Old 08-30-2011, 09:29 PM   #1
anonny OP
What could go wrong?
anonny's Avatar
Oddometer: 5,745
Another kick at the cat, 71 CL 450 restoration
I have RTW02 to thank for giving me the "hot tip" on this one Bought it from a nice couple in Kelowna who let me have it for a decent price for both parties, this is going to be a stock resto but not concours enough to break the bank.... a rider shall we say.
Let the fun begin.... caved in tank on this side, anyone have a spare getting in the way?
Luckily it's all there with relatively low mileage, but engine is seized $
This better reflects the general overall condition.
Kawasaki H1 build thread
71- 450 Honda CL re & re
anonny is offline   Reply With Quote
Old 08-31-2011, 08:28 AM   #2
Skowinski
Primate
Skowinski's Avatar
Oddometer: 6,220
Those old 450's are cool bikes. I was looking at one, the CB model, a while back, but the owner was just asking too much for it so I walked.
"A person needs a little madness, or else they never dare cut the rope and be free."
~ Nikos Kazantzakis
Skowinski is offline   Reply With Quote
Old 08-31-2011, 10:38 AM   #3
MacNoob
MacNoob's Avatar
Oddometer: 1,713
Awesome, I have your bike's little brother - pic is when we dragged it out from behind a shed:
MacNoob is offline   Reply With Quote
Old 08-31-2011, 08:14 PM   #4
anonny OP
anonny's Avatar
Oddometer: 5,745
What year is that, I notice the paint is the same but my has chrome fenders. Are you doing anything with it? wanna sell the tank
Todays chore was to see why the engine was stuck, aaaha just as I expected
Top end doesn't look too bad
So after a few days soaking the cylinders were reluctant to come off.... time for some friendly persuasion
a flawless execution, took some leverage and tapping as the right piston was real bad
The helpless victim
The piston and cylinder fate will be determined with some measuring, anyone been able to reuse stuff that looked this trashed before?
Old 08-31-2011, 08:28 PM   #5
MacNoob
MacNoob's Avatar
Oddometer: 1,713
It's a '71 CL175. ONE of your cylinders is bigger than both of mine together.... I don't think there would be too much parts commonality with your bike! But yes, the tank is in nice shape. I hope to just polish this thing up and not have to repaint much.
Make sure you come visit at www.hondatwins.net the source of all goodness for these bikes.
Old 08-31-2011, 08:32 PM   #6
crazydrummerdude
Wacky Bongo Boy
crazydrummerdude's Avatar
Oddometer: 7,651
Yep.
crazydrummerdude is offline   Reply With Quote
Old 09-01-2011, 08:33 PM   #7
anonny OP
anonny's Avatar
Oddometer: 5,745
Rods don't look too bad
Piston rings stuck big time, notice the bent oil control ring. Now how do you get the seized rings out? For the first time I broke a ring trying to get it out, this was the "good" piston (read less seized)
As soon as I can free the rings a friend will do some measuring for me.
Old 09-03-2011, 03:18 PM   #8
anonny OP
anonny's Avatar
Oddometer: 5,745
Anyone know how to remove the crank drive gear?
bit of an odd design.
Old 09-04-2011, 05:43 PM   #9
briarpatch
Oddometer: 57
It's been a long time since I tore down a CB/CL 450, but I believe you remove the inside snap ring and pull the cover out of the oil sludge trap. Inside is a nut (left hand thread?) removed by a special four pin socket after peening down a security washer. At any rate, pull that snap ring and cover and you can see inside. THANKS - Stan PS Those torsion bar valve springs were WAY cool for an everymans bike back then.
briarpatch is offline   Reply With Quote
Old 09-04-2011, 06:50 PM   #10
electroken
Oddometer: 219
That's a pretty standard centrifugal oil filer design for the early Honda twins.
Once the snap ring is out, you can thread a long M6 screw into the inner half of the centrifugal filter to help pull it out. A 40 year old o-ring will be fighting you the whole way. Coming up with the special four-fingered tool to remove the filter nut from the crank will be the hard part. There should be a locking washer staked in place under the nut that will have to be flattened before the nut will come off.
electroken is offline   Reply With Quote
Old 09-04-2011, 08:40 PM   #11
anonny OP
anonny's Avatar
Oddometer: 5,745
You guys were right on the money, inside the centrifuge and no that is not my handy work
it gets better
oil drain bolt
and no again.... I cannot take credit for the alternative tool work.
But on the brighter side of things
Tranny looked good, bearings good... whew
Shift forks are decent
But the biggest prize is the crank looks good, bearings check out and I don't have to worry about sending it out and spending a ton o cash (I remember my Mach 3 costing $1000 for a crank rebuild)
Old 09-05-2011, 05:33 AM   #12
electroken
Oddometer: 219
It appears that a previous owner had 3 tools in the tool box: Vise-grips, a punch, and a big-ass hammer.
Old 09-05-2011, 06:17 AM   #13
AtLarge
AtLarge's Avatar
Oddometer: 128
And no skills or common sense.
1973 CL70-K3
1983 KZ750-K1
2008 GSX1300-BKK8 #1120
Cardo Scala rider G4 PowerSet
AtLarge is offline   Reply With Quote
Old 09-05-2011, 06:22 AM   #14
Skowinski
Primate
Skowinski's Avatar
Oddometer: 6,220
Looks pretty typical of lots of the work I've seen on used bikes, unfortunately...
~ Nikos Kazantzakis
Old 09-05-2011, 11:20 AM   #15
LasseNC
XSessive!
LasseNC's Avatar
Oddometer: 1,077
I'd say the small-ends look scored?
Times are GMT -7.   It's 03:24 PM.
