
Old 08-28-2011, 07:58 AM   #229
Reposado1800
Juicy J fan!
Oddometer: 5,776
I think you did a great job with the porting. There is no way the factory can spend the time cleaning up the ports on every head. They just run with close enough and that "close enough" costs power in the top end. That said, how close is the water jacket to where you were grinding? Did you feel there was enough meat in the casting?
Old 08-28-2011, 11:02 AM   #230
slideways
permanent ex-pat
slideways's Avatar
Oddometer: 5,633
Great thread! I have always been a big fan of big bore kits. Recently did a big bore kit on my GF's Vespa 50cc to 70cc it runs great. My next big bore kit will be a 453 kit installed in my KTM 400. Thanks for the time and effort to post in here.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
Upper Italian Lakes report.
http://www.advrider.com/forums/showthread.php?t=160841
South Africa, Swaziland, Botswana ride report
http://www.advrider.com/forums/showthread.php?t=454490
Great CanAm Tour
http://www.advrider.com/forums/showthread.php?t=476605
slideways is offline   Reply With Quote
Old 08-28-2011, 03:56 PM   #231
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Unknown.....its rather hard to guess at that one. If antifreeze mix shows up in my oil, then will know the answer was "not enough".
HF
Old 08-29-2011, 03:28 AM   #232
tompee
tompee's Avatar
Oddometer: 97
I would also like to thank Highfive, from the bottom of my crankcase, for the effort and attention to detail in documenting these upgrades. Thinking long and hard about stroking my WRX now!
tompee screwed with this post 08-29-2011 at 06:35 AM
tompee is offline   Reply With Quote
Old 08-30-2011, 04:52 PM   #233
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
I might ought to mention, there was one other difference in my bike between Dyno 1 & 2 vs. Dyno 3 runs.
My first two runs were made with Krause Racing Ti sprockets and Sidewinder Smart-chain. Just before the Dyno 3 run, I changed to Supersprox combo with RK-xwring chain. Kept the exact same gearing ratio at 13/46, but only had about 300 miles on new chain & sprockets prior to Dyno3.
If anything, I would expect the heavier (new) chain and sprockets to yield more drag. The Sidewinder combo is claimed to add about 1.5 hp. So, I might of had an even better result running the original combo, but it was totally worn out.
Doesn't really matter to me, but I thought you ought to be made aware of these minor changes which could have affected test results (slightly). FWIW
HF
Old 08-30-2011, 06:16 PM   #234
Gany
Oddometer: 330
Thank you Highfive for your detailed posts. I know these things come at some expense if dyno costs are anything like they are in Australia.
Have you noticed much of a difference long term now regarding fuel consumption compared to stock?
Gany is online now   Reply With Quote
Old 08-31-2011, 11:52 AM   #235
freetors
Oddometer: 882
HighFive, You'll have to make the short drive up to C'ville and give me a test ride
freetors is offline   Reply With Quote
Old 09-01-2011, 09:09 AM   #236
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Yes indeed, they are. Think my project costs have exceeded intentions. But, that gnawing quest to know....
Guess I should have charged admission. I'll gladly accept papypal donations and start another project.
I have not measured fuel consumption yet. But, I guess I can do that now. I was averaging about 55 mpg (+/-) previously. Give me some time, and I'll report back later.
HF
Old 09-01-2011, 08:43 PM   #237
reddirtjoe
thinning the herd.
reddirtjoe's Avatar
Location: Let's Ride some red dirt!!.... NorthCentOklahoma
Oddometer: 2,003
Cycle World magazine, June 11 issue.
They added a Athena big bore kit too.
(plus GYTR Slip on muffler,gearing changed to 13/49, EFI box?)
Anyway, H.P. went from 28 stock to 33
Torque went from 17 to 22
Most likely on a different dyno and different weather then HighFive's, but you get the idea of improvements made by the big bore kit!!
I used to be a dumbazz,
then a smartazz
this year,....just an azz
reddirtjoe is offline   Reply With Quote
Old 09-08-2011, 12:17 PM   #238
montesa_vr
Legend in his own mind
montesa_vr's Avatar
Oddometer: 1,936
Thanks for the heads up. Here's the web link:
http://www.cycleworld.com/first_moto...pecial_feature
montesa_vr is offline   Reply With Quote
Old 09-08-2011, 06:57 PM   #239
Lesharoturbo
Nerdly Adventurer
Lesharoturbo's Avatar
Oddometer: 1,168
HF
I am very impressed with the torque curve. It is FLAT from 4300 - >8500!!!! I like the HP boost also, but so many times the torque suffers due to HP gains. Manufacturers would kill for that kind of flexibility! You,sir, have made a very different machine than Yamaha shipped over the ocean. It should be called the HF 290.
Impressive indeed!!
Individuality is best expressed individually; you are conforming in your non-conformity.
Lesharoturbo is offline   Reply With Quote
Old 09-09-2011, 05:54 PM   #240
HighFive OP
Never Tap-Out
HighFive's Avatar
Oddometer: 2,729
Impressive indeed!!
And it runs good too....
Thanks for your kind comments. I'm very pleased with the result. Seems better and better every day I ride it. I'll be hitting some serious trails this weekend.
HF
Times are GMT -7.   It's 02:59 AM.
