Old 09-18-2011, 11:56 AM   #1
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 15,063
Overgrown Offroad Zombie
If BMW destruction bothers you, stick to the hover and resist the click.
I picked up this 2001 1150GS in a trade and realized that needed upkeep was more than I could afford...conversion to something better was my only choice or so the voices told me.
Start with this:
Watch the flea market and find an XRR front end:
Remove 149 pounds of crap to get to this:
Find a CR500 frame on the 'list for $65, it's steel and uses the same head bearings and races as an XR650R:
Cut a little bit at a time for mockup:
Tell silly Lily to stop bothering me:
Start making parts:
Enjoy the look on my Father-n-laws face when he sees what I've done to this fine BMW:
Start adding tube:
Realized I put the fuel tank mounts in the wrong spot, back bone hits the tank...hmm, I better put it on it's feet before I get too crazy with the welder.
That last picture was nine days into the build. I spent some time measuring and ordering parts between selling the 1150GS parts I don't need anymore. Figured out the tank mounting and some other stuff. Then I got the flu and lost 10 pounds, in recovery mode now...maybe some bike progress today.
Stay tuned...a buddy is helping me figure out how to run a stand alone electronic ignition without the Motronic and I'm putting carburators on it too.
I have to start test riding this thing by the end of October as my wife and I are riding it two-up in November all over Death Zombie Valley.
larryboy is online now   Reply With Quote
Old 09-18-2011, 12:04 PM   #2
andyhol
volcano rider
andyhol's Avatar
Oddometer: 153
weight as it stands? very very cool imho
current rides: tiger 200 and cb200 scrambler in indo
90 yamaha xtz750 super tenere, 98 honda vtr 1000 firestorm in the uk
andyhol is offline   Reply With Quote
Old 09-18-2011, 12:05 PM   #3
bk brkr baker
bk brkr baker's Avatar
Oddometer: 5,894
Watch out !
Them propeller fellers are massing for an attack!
bk brkr baker is online now   Reply With Quote
Old 09-18-2011, 12:09 PM   #4
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 15,063
I was at 430 before I started putting parts back on. I'll have to do a final teardown for paint and will weigh stuff as it goes back on.
Edit: I'm hoping for 480 pounds ready to ride, with hard bags and mounts I'll probably end up at 500 pounds. 81 pounds lighter than stock.
Old 09-18-2011, 12:45 PM   #5
roadrage
roadrage's Avatar
Oddometer: 1,022
Put the Harley wheels on it!!! :-)
Cool hackage!
Live by the sarcasm. Die by the sarcasm.
roadrage is offline   Reply With Quote
Old 09-18-2011, 01:49 PM   #6
sailah
Lampin' it
sailah's Avatar
Oddometer: 5,766
Sweet, I like your style
We're not out here to rough it. We're here to smooth it. Things are rough enough in town.
Nessmuk
Old 09-18-2011, 02:19 PM   #7
fatpony
Dixiecrat
fatpony's Avatar
Oddometer: 218
Thumb
YOU are my hero and an inspiration! Please continue. Thanks, Mike
"Good enough is seldom either, but it'll do"
fatpony is offline   Reply With Quote
Old 09-18-2011, 02:48 PM   #8
CamoGreg
Can you see me?
CamoGreg's Avatar
Oddometer: 5,116
He wasn't right...in the head.
CAMOGREG
"We're all travelers in this world. From the sweet grass to the packing house. Birth 'til death. We travel between the eternities." -Prentice Ritter
CamoGreg is offline   Reply With Quote
Old 09-18-2011, 03:04 PM   #9
rallyman1978
rallyman1978's Avatar
Oddometer: 199
Wicked
rallyman1978 is offline   Reply With Quote
Old 09-18-2011, 03:46 PM   #10
Wolfgang55
Wolfgang55's Avatar
Oddometer: 3,521
So the BMW 1150 was to costly to keep up on the maintenance.
You keep the motor & put carbs on board.
You do have a vision & I too want to see it run & stop.
Good luck.
Wolfgang55 is offline   Reply With Quote
Old 09-18-2011, 04:47 PM   #11
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 15,063
Oh yeah, I traded the gauges for a rear GSA model rear wheel with a new TKC on it. Gonna have to pick up a fresh rear rotor as I let the rotor go with the wheel set I sold.
Old 09-18-2011, 06:35 PM   #12
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Originally Posted by larryboy View Post
I'm actually trying a small Magura clutch master to save weight, we'll see if it can move enough fluid.
The OE master bore diameter is 16mm and the slave is 24mm. Based on the 'engagement range' of the OE clutch I'd guess that a 10% smaller master bore diameter still might work. Say 14.5mm as a minimum diameter.
But since Magura makes the OE BMW master, you might find a 16mm Magura part. If so, on the old and new clutch levers check the centerline distance between the clutch lever pin and the piston pin. For the same bore diameter, that dimension determines lever throw.
IICE Air Hotrod your GS  Fuel Injection  Tech Info  Buy  Order List  Installation
Poolside is offline   Reply With Quote
Old 09-18-2011, 06:46 PM   #13
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 15,063
I'm more of a bolt it on, bleed it and see if it works kind of guy. Clutch master is in stock, I have a couple of different ones I can try. Probably get to it after the new springs go in the forks and front end is complete.
Old 09-18-2011, 06:58 PM   #14
Poolside
Syndicated
Poolside's Avatar
Oddometer: 11,887
Yea, I am getting that feeling about you
Old 09-18-2011, 07:00 PM   #15
larryboy OP
Chopper Rider
larryboy's Avatar
Oddometer: 15,063
Times are GMT -7.   It's 09:21 AM.
