09-25-2011, 09:23 AM
#31 |
Random Hooligan
Oddometer: 6,182
I wonder if it's because the BMW stator's output is not high enough for the load we're putting on them which is causing them to burn out?
![]() Which leads back to what I've been wondering for a while, is there a way to increase the output of the stator? I know on my XR400R I just had it re-wound by Baja Designs, why can't we do something similar to the BMW stator?
-Scott- Semper Fi '04 BMW R1150GSA, '08 KTM 450EXC-R, '04 KTM 625 SXC "A pessimist thinks all women are bad. An optimist is one who hopes they are." Chauncey Depew
09-25-2011, 12:40 PM
#32 | |
Oddometer: 2,828
Erling |
09-25-2011, 12:42 PM
#33 | |
Random Hooligan
Oddometer: 6,182
So, does anyone know of a way to increase the stator output?? That's one advantage the Tiger has over the 800GS.
09-25-2011, 05:14 PM
#34 |
Oddometer: 1,237
Well, I can't say mine had any extra strain on it. Never had battery troubles (still on the original) and nothing extra wired in save a GPS. Made it just over the 50k kms mark. Pretty pathetic if you ask me. Add in the month it was in the shop waiting on parts, and the whole experience left me very non-plussed.
09-25-2011, 06:04 PM
#35 |
carver
Oddometer: 67
Stator
My stator failed at 27000 miles. Three days before my warranty expired. I have heated grips and run an Oregon gps. I have no other electrical options. My original Excide BMW stock battery lasted three years, until my alternator died. Dealer repaired under warranty in 10 days. Will we will see more stator failures? Hmmm.
RJeff 05R1200GS then 09F800GS now |
09-29-2011, 04:37 PM
#36 |
Oddometer: 3,441
As ebrabaek said, apparently the stator is always producing 100% of what it is capable of producing given the RPM ... the regulator simply dumps the power it does not need back to the frame of the bike ... apparently other bikes use this style of regulator.... seems a bit screwy to me ....
Having more accessories drawing current would perhaps reduce the load on the regulator but the stator is working its ass off no matter what and getting quite hot doing so ....
09-29-2011, 07:29 PM
#37 |
Reseda, CA
Oddometer: 3,489
Dead stator at 18,000 or so for me.
http://johngil.whereamiriding.com |
09-29-2011, 10:27 PM
#38 |
Oddometer: 1,237
09-30-2011, 03:08 AM
#39 |
Oddometer: 4,915
Definitely a weak point on these bikes. Life expectancy seems to be around 50,000 miles or even significantly less in quite a few cases. Try to get them to take a few pictures to see if it's just a nicked wire or if the whole thing is burned out and black like Finn's.
I think the possible solutions would be weaker magnets, higher quality wires and epoxy insulation, or a series regulator. The last one would be the nicest as you wouldn't reduce the electrical power output.
Proud member of the HUSABERG ADVENTURE TEAM! '12 Husaberg FE570, 09 KTM XC-F/ 450 RFS hybrid, 07 KTM 450 SMR, 08+09 BMW F650GS twins/F800GS conversion, 03+05 YZF-R6 |
09-30-2011, 11:13 AM
#40 |
NoMoTDM still Gary
Oddometer: 3,711
There are other types of regulators out there that "should" work, that use relays instead of shunting excess amps to the frame. An on demand type that may prolong stator life. Called Mosfet. Triumph apparently uses this type of regulator. Here is an aftermarket source. http://roadstercycle.com/Shindengen%...rade%20kit.htm
You do not want one that outputs more than 14.5v. The above one is rated at 30amps. Being an electrical idiot, can some one commit on what 30 amps is referring to? I am assuming the max rating of each of the stator output wires. I know some of you have measured stator output on the F800, what are the the readings. Can't find a source for what effect on Canbus this may have, any thoughts?
BMW Motorrad USA customer service: "We make superior motorcycles and continue to improve them." |
09-30-2011, 11:54 AM
#41 | |
Oddometer: 4,915
That is not the case unfortunately, a MOSFET R/R will do nothing for stator life. It's just a more efficient switching circuit, so it heats up less. That is good on bikes that regularly burn out R/Rs, but not in our case. Guess where that extra power gets dissipated instead - the stator. The type that will help is a series type regulator that I mentioned above. I explained it in another thread on stators here in the parallel universe how it does it by reducing the actual power being produced, will post it again when I have access to a computer. Btw the rating of a R/R refers to the total power it can deal with, not each of the wires.
09-30-2011, 05:16 PM
#42 | |
Oddometer: 3,441
In terms of power rating, 30 amps is roughly what we would need, the charging system on the F800GS is spec-ed at 400 watts - watts is Voltage x current so at (say) 13 volts, 400 watts is indeed ~30 amps. Nice article here that explains how crappy shunt regulators (wait ... I meant "cost-effictive" ) differ from the more advanced designs (see the section "Active regulators"). http://en.wikipedia.org/wiki/Voltage_regulator One key thing I think we should all be doing is making sure that the frame/ground connection to our regulators is clean and solid ... if not, the regulator will quickly fry. Other than replacing the regulator with a more advanced design, or somehow improving the stator windings or keeping them cooler I'm not sure what else we can do............... |
09-30-2011, 06:05 PM
#43 |
NoMoTDM still Gary
Oddometer: 3,711
I though the Mosfet RR was a relay type. Trying to educate myself, I read on the internet (must be true) that is had the ability to shut down a segment of the stator if all the amps were not needed.
It would be nice to see an electrical diagram to determine if all the bikes power comes off the battery or are parts of the systme fed directly from the R/R. Still have not heard whether Canbus would prohibit some other option.
10-01-2011, 07:44 AM
#44 |
Oddometer: 3,441
Gary:
Here's the scematic .... I figured it would be more complicated, but really there is not much to see once you've seen it .... ![]() 3 wires from stator to R/R then a pair of wires wires from Regulator to each terminal of the battery JRWooden screwed with this post 10-01-2011 at 07:51 AM |
10-01-2011, 08:36 AM
#45 |
NoMoTDM still Gary
Oddometer: 3,711
Thank you. It looks simple enough. All roads lead to the ECU
